Страница 9 от 106 ПърваПърва ... 78910111959 ... ПоследноПоследно
Резултати от 121 до 135 от общо 1582
SONY телевизори (инфо на първа страница)
    #121
    Отговор: SONY телевизори 2020
    We review the Sony A8 (also marketed as the Bravia A8H in the USA), a 2020 4K OLED TV from the Japanese brand. Topics covered include near-black handling, colour accuracy, motion performance including X-Motion Clarity 120Hz BFI, upscaling, gradation, HDR including Dolby Vision, and input lag for gaming.
    Our review sample is the 65-inch Sony KD-65A8, but the Sony A8 is also available in a smaller screen size of 55 inches (model number KD-55A8).
    https://www.lcd-compare.com/gamme-tv...ine-up-409.htm
    A8 : Metal Blade double position / RMF-TX500E черно пластмасово
    A85 : Premium simple position / RMF-TX600E алуминиево
    A87 : Premium simple position / RMF-TX611E алуминиево с подсветка
    A89 : Premium simple position / RMF-TX611E алуминиево с подсветка
    Sony Android TV (EU) - Platform
    Platform & SoC 2020 2019 2018 2017 2016 2015
    Model: BRAVIA VH1
    SoC: MediaTek MT5895 (aka S900)
    Installed RAM: 3 GB
    Core Architecture: 4x ARM Cortex-A73
    CPU Clock: 1800MHz
    GPU Renderer: ARM Mali-G52
    Storage: 16 GB
    OpenGL ES: 3.2
    Android 32-bit (9.0 Pie)
    Supports HDMI 2.1 (48Gbps) , HDCP 2.3, USB 3.0
    Oled A9 - X1 Ultimate ??
    XH9299 - 4K HDR X1
    XH9288 - 4K HDR X1
    XH9096 - 4K HDR X1
    XH9077 - 4K HDR X1
    XH9005 - 4K HDR X1
    Model: BRAVIA 4K UR3
    SoC: MediaTek MT5893 (aka MT5598)
    Instaled RAM: 2.5 GB
    Core Arhitecture: 4x ARM Cortex-A73
    CPU Clock: 1032-1500MHz
    GPU Renderer: ARM Mali-G71
    Storage: 16 GB
    OpenGL ES: 3.2
    Android 32-bit (9,0 Pie)
    Support: HDMI 2.0b (18Gbps), HDCP 2.2, USB 3.0 & 2.0
    Oled A8, A89,A87,A85 - X1 Ultimate
    ZH8 (8K) - X1 Ultimate
    XH9505 (85-55") - X1 Ultimate
    XH9196 - 4K HDR X1
    XH8599 - 4K HDR X1
    XH8588 - 4K HDR X1
    XH8577 - 4K HDR X1
    XH8505 - 4K HDR X1
    XH8196 - 4K HDR X1
    XH8096 - 4K HDR X1
    XH8077 - 4K HDR X1
    XH8005 - 4K HDR X1
    Model: BRAVIA 4K UR2
    Installed RAM: 2.5 GB
    Storage: 16 GB
    OpenGL ES: 3.2
    Android 32-bit (8 Oreo)
    Supports HDMI 2.0b (18Gbps), HDCP 2.2, USB 3.0 & 2.0
    XH9505 (49") - X1 Ultimate
    ZG9 - X1 Ultimate
    Oled AG9 - X1 Ultimate
    XG9505 - X1 Ultimate
    XG8599 - 4K HDR X1
    XG8596 - 4K HDR X1
    XG8588 - 4K HDR X1
    XG8577 - 4K HDR X1
    XG8505 - 4K HDR X1
    Model: BRAVIA 4K UR1
    Installed RAM: 4 GB
    CPU Clock: 1500MHz
    Storage: 16 GB
    OpenGL ES: 3.2
    Android 32-bit (8.0 Oreo)
    Support: HDMI 2.0b (18Gbps) HDCP 2.2, USB 3.0 & 2.0
    Oled AG8 - X1 Ultimate ?? Oled AF9 - X1 Ultimate
    ZF9 - X1 Ultimate
    Model: BRAVIA 4K ATV3
    SoC: MediaTek MT5891 (aka 5596)
    Installed RAM: 2 GB
    Core Architecture: 4x ARM Cortex-A53
    CPU Clock: 1100 MHz
    GPU Renderer: ARM Mali-T860 MP2
    GPU Cores: 2
    Storage: 8 GB
    OpenGL ES: 3.2
    System: 4.9.51 ()
    SDK: 26
    Android 32-bit (6.0 Marshmallow - 8.0 Oreo)
    XG9005 - X1 Extreme
    XG8399 - 4K X1
    XG8396 - 4K X1
    XG8388 - 4K X1
    XG8377 - 4K X1
    XG8305 - 4K X1
    XG8196 - 4K X-Reality Pro
    XG8096 - 4K X-Reality Pro
    Oled AF8 - X1 Extreme
    XF9005 - X1 Extreme
    XF8596 - 4K HDR X1
    XF8505 - 4K HDR X1
    XF8305 - 4K HDR X1
    XF8005 - 4K X-Reality Pro
    Model: BRAVIA 4K ATV2
    Installed RAM: 2 GB
    CPU Clock: 1100 MHz
    GPU Cores: 2
    Storage: 8 GB
    OpenGL ES: 3.
    System: 3.10.79 (1.6.0.26.02.1.00)
    SDK: 24
    Android 32-bit (6.0 Marshmalloe - 7.0 Nougat)
    Oled A1 - X1 Extreme
    XE9405 - X1 Extreme
    XE9305 - X1 Extreme
    XE9005 - 4K HDR X1
    XE8505 - 4K HDR X1
    ZD9 - X1 Extreme
    XD8305 - 4K X-Reality pro
    XD8099 - 4K X-Reality Pro
    XD8088 - 4K X-Reality Pro
    XD8077 - 4K X-Reality Pro
    XD8005 - 4K X-Reality Pro
    SD8005 - 4K X-Reality Pro
    XD7505 - 4K X-Reality Pro
    XD7005 - 4K X-Reality Pro
    XD7004 - 4K X-Reality Pro
    Device: SVP-DTV15
    Product: SVP4KDTV15_EU
    Model: BRAVIA 4K 2015 ATV1
    SoC: MediaTek MT5890 (aka 5595)
    Installed RAM: 1.5 GB
    Core Architecture: 2x ARM Cortex-A17 + 2xARM Cortex-A7
    CPU Clock: 1100 MHz
    GPU Renderer: ARM Mali-T624
    Storage: 8 GB
    OpenGL ES: 3.1
    System: 3.10.79 (3.865)
    SDK: 23
    Android 32-bit (5.0 Lollipop - 7.0 Nougat)
    XE8099 - 4K X-Reality Pro
    XE8096 - 4K X-Reality Pro
    XE8088 - 4K X-Reality Pro
    XE8077 - 4K X-Reality Pro
    XD9405 - 4K X1
    XD9305 - 4K X1
    XD8505 - 4K X1
    X9005C - 4K X-Reality Pro
    X8505C - 4K X-Reality Pro
    S8505C - 4K X-Reality Pro
    X8305C - 4K X-Reality Pro
    S8005C - 4K X-Reality Pro
    W850C - X-Reality Pro
    W807C - X-Reality Pro
    W805C - X-Reality Pro
    W800C - X-Reality Pro
    W756C - X-Reality Pro
    W755C - X-Reality Pro
    Този пост е редактиран от hristoslav2; 11-06-20 в 20:22.
  3. Senior Member Аватара на cable
    Dec 2010
    #122
    May 2020
    #123
    Колеги ,както бях споделил в темата преди време е възможно да се инсталира firmware от XH95 на XG95, тъй като хардуерно са почти еднакви.Днес излезе официално ъпдейта на XH95 за Европа и преди малко реших да рискувам и да го сложа.Всичко мина безпроблемно и вече съм с менютата на XH95.Не съм правил кой знае какви тестове все още,но ми хареса ,че при натискане на info бутона,вече изписва дали сигналът е HDR или не и няма нужда да се влиза в display settings,за да се види. Ако някой реши и той да го слага, първо да ъпдейтне до последния официален firmware за XG95 ,който е v6.3626 , след това свалете ъпдейта за XH , който е v6.4770 ,качвате го на флашка според инструкциите в сайта на сони за ъпдейт и следвате стъпките. Правете го на своя отговорност !!!! Не съм отговорен ако някой си брикне телевизора.Може да прочетете в reddit и avsforum в конкретната тема на xg950 където се обсъжда цялата гимнастика.
    Jan 2011
    #124
    Някакви други предимства установил ли си?
    Sent from my SM-N975F using Tapatalk
    May 2020
    #125
    Струва ми се ,че local dimming-ът на high е една идея по-агресивен от преди ,менютата работят още по-бързо ,google voice search е по-бърз. Clearness на 1(x-motion clarity) определено прави още по-плавни движенията от колкото бяха преди това и май най-ярките хайлайти при HDR станаха още по-ярки (но това специално може и да е пласебо) . Като цяло това са ми наблюденията.
    Jan 2011
    #126
    Мерси, може ли линк към темата.
  9. Member Аватара на TODD
    Jul 2006
    #127
    Нормално е да стане файловете са за една и съща генерация ТВ 2018. Справка със сайта на Сони. KD-55XH9505 (sony_atvotafull_2018_1604770100_eua_auth.zip) KD-55XG9505 (sony_atvotafull_2018_1603626100_eua_auth.zip) Според мен е въпрос на време да го заменят файла и за Модели 2019. Лично съм пробвал firmware за KD-43XE8077 (sony_dtvota_2016_1606555100_eua_auth.zip) да го кача на KD-49X8005C (sony_tvupdate_2015_5435_eub_auth.zip). Ефекта е нулев телевизора се рестартира и не се ъпдейтва. Се пак Това е Сони не някоя китайска марка.
    Mar 2008
    #128
    еееее TODD , ако намериш начин да се ъпдейтнат нашите стари ТВ-та би било супер, но според мен е мисия невъзможна
  11. Junior Member
    May 2020
    #129
    Този пост е редактиран от hristoslav2; 19-09-20 в 22:17.
    Jan 2011
    #130
    Добре де ама моята версия излиза по-висока от 6.3626?
  13. Junior Member
    May 2020
    #131
    Ако си си купил скоро телевизора ти е фабрично с тази версия,която официално не е пусната още.
    При мен в момента е така -
    Jan 2011
    #132
    Да, тази седмица. Въпросът е дали мога да ъпдейтна с твоята.
  16. Member Аватара на TODD
    Jul 2006
    #133
    apmil4ev Мнението ми беше насочено към style34 и devilnevercry86, че няма вероятност да си брикнат телевизорите (освен ако не спре тока по време на ъпдейта) с ъпдейта понеже е за една и съща платформа. Примера ми беше само като информация, че дори да объркаш версията ТВ-то не се ъпдейтва. А това, че нашите ще се ъпдейтнат към по висока версия няма да стане ясно ми е.
    Цитат Първоначално публикувано от style34 Виж публикацията
    Можеш.
    #134
  18. Junior Member
    May 2020
    #135
    Видео сравнение на локалното затъмнение на XG95 преди и след ъпдейта с XH firmware
    https://www.youtube.com/watch?v=lQzT57ruHFk&list=FL4wZI_pfmRC5lJI08CybNiQ&index=2&t=98s
  1. Samsung телевизори (инфо на първа страница)
    Отговори: 1207
    Последно: Вчера, 21:16
  2. LG телевизори (инфо на първа страница)
    Отговори: 1022
    Последно: Вчера, 08:27
  3. Отговори: 117
    Последно: 12-06-21, 00:44
  4. SONY телевизори 2017
    Отговори: 1111
    Последно: 01-01-18, 07:21
  5. SONY телевизори 2015
    Отговори: 866
    Последно: 02-01-16, 08:36
