TOSHIBA 42SL863 VS. PANASONIC TX-L42E30E
  Здравейте!
Нека всички по компетентни и запознати с технологиите на използваните компоненти в двата телевизора,както и всички които ги притежават да изкажат мненията си относно предимствата и недостатъците на двата телевизора.
ето характеристиките на двата модела,както и разликите които намирам аз между тях са описани по долу.
Прочетете и споделете:)
TOSHIBA 42SL863
Diagonal Screen Size (cm / inch) 107/42
Screen Format 16:9
Panel Resolution 1920 x 1080
Brightness (cd/m2) 450
Dynamic Contrast Ratio 4.000.000:1
Response Time (G to G) (ms) 5.5
Viewing Angle (º) 178
LED-TV Yes
LED Edge Yes
Full HD - High Definition 1080p Yes
Meta Brain Yes
200 Active Motion Rate (AMR) / Frame Refresh Rate Yes
Resolution+ Yes
24p Mode: Standard | Smooth Yes
Real Digital Picture Yes
Digital Noise Reduction Yes
MPEG Noise Reduction Yes
3D Digital Comb Filter Yes
Active Backlight Control Yes
Ambient Light Sensor Yes
3D Colour Management Yes
Colour Temperature selectable Yes
Manual picture size select Yes
Exact Scan Mode Yes
Expert Settings
Pre-Sets: Hollywood Mode 1 & 2 (Day/Night Mode) Yes
Greyscale Settings Yes
Gamma Settings Yes
RGB Filter Yes
Integrated Universal Test Pattern Yes
601/709 Colour Decoding Selection Yes
Copy to All Inputs Yes
HDMI Information Yes
Tuning
TV Standards PAL I/BG/DK; SECAM BG/DK/L, NTSC BG 4.43
Number of Channels ATV (100) │ DTV (9999)
Analogue Yes
DVB-T Yes
DVB-T2 Yes
DVB-C / DVB-C (HD) Yes
DVB-S / DVB-S2 (HD) Yes
H.264 Yes
DVB Common Interface+ (CI+) Yes
NTSC Video-Playback Yes
Auto Set-up Yes
USB-Features
Picture (USB) JPEG
Audio (USB) MP3, MP4
Video (USB) AVCHD, AVCHD Lite, mts, m2ts, H.264, MPEG2-PS, mpg, mpeg, MPEG2, MP4, mp4, m4v
Personal-TV
4 User Modes Yes
Personal Picture Setting Yes
Personal Volume Setting Yes
Personal Favorite List Yes
Personal Recording Management Yes
Other Features
Freeze Screen Yes
Timer Yes
Panel Lock Yes
Auto Format Yes
4:3 stretch Yes
No Signal Off Yes
Hotel Mode Yes
Clone Mode Yes
Store Mode
Digital POP Demo Yes
Active Vision 100Hz demo Yes
Resolution + demo Yes
Eco
EU Eco Label Yes
Energie Label B
Presence of Lead (Below RoHS Directive limit including exemptions) Yes
Mercury Content <0,1 mg/kg
Cabinet
Touch Control Panel Yes
Swivel stand Yes
Wall Mountable (VESA) 400 x 400 (M8)
Accessories (optional)
USB wireless Dongle Yes
Picture Mode
AutoView Yes
Dynamic Yes
Game Yes
Movie Yes
PC Yes
Standard Yes
Store Yes
Audio
NICAM Stereo Yes
udyssey EQ Yes
Dolby Digital Plus Yes
Dolby Volume Yes
Sound Navi Yes
Sound Output (RMS) W 2 x 10
Interactive Features
Digital Text Yes
Text Page Memory 500
Electronic Programme Guide 8 Day Yes
Now and Next Information Yes
Favourite Channel Memory Yes
Smart-TV
Wireless Ready (Toshiba WiFi Dongle required) Yes
WiFi Protected Setup (WPS) Yes
DLNA Yes
DLNA DMP Yes
DLNA DMR Yes
Toshiba Media Controller compatible Yes
Compatible with Windows 7 Yes
You Tube Channel Yes
HbbTV Yes
Toshiba Places Yes
Toshiba AppsConnect Yes
Connections
HDMI 4
1080p, 1080i, 720p, 720i, 576p, 576i, 480p, 480i | 24Hz (24p) Yes I Yes
Version 1.4 | Audio Return Channel | HDMI Ethernet Channel | Audio Content Enhancement | 3D Yes │ Yes │ - │ Yes
REGZA-Link (HDMI-CEC) Yes
INSTAPORT™ Yes
LAN Yes
Component Video Yes
Composite Video Yes
SCART Yes
SCART (RGB | S-Video | AV) Yes
Analogue audio (Cinch) | Audio (mini jack) Yes IYes
PC Input Yes
USB Yes
Number of USB 2
Digial Audio Out Yes
Headphone Yes
Power Supply
Line Voltage 220-240V 50-60Hz
Power Consumption EN62087 - Home Mode (W) 94.75
Power Consumption EN60065 - Maximum power (W) 135
Power Consumption - Stand-by (W) 0.186
Yearly energy consumption (average) 138.335
Dimensions
Width (mm) 989
Height without Ped.Stand (mm) 607
Height with Ped.Stand (mm) 675
Depth without Ped.Stand (mm) 35.8
Depth with Ped.Stand (mm) 287
Weight without Ped.Stand (kg) 15.5
Weight with Ped.Stand (kg) 19.6
Packed width (mm) 1305
Packed depth (mm) 95
Packed height (mm) 700
Packed weight (kg) 21.6
Accessories (included in carton box)
Remote Control (Type) CT-90369
Remote Control Battery R03(AAA) x2
TV Stand Integrated Yes
Instruction Manual Yes
EAN
EAN 5900496513464
TV Tuner
Интегрирани тунери* PAL -B/G/H, -I, -D/K: SECAM -B/G, -D/K, L/L'; DVB-T, DVB-T (MPEG4-AVC [H.264]), DVB-C (MPEG4-AVC [H.264])
Приемане на телетекст 1000P
Дисплей
Контраст Висок контраст
Размер на екрана 42" (106 cm) диагонално
Панел IPS-alpha LED LCD панел (E-LED подсветка)
Panel Drive 200 blb IFC pro
Свободен зрителен ъгъл 178 градуса
Резолюция Full-HD 1,920 x 1,080 (16:9)
Приложими PC сигнали XGA, WXGA, SXGA 60Hz, 1920 x 1080 (HDMI)
Приложим формат на сканиране
FULL-HD 1080p (HDMI only), 1080i
HD 720p
SD 576i/p, 480i/p
Moving Picture Resolution 900 линии
Intelligent Frame Creation Pro да
Motion Focus Technology да
24p Smooth Film/Playback да/ да
Deep Colour (10-битов панел) да
Супер Резолюция да
Режим на картина Dynamic/Normal/Cinema/True Cinema/Game/Photo
Vreal Vreal Live
Звук
Високоговорители 2 x 10 watt 1-канални долни високоговорители
Режим на звука Music/Speech/User
Virtual съраунд V-Audio Surround
Dolby Digital/dts Dolby Digital Plus/DolbyPulse/dts2.0+Digital Out
Вход / изход
CI (Общ интерфейс) да
VIERA Image Viewer да (AVCHD/SD-VIDEO/Motion JPEG [Lumix]/MP4 [Xacti]/DivXPlusHD/MKV/MPEG4/JPEG/MP3/AAC/WMV/WMA playback)
USB 3 (2 задни, 1 страничен); Mass Storage/Keyboard/WiFi/USB-HDD Recording/SK Camera
USB HDD / SD Card Записване да (USB HDD)
HDMI Input/ Support Feature 4 (3 задни, 1 страничен)/ Audio Return Channel (Вход 2)
Композитен видео вход AV2: RCA фото тип х 1 (отстрани)
Компонентен видео вход RCA фоно тип x 1 set (задна част)
РC вход Мини D-sub 15-pin x 1 (отзад)
Аудио вход (HDMI, PC, Composite, Component) RCA фоно тип x 1 set (задна част)
21-Pin вход/изход AV1: AV вход/изход, RGB вход, Q-Link (отзад)
LAN Port да
Аналогов аудио изход RCA фоно тип x 1 set (задна част)
Цифров аудио изход (оптичен) 1, заден
Headphone Jack 1, страничен
Характеристики
Wireless LAN Адаптор** WiFi Ready
EPG (Now and Next) да
EPG for DVB-T (7days) Gemstar EPG: UK, Италия, Германия, Испания; 7-Days SI EPG: Франция, Швеция
VIERA Connect да
DLNA да
VIERA Tools да
VIERA Link да (HDAVI контрол 5)
Много прозорци PAT
Eco Навигация да
Режим Игра да
Q-Link да
Таймер изкл. да
Заключване за деца да
Основни
На режим средна мощност на потребление*** 70 W
Захранване AC 220 - 240 V, 50/60 Hz
Консумация-висока оценка 102 W
В режим на готовност потребление 0.3 W
Размери (Ш х H х Д) (без стойка о) 1,002 x 611 x 75 mm (Дълбочина на панела: 41 mm)
Размери (Ш х H х Д) (със стойката) 1,002 x 646 x 288 mm
Тегло (без стойка о) 15.5 kg
Тегло (със стойката) 19.0 kg
Wall Bracket TY-WK3L2RW
VESA Standard да
Други спецификации
ЗАБЕЛЕЖКА * Забележка за DVB функции: / Този телевизор е предназначен да отговаря на стандартите (настоящи от август 2009 г.) на DVB-T/C/S/S2 (MPEG2 и MPEG4-AVC [H.264]) услуги. / Съвместимостта с бъдещите услуги DVB не е гарантирана. / DVB-T MPEG4-AVC предаване е на разположение в избрани страни: Дания, Испания, Естония, Франция, Литва, Норвегия, Словения, Швеция, Полша, Унгария, Португалия. / DVB-C функция е достъпна само в следните страни: / Швеция (ComHem, Canal Digital), Дания (YouSee), Норвегия (Canal Digital), Финландия (кабелна Готов HD), Германия, Швейцария, Холандия / Списъкът на страни по-горе е от 1 януари, 2010. / Проверете най-новата информация за наличните услуги на следния електронен адрес (само на английски): / http://panasonic.jp/support/global/cs/tv/ / ** В зависимост от района, този аксесоар може да не е включен. / ** Въз основа на метода за измерване на IEC 62087 Ed.2.
Основните разлики които намирам аз са:
TOSHIBA 42SL863 PANASONIC TX-L42E30E
s-тунер-да       не
usb-2бр.        3бр.
pvr функция-не   да
DTS-не         да
За Тошибата чзнам,че има проблеми със субтитрите на DIVX,но така и не разбрах с другите кодеци има ли субтитри?
-Слаб контраст спрямо други модели-аз го гледах в магазина и на SD сигнал си излъчва доста прилично.
-не познава всички спътници
-медия сървъра дава грешка на avi формат
-некачествен звук
За Панасоника
-Проблеми с PVR фукцията от външен хард(при запис диска се форматира и губи цялата информация)
-лош контрол на панела и настройките на картина и канали
Това се сещам за сега.
За проблеми със субтитрите от usb при Панасоника не съм запознат,така че който го има или знае да пише.
За отстраняването на същите при Тошибата давайте решения.
Какво е най удачното свързване с компютър и за двата модела?
Имам видео карта nvidia G-force 9800GT преходник от DVI към HDMI и S-PDF кабел за връзка с аудиото към дъното.
Изискванията към телевизора са:
-Надежден панел с приятна за окото картина
-40-42 инча
-цена до 1400лв.
-по възможност добър медия плеър и настройки
Да не пускам нова тема:
приемам и други предложения за марка и модел.
от 3d моделите се спрях на LG 47LW4500 основно поради ниската цена и гаранцията от 5 години!(пишете от трите кой си заслужава най вече)3d-то не е приоритет
Трябва да направя избор възможно най скоро,така че не се бавете с постовете си:)
Благодаря!
     Re:TOSHIBA 42SL863 VS. PANASONIC TX-L42E30E
  -Според мен панел Samsung с матрица S-PVA
-Samsung UE-40D5800  Version:01  Z8Y83SMB500010F
-цена1.339 лв
-най добрият плеър e на samsung
Относно 3d LG 42PW450 е добър избор !
				Първоначално публикувано от V.Valev
 За Панасоника
    Това е стандартно за всички марки телевизори. Харда се форматира от телевизора, като записва е кодиран и се възпроизвежда само от телевизора на който е направен.
