Problem s Video Capture, njakoi znae li zasto?
Zdraveite,
Imam Win XP i se opitvam da zapi6a nesto ot TV kartata. No kogato file stane kym 5 Gb, programata spira da zapisva. Probvah s 3 razli4ni programi i vse taka. Zapisvam na FAT32 djala, kudeto imam i mnogo svobodno mjasto.
4udja se da ne bi Windows-a da ima njakakvo ograni4enie za goleminata na failovete?
DA, 4GB limit na file-a
(ot helpa na XP daj FAT32 edin ot topicite... po dolu sum izvadil suhtestvenoto ot nego)
FAT32
Volumes from 512 MB to 2 TB.
In Windows XP, you can format a FAT32 volume up to 32 GB only.
Does not support domains.
Maximum file size is 4 GB.
FAT
Volumes from floppy disk size up to 4 gigabytes (GB).
Maximum file size is 2 GB.
NTFS
Recommended minimum volume size is approximately 10 megabytes (MB).
Volumes much larger than 2 terabytes (TB) are possible.
Cannot be used on floppy disks.
File size limited only by size of volume.
Ufffff, da e... i njama li njakakyv na4in da go nakaram na FAT djala da zapisva po-golemi failove? Imam dosta informacija tam i iskam da moga da go polzvam pod DOS.
Има името му е Partition Magic :)
цепиш, правиш струваш...
2 дяла ... Fat и Ntfs (Нали имаш много място)
после пак можеш да си ги събереш....
Ehh, javno ste se nalozhi da formatiram. No vyv vsi4ki slu4ai blagodarja mnogo za informacijata.
A be vie neshto ste se pobarkali....
V momenta polzvam edin cial HDD(logi4eski i fizi4eski) 40GB, pod Windows XP, i 98, i niama nikakav problem, koi vi goni s tia "do 32 GB, up to 4 gb"??!?!?
To4nia prevod na izre4enieto:
"In Windows XP, you can format a FAT32 volume up to 32 GB only."
e, 4e pod Windows XP MOJETE DA FORMATIRATE FAT32 DO 32 GB!!!!
a ne VAOBSHTE 4e ne MOJE s drugo neshto, po-goliam razmer!!!!
Pak ste prevejdali angliiskia s BULTRA...
A maximum file size si e do 4 gb, no ne vijdam problem, zashtoto vis4ki programi potdarjat split na filetata nad opredelen razmer!
Prosto triabva da se 4ete vnimatelno v deskriptiona na programite, bilo za capture, bilo za rip!
http://www.bpeme.to/~drrossft/gif/lg.gif
To i az imam problem nikade ne moga da otcriq drivers za moq tv tuner v saita na proizvoditelq nqma i duma koqto da se spomenava za toq model prekaleno e star "Typhoon Silver Crest BT7xx" Ne pomnq ve4e to4no koi (TV tuner Radio Teletext Distancionno). Ina4e tiq problemi s fata otdovna sa qsni samo deto kato si ka4i6 DIVX codec ot v.5.xx nagore i ve4e ne moje6 da izpolzva6 Capture zashtoto v momenta v koito otide6 na meniuto za opredelqne na video komresiqta i zabiva kompiutara ina4e tova e edinstvenoto re6enie da zapisva6 bez da formatira6 dqla prosto zapisva6 direktno v DIVX i nqma griji e vqrno 4e pri savsem malko po niska rezoliuciq otkolkoto necompresirano.
1. DeadAirPlain: Otnosno driverite, ima redica universalni driveri, probvai s tjah.
2. A za da compresiram videoto v realno vreme s DivX 5.xx, tova ozna4ava compa da compresira s 24 fps, koeto e dosta dale4 ot vyzmozhnostite na procesor4eto mi.
3. d-rRoss: Kato zapisvam film ili nesto drugo ot televizijata ne moga da spra, 4e posle na novo da go pusna da zapisva i t.n. Edno, 4e ste iztyrva njakolo secundi i vtoro, 4e go naglasjam da zapisva ot- do opredelen 4as, ponezhe iskam da si zapi6a nesto kato me njama.
Dr-e tova sum go copy/paste direktno ot help-a na XP... (az ne gi izmisljam tija neshta)
az lichno rabotja samo pod NTFS i ne sum imal problemi.
I tova za razmera na disk-a ne e ot znachenie.. problema si e vuv file-vete.. i to e fakt, i tochno konkretnata mu programa javno ne podurja spliting...
Inache i az sum si formatilal 40G disk na Fat32.. daje s format c: i ne sum zabeljazal problemi ma na...
Ami da de, tova iskah da kaja, 4e na Windows Xp disk managementa ne mu e silnata strana, sorry 4e malko grubi4ko se izrazih :)
Hi bi li mi kazal koi sa i ot kade da gi izteglq i o6te ne6to ima li na4in da si 6erna televizor4eto v lokalnata mreja?
i o6te ne6to ne sam kazval 4e go kompresiram v DIVX5.xx a prosto 4e kato go instaliram nqmam dostap do meniuto otkadeto moje6 da opredeli6 codeca za6toto zabiva televizor4eto sledovatelno ili 6te imam capture ili nqma da moga da GLEDAM filmi koito iskat DIVX5.xx tova e prosto zabiva predi da stigne6 do codeca ina4e s DIVX 4.00 nomera stava no ako iska6 da ne se4e trqbva mnogo da namali6 rezoliuciqta i da uveli4i6 bitrate koeto e bezsmisleno no s 3.11 se polu4avat dobri rezultati.
Vizh na http://asvzzz.narod.ru/ systo taka i programata im e mnogo jaka
<font color=yellow><font face='Arial'>
Под Windows 98 SE съм записвал с Video Capture директно в MPEG2 с компресия 1:25 и файла ставаше 10 GB и повече и нямаше проблеми. После го пусках да се енкодва в MPEG4 и след 2 часа готово сд-то с филма.
</font id='Arial'></font id=yellow>
Fuck them ...and their law!
