Problem s WinXP SP1 Final i StyleXP
Sled kato si slojix Service Pack 1 na XP-to, StyleXP-to sprq da fynkcionira. Preinstalirax go i pri startiraneto my mi izliza slednoto ne6to:
"StyleXP cannot be enabled on this system"
"StyleXP works on the following builds of XP:
-2600
-3541
-3590
-2505"
Mnogo stranno pri polojenie 4e moito XP e build 2600 !!!!!!!
Probvax StyleXP versiite: 0.70, 0.80 i 1.0 - i pak su6tata istoriq.
Ako nqkoi ima su6tiq problem ili znae ot kakvo se poly4ava taka da pi6e.
10x za vnimanieto
reshenieto e da izchakash da izlezne nowa versia na StyleXP iavno ima nesawmestimot s SP1 za WinXP
Bat Rambo - poslednata versiq e 1.01 - specialno za service paka, dai mail i ste ti q pratq zaedno s keygen.
http://free.data.bg/kayso/MKIV-Blitz-005.jpg
A za kvo li si slagash SP-a?
Gledah infoto - ta v nego ima neshta samo za otchitane na deinost - i za sgadvane na jivota na "nelitsenziranite" kopia :)
Ako go biaha zabavili malko - i da slojeha DX9 - makar che az pak stiah da ia svalia otdelno...
ASUS A7V333;AthlonXP1600+ as 2000+ (10x166MHz,1.67GHz,1.75V);2x128MB DDR400 Kingmax CL2 on 2/2/2/5/2CMD;Joytech ApolloGeForce4 Ti4200 300/500MHz;40GB IBM 120GXP 1x7200rpm;C-Media 8738 on board ;EVERCOOL ND15 cooler + 2xFan on case (45*Cmax)
