E 4e ko iskash :)))) Da si go svalish i aktivirash bezplatno ot MS i 1 godinka da si imash free server suvsem zakonno... de davat taka sireneto :))
.. Crack [:)]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Flex
oh 4e ste mi sladki... ne znam koi e vijdal .NET i koi ne oba4e tuka go obqsnqvam za 4-ti put nqkude a po drugi forumi za 20-ti.
1. Ot services se puska windows audio i se slaga na automatic
2. ot display properties->settings->advanced->troubleshoot dava accelerationa na max
3. ot dxdiag na display se puskat accelerationite i veki si4ko e nared :)
FLEX zashto sa nujni 3 slojni proceduri kogato samo s edna reshavash problema pri instalacijata na directx 9.0 se puska avtomatichno i audioto i acceleracijata za 3D kakto i se opravjat dosadni bugove s njakoi 3D igri primerno never winter nights ?
Абе хора като сте се разпалили да си говорите по тая тема, аз също имам въпрос относно win2003net...
Имате ли някакъв крак за него ако не поне ръка :))
за rc2 :)
pri polojenie 4e MS davat bezplatno da go izpolzvash za 1G to ne sa mnogo entusiastite da pishat crack... :)
Ami na men mi dava 14 days left, moje bi ot cd-keya ili ne znam ?
Alexandro - princip, purvo 4e DX9 final e otskoro na pazara, vtoro e hubavo naroda da razbere koe kude e :)
Za RC2 i activationa mu - ei ot tuka: http://www.microsoft.com/windows.net...w/default.mspx se registrirash iz4akvash (mnogo) da ti dadat kliu4, smenqsh si toq s koito si v momenta i si aktivirash windowsa za 1 year
eto i cracka
Microsoft NT Server 2003 download link
This download link is coming from Microsoft
Microsoft NT Server 2003 Beta
http://download.microsoft.com/downl...ExchTiBeta2.exe
184 MB
When you open it up it will be 414 mb.
Burn to CD
Your going to need both cracks. First one removes the time bomb 14 day trial time.
http://berdt.net/mirrored/tweaknt-winbeta/TweakNT.exe
This one kills the actavition
http://berdt.net/mirrored/reset5setup.exe
TweakNT is a utility that allows you to remove the time bomb and change the edition of any NT OS.
It should be fairly self-evident how to use it, if it isn’t; I would suggest you don't even try,
As you'll most likely break something.
Notes:
Time bomb is not the same as WPA, time bomb is usually present in betas, and is normally somewhere
Between 120 and 360 days.
If there is a time bomb, the build will always be shown on the desktop, consequently, removing
The time bomb will remove the build from desktop (unless you specify it to always show)
Converting can render your OS completely unusable, do not touch this unless you know what you're
Doing.
Obviously, you can't convert Windows 2000 to web server, as it doesn’t exist, these are for .net
But the basic "ntswitch" will work on all versions of NT.
All changes made by TweakNT are reversible (apart from restoring the time bomb), though in some cases
You may not be able to get to a point where you can run TweakNT to reverse the changes, if this happens
You will need to restore the backup of the registry created by TweakNT. You will be told the location
Of this file after the backup is created.
От де да го взема този NET
Някой беше вече писал ама не мога да го намеря :(
Klamer ами в free.evro.net го има и в free.techno-link.com също го има вече и на други места може да се е появил. :))
Към Flex: По въпроса с "memory leak" при Windows.NET 2003 Server RC2.
Не съм забелязал подобен проблем а съм го инсталирал на две машини едната от които е дву-процесорна и не са гасени от седмици, нещо повече: за капак и двата са пуснати като Terminal Server (Application Mode) и са ангажирани с поне десет Remote Clients средно по 10 часа в денонощието.
Пичове мойят е Windows Server 2003 Enterprice Edition ver. 5.2.3765 дали е бета?Шото никъде не пише да е бета.А и като качих детонатора 43.00 що не ми дава менюто за до-настройки на NVidia че без тях не мога да си пусна картина на ТВ-то. Каде да барна за да го оправя?
А и да го похваля нета ми върви с около 50% по-бързо особено явно това пролича като пуснах Diablo II ми пинга не съм го виждал толко нисък само 350 и то през Dial-up от Интернет България (които според мен имат най-скапания нет) просто е върха.
ЕВАЛА МАЙКРОСОФТ :)))
King mooje, tova si e beti4ka, moje da se durji kakto si iska na razli4nite mashini :)
Gazara, vij page 1 mai tam bqh pisal neshto...
