problem s SP1 WinXP Home Edition
  imam windows XP Home Edition
iskam da mu sloja Service Pack 1
dava nqkakva greshka tochno sled vuprosa za arhiviraneto na starite failove.
da ne bi da ima SP za professional i za Home edition?
ili pak trqbva da se smenq kliucha
shtoto i tova muchih ama ne mi stavat kliuchovete
nqkoi ako ima cd-key-ta za home edition
kajete kakvo da pravim :)
  Smukni si crack za activation i sled tova updatvai SP packa a i kaji kolko ti e golqm ili ti go durpash ot internet direktno
  1. Run a system resore to create a new checkpoint in case you need it.
2. Run regedit and go to:
HKEY_LOCAL_MACHINE/Software/Microsoft/WindowsNT/Current Version/WPAEvents, on the right double click on "oobetimer" and change at least one digit of this value to deactivate windows.
3. Choose run from start menu and type in this command:
%systemroot%/system32/oobe/msoobe.exe /a to get the activation screen and go to the second option which is activate by phone.
4. In the new screen choose the option to change product key, and type in the new product key (your Corporate one only).
4a. If it brings you back to the prior screen after entering the new key click remind me later and then reboot.
5. Close that window, reboot your system and enter the command in step 2 for the second time to verify your activation , you should see "windows is already activated".
6. 1 Now install SP1.
7. If you have done this wrong or without a valid key you will not be able to boot. hit F8 and select last known good configuration.
22DVC-GWQW7-7G228-D72Y7 -QK8Q3
USPEH
