Как мога да върна лаптоп Sony-PCG-6121m към първоначалната фабрична инсталация.
Дайте съвет как мога да върна лаптоп Sony-PCG-6121m с Windows 7 към първоначалната фабрична инсталация.
Инсталационно DVD няма. Вероятно има системен дял от който се преинсталира. Не знам и как да изпиша в търсачката на Google та да намеря някаква помощ.
Отговор: Как мога да върна лаптоп Sony-PCG-6121m към първоначалната фабрична инсталация.
Click start, all programs, system recovery
1. Connect the PC to the AC power adapter. (Make sure you on AC Power when doing this and not battery)
2. Close all programs.
3. Click Start , click All Programs , select System Recovery , and click PC Recovery .
4. When the recovery options are presented, select the option to perform the PC Recovery and click Next .
5. The PC will restart.
6. When the Welcome to PC Recovery message displays, click OK to continue.
7. On the System Recovery panel, select System Recovery . By default, the system will perform a complete reformat and will destroy all user data.
8. Restart the PC when prompted.
As an alternate method to the steps above, click Advanced Options , and select the Destructive Recovery option, and click Next to begin the reformatting process.
The PC is in the original factory condition and all system data, such as location and date must be reconfigured.
Note: This shouldn't take long, when I did it for my sister it was not more then an hour.
Now after you have restore the laptop back to factory defaults, you should still be able to create the recovery cd/dvd if you so wish. If you do here are the steps to do that.
1. Again make sure the laptop is plugged into the AC
2. Click Start , click All Programs , select System Recovery , and click Create Recovery Disks .
The PC Recovery Disk Creator utility displays a message indicating the type and number of media disks required.
3. Verify the required number of media disks are available.
4. Click Next to begin the actual copying process.
Remove written disk and insert additional disks when prompted.
5. Label each disk, in sequence it was created, as prompted.
6. Store the newly created set of recovery disks in a safe place.
This process should only take 1hr-2 1/2 hrs
Note: This process can only be done once. If the cds are ever lost or damaged. The manufacture would have to be called for recovery disc replacements.
Да не подтискам хората, че знам как да питам гуугъл :)
Това System Recovery го няма :(
Виж пак във всички програми,трябва да имаш подменю ПОДДРЪЖКА,там има рекавъри,поне при мен е така.
Windows e на италиански и System Recovery е ----> ripristino di sistema :)
Пуснахме го и тръгна но след 85% някъде екрана става черен и така стои
Би трябвало да има vaio recovery center.Аз винаги оттам го правя и не съм имал проблеми.И вие какво направихте след като стои на 85%?
Стои дълго време с черен екран и го изключиха бутона за пускане
- - - Обновено - - -
Готово успяхме да оправим проблема. Всичко мина ОК.
Благодаря на отзовалите се
Забелязал съм, че Sony правят всичко сложно без никаква причина. Например, ако решиш да влезнеш в bios-а и си изпочупиш пръстите от почукване на Del, рестарт F-хх плюс комбинация от клавиши изведнъж поглеждаш бутона Аsist. Да имаш пряк бутон за достъп до bios-а над клавиатурата е тъпо. Обикновено след настройката на bios-a работа с него нямаш с месеци.
