ПРОБЛЕМЪТ "BAD_POOL_CALLER"
  АКО НЯКОЙ ЗНАЕ РАЗРЕШЕНИЕ НА ТОЗИ ПРОБЛЕМ ЧАКАМ ОТГОВОР:
<font color="yellow">A problem has been detected and Windows has been shut down to prevent damage to your computer.
BAD_POOL_CALLER
If this is the first time you`ve seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as cashing or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced startup options, and then select Safe Mode.
Technical information:
*** STOP: 0x000000C2 (0x00000007, 0x00000CD4, 0x00000000, 0x81FECA18)</font id="yellow">
  <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">АКО НЯКОЙ ЗНАЕ РАЗРЕШЕНИЕ НА ТОЗИ ПРОБЛЕМ ЧАКАМ ОТГОВОР:
BAD_POOL_CALLER
</font id="yellow">
 <div align="right">Originally posted by illuminator*-*30/01/2004*:* 09:28:42</div id="right">
Не си писал за кой уиндоус но все пак виж линка по-долу:
 http://support.microsoft.com/search/...&srchExtraQry=
 http://support.microsoft.com/default...b;en-us;314492
  За превъзходния ХР става въпрос
