колеги това лг rgb ли е?как да разбера?
LG 49UH664V - Технoмаркет - онлайн магазин
Да. Моделите с WRGB структура на матрицата са с орязана резолюция и не са подходящи за монитор при работа с компютър.
Иначе като телевизор трудно ще видиш разликата.
Виж 4-та колонка в таблицата - оцветено с червено. От UH750 надолу.
LG Oled UHD TV 2016 - european models Product Certification_____________
UHD
Premium Dolby Vision_______
HDR 10
_________________
Videopanel_____________________________
Type LCD matrix,
Bits of color,
Operating frequency of T-Con board of the panel,
Curvature,
Index,
Anti-reflective filter Backlight________________________
Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
Black Frame Insertion
Pulsе Wide Modulation Color Space________________________
DCI P3 - %
Rec.2020 - % Contrast________________________
White & Black level
ANSI
With local dimming
Without local dimmingViewing angle
_____________ Input Lag___________________________________
SoC_____________
CPU
GPU
software
OS
Conectors_____________________ Networks_______________________
Tuner________________
Audio______________
Opportunities for______________________________________
calibrationProduct G6V
77", 65"Yes Dynamic optimization scenes via Dolby Vision technology VS10 77" - In HDR max 744cd/m2
65" - In HDR max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
77" - LC770LQD-LGxx, WRGB, 10-bit
65" - LC650LQD-LGxx, WRGB, 10-bit
Passive 3D
MCI - Motion Clarity Indec - 1000
(MCFI - Motion Clarity Frame Interpolation)
Triple anti-reflective coatingNo
No
77"DCI P3 - 95 % / Rec.2020 - 80%
65"DCI P3 - 94.14% / rec.202075" -
65" - ∞ / 150cd/m2 / 0.00cd/m2
290cd/m2 in ISF Dark mode
77" - °(cone)
65" - °(cone)77"- Game mode 34.0ms / by default
65"- Game mode 33.6ms /Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA4 x HDMI2.0a (ARC,CEC,MHL)
1 x Satelite in(Main:F-type,female)
1 x AV Composite In 3.5mm jack
1 x Component in(shared with composite)
1 x RS232C(Mini Jack)
1 x Antena (RF) (Female)
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller
Compatibility-mouse/keyboard
Bluetooth 4.0H15 64-bit
Quad Core
webOS 3.0Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2audio system
Harman / Kardon 4.2
Sound power: 60 W
Dolby Digital PlusIRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesG6V
E6V
(flat)
65", 55"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max 655cd/m2
55" - In HDR max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-LGxx, WRGB, 10-bit,
55" - LC550LQD-LFxx, WRGB, 10-bit,
Passive 3D
MCI - Motion Clarity Index
Double anti-reflective coatingNo
No65" DCI P3 xy - 94.5 %
55" DCI P3 - 96.46%65" - ∞ / 195cd/m2 / 0cd/m2
55" - ∞/-65" - °(cone)
55" - 166°(cone)65"- Game mode 34.1ms / by default 63ms
55"- Game mode 34.1ms / by default 63msLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital PlusIRE White balance - 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesE6V
C6V
(curved)
65", 55"
? Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max
55" - In 100% window HDR max peak 400cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-xxxx, WRGB, 10-bit, Curved
55" - LC550LQD-xxxx, WRGB, 10-bit, Curved
The LG OLED C6V has a new structure of sub-pixels that differs from that of the LG Signature G6V.No
No
65" DCI P3 - 9 %
55" DCI P3 - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
65" - Game mode
55" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA3 x HDMI2.0a (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Bluetooth 4.0-
Quad Core
webOS 3.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2audio system Harman / Kardon 4.0
Sound power: 40 W
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesC6V
B6V
65", 55"
(no support for 3D)
No Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max
55" - In HDR max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" DCI P3 - 9 %
55" DCI P3 - 9 %
65" -
55" -
65" -
55" -
65" - Game mode
55" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Bluetooth 4.0-
Quad Core
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Harman / Kardon 4.0
Sound power: 40 W
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesB6V
LG LCD Super UHD TV 2016 - european models Product UHD
Premium
________________Dolby
Vision
__________HDR
_________________Videopanel
___________________________________Backlight
DimmingColor Space
____________________________Contrast &
Black level
_______________Viewing Angle
____________Input Lag
_____Networks
__________________Ports
___________________SoC
Platform
Software
OS
_____Tuner
______________Audio
______________ Opportunities for calibration_____________________Product UH980V
95"No Yes
VS1095" - In HDR max
HDR1095"- IPS, 10-bit, 120/100Hz
Quantum DotsDirect Led (W-Led)
Local Dimming95" - 95" - 95" - 95" - Game mode Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboard-
Quad Core
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shift
HEVC, VP9audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA SurroundIRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH980V
95"LG LCD UHD TV 2016 - european models Product UHD
Premium
_____Dolby
Vision
_____HDR
DimmingColor Space
Black level
_____Networks
Platform
Software
OS
_____Tuner
______________Audio
______________ Opportunities for calibration____________________Product UH955V
86"
Differences in the design of the following model has a black edging UH955V screen, behind the TV also black, UH950V model has a white screen edging with round edges and a white back of the TV.
No Yes
VS1086" - In HDR max
HDR1086" - AS-IPS, 10-bit, 120/100Hz + BLS
LC860EQD-FJF1
Quantum Dots
PMI (Picture Mastering Index) 2700
Motion Interpolation (TruMotion)
True Black Panel86" - Edge Led (W-Led)
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz86"- DCI P3 - /Rec.2020 -
Color Prime P86" -
86" - °(cone)
86" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
WebOS 3.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
Gamma - 10 points
CMS -
ISFccc -UH955V
86"UH950V
65", 55"
No Yes
VS1065" - In HDR max
55" - In HDR max
HDR1065" - AS-IPS, 10-bit, 120/100Hz + BLS
LC650EQF-YJF1
55" - AS-IPS, 10-bit, 120/100Hz + BLS
LC550EQH-YJF1
Quantum Dots
True Black Panel Plus65" - Edge Led (W-Led)
55" - Edge Led (W-Led)
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz65" - DCI P3
55" - DCI P3
Color Prime P65" -
55" -
65" - °(cone)
55" - °(cone)
65" - Game mode
55" - game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
Gamma - 10 points
CMS -
ISFccc -UH950V
65", 55"UH855V
75"No Yes
VS1075" - In HDR max
HDR10
75"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC750EQF-FJF1
Quantum Dots
Clear Plus - Flashing backlight (BFI)
True Black Panel75" - Edge Led
65" - Edge Led below(W-Led)
60" - Edge Led below(W-Led)
55" - Edge Led below(W-Led)
49" - Edge Led below
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz75" -
65" -
60" -
55"- DCI P3 - 85% /Rec.2020 - 62%
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
ANSI 1188:1 / 99.8cd/m2 / 0.084cd/m275" - °(cone)
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
M16+F16
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCaudio system
Harman / Kardon 4.2
Sound power: 60 W
Dolby Digital Plus
Gamma - 10 points
CMS -
ISFccc -UH855V
75"UH850V
8507
65", 60", 55", 49"No Yes
VS1065" - In HDR max 315cd/m2
60" - In HDR max
55" - In HDR max 360cd/m2
49" - In HDR max cd/m2
HDR10
65"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC650EQF-DJF1
60"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC600EQF-DJF1
55"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC550EQH-DJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
65" -
60" -
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
M16+F16
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCaudio system
Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
Gamma - 10 points
CMS -
ISFccc -UH850V
65", 60", 55", 49"UH780V
770/7707
75", 65", 60", 55", 49"No Yes
65" - In HDR max
60" - In HDR max
55" - In HDR max 341cd/m2
49" - In HDR max
43" - in HDR max
HDR10
75"- AS-IPS, 120/100Hz + BLS
65"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
60"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
55"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
49"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
43"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
Quantum Dots
PMI (Picture Mastering Index) 2500
Motion Interpolatiom (TruMotion)
Clear Plus - Flashing backlight (BFI)75" -
65" - Edge Led below (W-Led)
60" - Edge Led below (W-Led)
55" - Edge Led below (W-Led)
Vertical Dimming
55" - 6 zones
65" - DCI P3 -
60" - DCI P3 -
55" - DCI P3 - 77.6% /Rec.2020 - 58%
49" - DCI P3 -
Color Prime P75" -
65" -
60" -
55"- native - 920:1 /
ANSI 1153:1 / 101.5cd/m2 / 0.088cd/m275" - ° (cone)
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode 38.1ms / by default 57ms
49" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboardK2L
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance- 20 Points
Gamma - 10 points
CMS -
ISFccc -UH770V
65", 60", 55", 49"UH750V
7507
65", 55", 49", 43"No No 65" - In HDR max
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)65"- AS-IPS, 8-bit+FRC, 60/50Hz
55"- AS-IPS, 8-bit+FRC, 60/50Hz
49"- AS-IPS, 8-bit+FRC, 60/50Hz
43"- AS-IPS, 8-bit+FRC, 60/50Hz
WRGB structure - resolution 2880x216065" - Edge Led (W-Led)
49" -
43" -
Local Dimming
PWM Freq. - 120/100Hz65" - DCI P3 - 90%/
55" - DCI P3 - 90%/
49" - DCI P3 - 90%/
43" - DCI P3 -
Color prime P65" -
55" -
49" -
43" -65" - °(cone)
55" -
49" -
43" -65" -
55" -
49" -
43" -Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCSound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH750V
65", 55", 49", 43"UH700V
7007
70"No No 70" - In HDR max
HDR PROcessing
(missing hardware for playback HDR)70"- AS-IPS, 8-bit+FRC, 120/100Hz
70" - Edge Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz70"- DCI P3 - 84%
70" - 70" - 70" - Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
Dolby Digital Plus
ULTRA SurroundUH700V
65", 55", 49", 43"UH670V
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
49" - Direct Led (W-Led)
43" - Direct Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz65"- DCI P3 - 84%
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime P65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCaudio system
Harman / Kardon 2.0
Sound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH670V
65", 55", 49", 43"UH660V
668/664/661
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
Local Dimming
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime Pro65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCaudio system
Harman/Kardon 2.0 - only in model 668
Sound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH660V
65", 55", 49", 43"UH650V
6507
65", 60", 55", 49", 43"No No 65" - LC
60" -
55" -
49" -
43" -
HDR PROcessing
Convert SDR to HDR
60"- AS-IPS, 8-bit+FRC, 60/50Hz
60" - Edge Led (W-Led)
60" - DCI P3 -
55" - DCI P3 - 84%
49" - DCI P3 - 84%
43" - DCI P3 -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
Bluetooth3 x НDМІ2.0 (ARC,CEC,MHL)
Соmроnеnt іn 1 (ѕhаrеd wіth соmроѕіtе)
1 x RЅ232С (Міnі Јасk)
USB 2.0 x 2
1 x Antena (RF)
1 x CI+ 1.3-
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
Dolby Digital Plus
ULTRA SurroundUH650V
65", 60", 55", 49", 43"UH635V
58", 50",
UH630V
40"
No No 58" -
50" -
40" -
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)58"- MVA ?, 8-bit, 60/50Hz
50"- MVA ?, 8-bit, 60/50Hz
40"- MVA ?, 8-bit, 60/50Hz
58" - Edge Led (W-Led)
50" - Edge Led (W-Led)
40" - Edge Led (W-Led)
PWM Freq. -58" - DCI P3 - 90%
50" - DCI P3 - 90%
40" - DCI P3 -
Color Prime Plus58" -
50" -
40" -58" -
50" -
40" -58" -
50" -
40" -Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
1 x Соmроnеnt іn(ѕhаrеd wіth соmроѕіtе)
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
Sound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH630V
58", 50", 40"
UH620V
6257/6207
60" -
55" -
49" -
43" -
HDR PROcessing
(missing hardware for playback HDR)65"- S-IPS, 8-bit, 60/50Hz
60"- S-IPS, 8-bit, 60/50Hz
55"- S-IPS, 8-bit, 60/50Hz
49"- S-IPS, 8-bit, 60/50Hz
43"- S-IPS, 8-bit, 60/50Hz
WRGB structure - resolution 2880x216060" - Edge Led (W-Led)
Local Dimming
PWM Freq. -65" - DCI P3
55" - DCI P3
49" - DCI P3
43" - DCI P3 -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi (only 802.11 n)
WiDi / Miracast
WiFi Direct
DLNAHDMI x (HDCP2.2)
1- ARC,
1 - Compatible 4K@60p and HDR 422
1 x USB 2.0-
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
Sound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH620V
65", 60", 55", 49", 43"UH610V
6157/6107
55" -
49" -
43" -
HDR PROcessing
49" -
43" -
PWM Freq. -65" - DCI P3 -
55" -
49" -
43" -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi (only 802.11.n)
WiDi / Miracast
DLNA3 x НDМІ2.0 (ARC,CEC,MHL)
RЅ232С (Міnі Јасk)
2 x USB 2.0-
Analog (PAL,SECAM)
PVR
HEVC
Sound power: 20 W
Dolby Digital Plus
ULTRA SurroundUH610V
65", 55", 49", 49", 43"UH600V
No No No 65" - S-IPS, 8-bit, 60/50Hz
60" - S-IPS, 8-bit, 60/50Hz
55" - S-IPS, 8-bit, 60/50Hz
49" - S-IPS, 8-bit, 60/50Hz
43" - S-IPS, 8-bit, 60/50Hz
True Black Panel65" - Edge Led (W-Led)
60" - Edge Led
49" - Edge Led (W-Led)
PWM Freq. -65" -
60" -
55" -
49" -
43" -
65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
WiDi / Miracast
DLNA
Bluetooth (only 49-65")3 x НDМІ2.0 (ARC,CEC,MHL)
1 x Соmроnеnt іn (ѕhаrеd wіth соmроѕіtе)
1 x USB 2.0-
WebOS 2.0
DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR
HEVC - only 49-65"
Sound power: 20 W
Dolby Digital Plus
Virtual Surround MoreUH600V
65", 60", 55", 49"LG FHD & HDReady TV 2016 - european models Product UHD
Premium
_____Dolby
Vision
__________HDR
______________________Videopanel
___________________
DimmingColor Space
Black level
_____________Input Lag
_____Networks
___________________________SoC
Platform
Software
OS
_________Tuner
_______________Audio
_______________ Opportunities for calibration_____________________Product LH660
55", 49", 43"No No No 55" - IPS, 8-bit, 120/100Hz
49" - IPS, 8-bit, 120/100Hz
43" - IPS, 8-bit, 120/100Hz
49" -
PWM Freq. -55" -
49" -
43" -
55" -
49" -
43" -55" -
49" -
43" -55" -
49" -
43" -Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH660
55", 49", 43",LH640
6407
55", 49", 43"No No No 55" - IPS, 8-bit, ? Hz
49" - IPS, 8-bit,
43" - IPS, 8-bit,
PWM Freq. -55" -
49" -
43" -
55" -
49" -
43" -
55" -
49" -
43" -
55" -
49" -
43" -Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH640
55", 49", 43"LH600
609/604/6047
55", 49", 43", 32"No No No 55" - IPS, 8-bit, 60/50Hz
49" - IPS, 8-bit, 60/50Hz
43" - IPS, 8-bit, 60/50Hz
32" - IPS, 8-bit, 60/50Hz
32" - Direct Led (W-Led)
PWM Freq. -55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH600
55", 49", 43", 32"LH590/595
49", 43", 32"No No No 49" - IPS, 8-bit, 60/50Hz
43" - MVA, 8-bit, 60/50Hz
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
LH590
49", 43", 32"LH570
32" - IPS, 8-bit, 60/50Hz49" -
43" -
-Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB-T/T2/C/S/S2
Analog (PAL,SECAM)Sound power:
43" - 10 W
32" - 6 W
Dolby Digital Plus
Virtual Surround MoreLH570
49", 43", 32"LH560
43"No No No 43" - IPS, 8-bit, 60/50Hz
43" -
- Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
WebOS 2.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
LH560 LH540
541/545
32" - IPS, 8-bit, 60/50Hz55" - Edge Led (W-Led)
43" - Edge Led (W-Led)- x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB-T/T2/C/S/S2
Analog (PAL,SECAM)
HEVC - 2K/60pSound power: 10 W
Dolby Digital PlusLH540
49", 43", 32"LH530
49" , 43"
43" - IPS, 8-bit, 60/50Hz49" - Direct Led (W-Led)
43" -- 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
HEVC - 2K/60p
PVRLH530 LH510
513/519/5100
49", 43" - 1920x1080
32" - 1366x768
32" - IPS, 8-bit, 60/50hz49"- Direct Led (W-Led)
43"- Direct Led (W-Led)
32"- Direct Led (W-Led)- 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB-T/C
Analog (PAL,SECAM)
(43, 49" + T2/S2)Sound power: 6 W
Dolby Digital Plus
Virtual SurroundLH510 LH500
43" - 1920x1080
32" - 1366x768No No No 43" - IPS, 8-bit, 60/50Hz
32" - IPS, 8-bit, 60/50Hz43"- Direct Led (W-Led)
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB- T2/C
HEVC - 2K/60pSound power: 6 W
Dolby Digital Plus
Virtual SurroundLH500
Този пост е редактиран от hristoslav2; 07-08-16 в 11:34.
G6
Обзор LG Signature OLED65G6V: ультратонкий OLED телевизор
LG OLED65G6P HDR OLED TV Review
LG Signature OLED65G6V : Test complet - Les Numériques
https://tweakers.net/reviews/4651/g6...-topmodel.html
La prova del nuovo OLED Signature G6: il TV gioiello firmato LG | DDay.it
E6
https://www.avforums.com/review/lg-c...v-review.12713
LG OLED65E6V 4K HDR TV Review
LG OLED55E6 (E6) 4K HDR OLED TV Review
LG 55E6V (E6) UHD HDR OLED TV – recenzija – HD Televizija – HDTV eZine
LG E6 review - FlatpanelsHD
Test: LG OLED65E6V - fwd - FWD Magazine
C6
LG OLED55C6V : Test complet - Les Numériques
คุณภาพจัดเต็ม รีวิว OLED55C6T รองรับทั้ง HDR10 และ Dolby Vision | LCDTVTHAILAND
B6
LG OLED 65B6J Test - młodszy brat OLED'a E6 - OLED - HDTV Centrum Polska
LG 55B6J (B6) UHD HDR OLED TV – recenzija – HD Televizija – HDTV eZine
LG B6 Review (OLED55B6P, OLED65B6P)
LG Oled UHD TV 2016 - european models Series
Model
________________ Certification UHD________
Premium
(1) Dolby Vision_______
(2) HDR 10________________
In Windows
2/5/10/20/100% Videopanel_______________________
Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
Pulsе Wide Modulation Measurement_______________________________
(out of the Box & after calibration)
DCI P3 / Rec.2020 / Delta E / Gamma / Temperature Contrast________________________
White & Black level
ANSI
With local dimming
Without local dimming Viewing angle
___________( ° cone) Motion resolution
_________________________ Product_____________ Input Lag_____________
Game mode
by default Audio____________________________ Operating Sistem_____________________
Board
System on Chip
Central Processing Unit
Graphic Processor Unit
RAM
Software
Conectors__________________________________ Tuners________________ Media Player__________________ Opportunities for_________________________
calibration Note_________________________________________________________________________
Pros & ConsProduct G6V
(flat)
77", 65"
3D passive interlaced circular polarization with FPR technologyYes Dynamic optimization scenes via Dolby Vision technology VS10 77" - max 744cd/m2
65" - max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
MCI - Motion Clarity Index - 1000
The new pixel structure of the OLED-panel TVs LG OLED65G6V applied. Compared to the previous generation of 4 identical sub-pixels (red, green, blue and white), in the new panels the red subpixel has become a little less, and the blue and white is slightly increased. It was thus able to increase the peak brightness of the new OLED-screen.No
No
77" -
65" - 94.14% / x-x /4.5-1.6 / 2.21-2.2 / 6225-6517K75" - 1000000:1 /
65" - 1000000:1 / 150cd/m2 / 0.00cd/m2
77" - °(cone)
65" - °(cone)77" - 600-650[with TruMotion], 300 without
65" - 600-650[with TruMotion], 300 withoutG6V
77", 65"77" - 34.0ms /
65" - 33.6ms /audio system Harman / Kardon 4.2
Total sound power: 60 W
Four speakers
2 built-in subwoofer: 20W
Dolby Digital Plus
DTS
DTS-HD
Not surprisingly, the sound is very good for a TV. The LG 65G6V comes down low enough in the spectrum since the low mids from 100 Hz are audible. The sound reproduction is excellent between 180 and 1500 Hz. However, we noted an effect of sibilance very disturbing in the treble, which prompted us to reduce the frequency of 10 kHz via the equalizer. Once this small adjustment, the ear is less abused and it is possible to listen to some music on the TV. The large size of the foot could have enabled LG to go one step further with a woofer bigger and a vent that is found on the system sound bars . Finally, the distortion is limited 0.9%.webOS 3.0
CPU - H15, 64-bit, Quad Core
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller - Compatibility-mouse/keyboard
1 x R232
Bluetooth 4.0 - audio device (headset or speaker).Dual tuners
DVB -T/ T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2It supports codecs and containers
Video : VC-1, XviD, H.264/AVC, MJpeg, MPEG1/2/4, HEVC, VP8, VP9, RV30/40
Audio : WMA, MPEG1 Layer I/II/III (MP3), Dolby Digital, Dolby Digital Plus, PCM, LPCM, DVDLPCM, ADPCM, DTS, AAC, HE-AAC AAC LC, AMR-NB et AMR-WB
However, the ISO images of DVD / Blu-ray and native files are not yet supported.IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes (ISF Day & ISF Night)
Interestingly, if you choose the “Copy to all inputs” function, the on-screen text makes reference to an LCD Backlight, when it is of course discussing the the [OLED Light] control. Irritatingly, this only copies the basic picture settings. While the 20-point Grayscale/White Balance controls have their own “copy to all” function, the adjustments for the three-axis Color Management system have no such equivalent and have to be manually copied to all of the inputs. That’s six colors with three adjustments each, and 3-4 HDMI inputs plus internal Smart TV features to apply the settings to, which is sure to make calibrators groan.Pros:
- + Unique ultra-slim design «OLED on glass"
- + 10-bit, the OLED panel that supports HDR and Dolby Vision
- + High quality Ultra HD images
- + Excellent scaling Full HD images up to 4K
- + Powerful built-in speakers OLED Surround
- + Picture Perfect (color temperature and gamma).
- + Almost infinite contrast.
- + Excellent 3D rendering.
- + wide viewing angles.
- + Responsiveness of the panel.
- + WebOS 3.0 interface always as responsive and pleasant.
Minuses:
- - The high price at the start of sales
- - The absence of mass HDR-content
- - imposing foot.
- - audio rendering by default.
Remote control not backlit
G6V
E6V
(flat)
65", 55"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 65" - max 655cd/m2
55" - max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
No65" - 94.5 %
55" - 96.46%65" - ∞ / 195cd/m2 / 0cd/m2
55" - 166°(cone)E6V
(flat)
65", 55"65"- 34.1ms / 63ms
55"- 34.1ms / 63msaudio system Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
DTS
DTS-HDwebOS 3.0
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller compatibility-mouse/keyboard
1 x R232
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance - 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
C6V
(curved)
65", 55"
? Dynamic optimization scenes via Dolby Vision technology VS10 65" - max
55" - 100% max peak 400cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
65" - 9 %
55" - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
C6V
(curved)
65", 55"
65" -
55" -
Sound power: 40 W
Dolby Digital PluswebOS 3.0
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device(headset or speaker).DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
B6V
65", 55"
(no support for 3D)
No Dynamic optimization scenes via Dolby Vision technology VS10 65" - max
55" - max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" - 9 %
55" - 9 %
65" -
55" -
65" -
55" -
B6V
65", 55"
(no support for 3D)65" -
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device (headset or speaker).DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Series
Model
Premium
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
(out of the Box & after Calibration)
DCI P3 / Rec.2020 / Delta E Contrast________________________
White & Black level
ANSI
With local dimming
Audio____________________ SoC____________________
CPU
GPU
Software
OS Networks____________
Conectors______________________ Tuners______________ Media Player______________ Opportunities for_________________________
Pros & ContProduct
Този пост е редактиран от hristoslav2; 14-08-16 в 16:19.
Интересен способ за ремонт на Main board
LG LCD TV 42DL550 Fix | ZEDIC.COM
Но докато работят поне част от HDMI портовете не се занимавайте с такъв ремонт.
Понеже бях писал, че ще напиша като има развитие по проблема с изгорелите пиксели... Не съм очаквал толкова нагло и циганско развитие..Нашата поддръжка бе със супер отношение, хвала! Дойде човек от официалния сервиз на LG - любезен, коментирахме надълго и нашироко, две независими страни коментираха, че е недопустимо такъв модел ТВ да има пробллеми, щели да поръчат нов панел, ако не се намери друга бройка за подмяна. До тук супер!
Днес обаче ми се обаждат от сервиза и ми сервират следното безумие - "LG отказва ремонта, оплакването е невалидно, понеже тв-то не е било включено към устройство/плеър LG, официално поддържано от модела..."
Явно и тук е така като при аудио техниката, колкото повече пари хвърлиш, толкова повече те е*ат в г*за и се гаврят с теб...
Мисля да си търся правата.
Това е абсурдно искане и изнудване от тяхна страна. Сигурно искат кабелната ти да е на LG, мултиплекса за ефирната също да е на LG, както и компютъра, камерата...
Пробва ли с рекламация при търговеца ? Прочети внимателно инструкцията и гаранционната карта дали някъде в тях има написано подобно нещо.
Отговори им(на сервиза и на LG), че ще си търсиш правата, чрез КЗП и съда.
Задължително отиди и поискай отговора им в писмен вид за пред съда.
Правото ми на рекламация | pravatami.bg
Пусни жалба до КЗП и изчакай отговор
https://kzp.bg/podavane-na-zhalba
Към онези желаещи да си закупят Олед телевизор на LG:
Отложете покупката си до окончателно решение на горният спор, понеже има вероятност да се сблъскате с подобен проблем и да ви сервират същият номер.
Изчакайте да видим окончателният отговор на компанията относно политиката им за изгорелите пиксели.
Този пост е редактиран от hristoslav2; 23-08-16 в 17:42.
Бе аз преди бях писал, че тия са като комунисти на разпит и отричат до край производствени проблеми, ама те ще излязат още по-големи измекяри ... Правилното в такъв случай при негативно развитие е широко отразяване на случая и бойкот на продуктите на фирмата , та белким им дойде акъла в главата !
Някой знае ли какво точно означава Индекс на обработване на изображението((Picture Mastering Index)? Защото аз стигнах до извода,че това е някакъв субективен показател с който LG ,рейтват телевизорите си.
Правилно си разбрал с този маркетингов индекс искат уж да покажат, качеството на изображение в даденият модел. Индексът няма нищо общо с честотата на опресняване на картината в панела - Hz -овете. Маркетолозите си ги пишат както им уйдисва...
Picture Mastering Index - замества използваните преди това за показване за флуидността други LG индекси: Motion Clearity Index и Ultra Clarity Index (MCI и UCI) . Логично е да се мисли, че, стойността на Picture Mastering Index отчита различни критерии за рязкостта на изображението в движение.
http://en.tab-tv.com/?p=12236
https://www.entain.de/wiki/lg-pictur...-pmi-a466.html
::: LG Developer | Hardware Specification :::
::: LG Developer | Media Format Supported by webOS Signage 3.0 :::
Model
Premium
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
Game mode
by default Audio____________________________ Operating Sistem__________________________
Board
System on Chip
RAM
Software
(flat)
77", 65"
65" - max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
No
77" -
77" - °(cone)
Four speakers
Dolby Digital Plus
DTS
DTS-HD
Not surprisingly, the sound is very good for a TV. The LG 65G6V comes down low enough in the spectrum since the low mids from 100 Hz are audible. The sound reproduction is excellent between 180 and 1500 Hz. However, we noted an effect of sibilance very disturbing in the treble, which prompted us to reduce the frequency of 10 kHz via the equalizer. Once this small adjustment, the ear is less abused and it is possible to listen to some music on the TV. The large size of the foot could have enabled LG to go one step further with a woofer bigger and a vent that is found on the system sound bars . Finally, the distortion is limited 0.9%.Model - SM5C
Platform - webOS Signage 3.0
Chipset - M16
CPU - ARM Cortex-A53 1.0 GHz Quad Core
RAM - 2.0 GB*
Flash Memory - eMMC 5.0, 8 GB
GPU - ARM MaliT760 Quad Core (550MHz)
Graphic Resolution
App -1920 x 1080 FHD
Video - 1920 x 1080 FHD
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
DVB -T/ T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
Minuses:
- - imposing foot.
G6V
E6V
(flat)
65", 55"
55" - max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
No65" - 94.5 %
55" - 166°(cone)E6V
(flat)65", 55"65"- 34.1ms / 63ms
Sound power: 40 W
Dolby Digital Plus
DTS
DTS-HDModel - SM5C
Chipset - M16
RAM - 2.0 GB*
Graphic Resolution
Video - 1920 x 1080 FHDLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
C6V
(curved)
65", 55"
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
65" - 9 %
55" - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
C6V
(curved)
65", 55"
65" -
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
B6V
65", 55"
(no support for 3D)
55" - max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" - 9 %
55" - 9 %
65" -
55" -
65" -
55" -
B6V
65", 55"
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Series
Model
Premium
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
CPU
GPU
Software
Pros & ContProduct
Този пост е редактиран от hristoslav2; 28-08-16 в 16:38.
LG OLED65G6V 4K OLED TV Review
LG quick Booth Tour (TV section) @ IFA 2016
LG 55-inch Dual-View Flat OLED Display (55EH5C) @ IFA 2016
World's first High Frame Rate HLG on LG 4K OLED TVs 100/120 Frames
source video:[you tube - MonKeYBusiness1988]
OLED-телевизоры LG будут поддерживать все форматы HDR - 4PDA
Този пост е редактиран от hristoslav2; 05-09-16 в 21:30.
http://hdtelevizija.com/wp-content/u...eup-matrix.jpg
Service manuals
http://webos-forums.ru/topic3291.html
http://remont-aud.net/load/lcd_tv/178
Model
Premium Dolby Vision_______ Hybrid Log Gamma______
(HLG) HDR 10____________
In Windows
2/5/10/20/100% Videopanel_________________________
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
Game mode
by default Audio____________________________ Chassis__________________________
Operating Sistem
Board
System on Chip
RAM
Software
(flat)
77", 65"
3D passive interlaced circular polarization with FPR technologyYes Dynamic optimization scenes via Dolby Vision technology VS10 Yes 77" - max 744cd/m2
65" - max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
No
77" -
77" - °(cone)
Four speakers
Dolby Digital Plus
DTS
DTS-HD
Not surprisingly, the sound is very good for a TV. The LG 65G6V comes down low enough in the spectrum since the low mids from 100 Hz are audible. The sound reproduction is excellent between 180 and 1500 Hz. However, we noted an effect of sibilance very disturbing in the treble, which prompted us to reduce the frequency of 10 kHz via the equalizer. Once this small adjustment, the ear is less abused and it is possible to listen to some music on the TV. The large size of the foot could have enabled LG to go one step further with a woofer bigger and a vent that is found on the system sound bars . Finally, the distortion is limited 0.9%.Chassis -
Model - SM5C
Chipset - M16
RAM - 2.0 GB*
Graphic Resolution
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
DVB -T/ T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
Minuses:
- - imposing foot.
G6V
E6V
(flat)
65", 55"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max 655cd/m2
55" - max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
Passive 3D
No65" - 94.5 %
55" - 166°(cone)E6V
Sound power: 40 W
Dolby Digital Plus
DTS
DTS-HDChassis - EA62C
Model - SM5C
Chipset - M16
RAM - 2.0 GB*
Graphic Resolution
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
C6V
(curved)
65", 55"
? Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
65" - 9 %
55" - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
C6V
(curved)
65", 55"
65" -
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
B6V
65", 55"
(no support for 3D)
No Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max
55" - max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" - 9 %
55" - 9 %
65" -
55" -
65" -
55" -
B6V
65", 55"
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
LG LCD Super UHD TV 2016 - european models UH980V
95"No Yes
VS10Yes 95" - In HDR max
Local Dimming95" - 95" - 95" - 95" - UH980V
95"95" - Game mode audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
webOS 3.0Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboardDVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shift
HEVC, VP9IRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH980V
95"LG LCD UHD TV 2016 - european models Series
Model
Premium
Dolby Vision_______
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
CPU
GPU
Software
Pros & ConsProduct UH955V
86"
No Yes
VS10Yes 86" - In HDR max
LC860EQD-FJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
Color Prime P86" -
86" - °(cone)
UH955V
86"86" - Game mode
audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
WebOS 3.0Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH955V
86"UH950V
65", 55"
No Yes
VS10yes 65" - In HDR max
55" - In HDR max
LC650EQF-YJF1
LC550EQH-YJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
55" - DCI P3
Color Prime P65" -
55" -
65" - °(cone)
55" - °(cone)
UH950V
65", 55"65" - Game mode
55" - game mode
audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH950V
65", 55"UH855V
75"No Yes
VS10No 75" - In HDR max
HDR10
LC750EQF-FJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
65" -
60" -
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH855V
75"75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
audio system
Harman / Kardon 4.2
Sound power: 60 W
Dolby Digital Plus
ULTRA Surround-
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH855V
75"UH850V
8507
VS10No 65" - In HDR max 315cd/m2
60" - In HDR max
HDR10
LC650EQF-DJF1
LC600EQF-DJF1
LC550EQH-DJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
65" -
60" -
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH850V
65", 60", 55", 49"75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
audio system
Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
ULTRA Surround-
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH850V
770/7707
65" - In HDR max
60" - In HDR max
49" - In HDR max
43" - in HDR max
HDR10
Quantum Dots
Vertical Dimming
55" - 6 zones
65" - DCI P3 -
60" - DCI P3 -
49" - DCI P3 -
Color Prime P75" -
65" -
60" -
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH770V
65" - Game mode
60" - Game mode
49" - Game mode
K2L
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH770V
7507
65", 55", 49", 43"No No No 65" - In HDR max
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
49" -
43" -
Local Dimming
55" - DCI P3 - 90%/
49" - DCI P3 - 90%/
43" - DCI P3 -
Color prime P65" -
55" -
49" -
43" -65" - °(cone)
55" -
49" -
43" -65" -
55" -
49" -
43" -UH750V
65", 55", 49", 43"75" - Game mode
65" - Game mode
55" - Game mode
49" - Game mode 38.1ms / by default 57ms
43" - Game mode
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH750V
7007
70"No No No 70" - In HDR max
HDR PROcessing
Local Dimming
70" - 70" - 70" - UH700V
65", 55", 49", 43"70" - Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH700V
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
Local Dimming
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime P65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH670V
65", 55", 49", 43"65" -
55" -
49" -
43" -audio system
Harman / Kardon 2.0
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH670V
668/664/661
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
Local Dimming
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH660V
55" -
49" -
43" -audio system
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH660V
6507
65", 60", 55", 49", 43"No No No 65" - LC
60" -
55" -
49" -
43" -
HDR PROcessing
Convert SDR to HDR
60" - DCI P3 -
55" - DCI P3 - 84%
49" - DCI P3 - 84%
43" - DCI P3 -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -UH650V
65", 60", 55", 49", 43"65" -
60" -
55" -
49" -
43" -Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
USB 2.0 x 2
1 x Antena (RF)
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH650V
58", 50",
UH630V
40"
No No No 58" -
50" -
40" -
HDR PROcessing
Convert SDR to HDR
50" - DCI P3 - 90%
40" - DCI P3 -
50" -
40" -58" -
50" -
40" -58" -
50" -
40" -UH630V
58", 50", 40"58" -
50" -
40" -Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
2 x USB 2.0
1 x Antena (RF)
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
UH630V
58", 50", 40"
UH620V
6257/6207
60" -
55" -
49" -
43" -
HDR PROcessing
Local Dimming
55" - DCI P3
49" - DCI P3
43" - DCI P3 -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH620V
65", 60", 55", 49", 43"Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
WiDi / Miracast
WiFi Direct
1- ARC,
1 x USB 2.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
UH620V
6157/6107
55" -
49" -
43" -
HDR PROcessing
49" -
43" -
55" -
49" -
43" -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH610V
65", 55", 49", 49", 43"65" -
55" -
49" -
Dolby Digital Plus
ULTRA Surround-
WiDi / Miracast
RЅ232С (Міnі Јасk)
2 x USB 2.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR
HEVC
UH610V
No No No No 65" - S-IPS, 8-bit, 60/50Hz
60" - Edge Led
PWM Freq. -65" -
60" -
55" -
49" -
43" -
65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -UH600V
65", 60", 55", 49"UH600V
65", 60", 55", 49"Series
Model
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
Game mode
Board
System on Chip
RAM
Software
Pros & ConsProduct
Този пост е редактиран от hristoslav2; 06-09-16 в 18:26.
