какъв джойстик да използвам на телевизор самсунг ue48h6400 за игри благодаря предварително.
How do I connect a controller to my Samsung TV?
Samsung TVs
USB Connecting Instructions (for all models supporting PSNow)
- Connect the DualShock 4 and the TV’s USB port using the USB cable.
 - Press the PlayStation button on the DualShock 4 to turn on the controller.
* If the controller is not paired via Bluetooth, the controller must remain connected via USB to be used. It will not function wirelessly.
Bluetooth Pairing Instructions
- Press the menu button on the television’s remote.
 - Select the System tab from the on-screen menu.
 - Select Device Manager.
 - Select Bluetooth Gamepad Settings.
 - After entering the Bluetooth Gamepad Settings menu, press and hold the Share and PlayStation button for up to 8 seconds on your DualShock 4 Controller. The controller should flash white from the lightbar.
 - Use the television remote to select Refresh within the Bluetooth Gamepad Settings.
 - Select the DualShock 4 device from the refreshed Bluetooth devices list.
 - Select Pair and Connect.
 - If the device paired properly, it should now glow white instead of flashing.
* If device does not respond after pairing, try restarting both the television and controller
(Note: the H6350, H6300, and H5500 models do not support Bluetooth functionality)
Smart Hub > Games
Няма такъв аксесоар за телевизори
Accessories | SAMSUNG UK
Mobile devices with a screen size between 4 and 6.3 inches can be mounted directly on the gamepad - and you can connect your device to a compatible TV and play your games on the big screen.* * Additional equipment may be required; check your device for TV compatibility.
Samsung Wireless Gamepad (Android) - Bluetooth 3.0 & NFC - Samsung UK
