Резултати от 16 до 30 от общо 39
Моля за мнение - Geforce 4 или ATI Radeon
    Dec 2000
    #16
    RoCoBG mi to e jasno na vsi4ki zasto njama mnogo info nikade.
    Vse oste karti samo se anonsirat a az v realna prodazba do dnes ne sam vidjal.
    Ddimitrov
  3. Senior Member Аватара на Kayso
    Apr 2002
    #17
    Ama da znaete 4e gi prodavat pri tova ot mesec ve4e ama v USA. I se 4udq kakvo da si poru4am za tova zadadoh vuprosa. Qvno otnovo nVidia pe4eli to4kite i direktno smqtam da otlepq Gf4 4400 i prosto nqma skoro da q smenq.
    Asus V8440 Geforce 4 Ti 4400 chip 128mb DDR SDRAM DVI/TV out RetailA core clock speed of 275MHz and memory clock speed of 550MHz, combined with 128MB DDR SDRAM provides exceptional performance in all the latest games and applications. Also included are revolutionary technologies such as: nFiniteFX II engine for complex geometry and animation, Accuview Antialiasing for unbeatable visual quality and frame rate, as well as nView for multiple display flexibility and user control. ,Part#:V8440TD128M (ITEM=ABS14121126)
    Price:$271 FedEx Saver Shipping $7 Stock: Yes
    Asus V8460 Geforce 4 Ti 4600 chip 128mb DDR SDRAM DVI/TV outA core clock speed of 300MHz and memory clock speed of 660MHz, combined with 128MB DDR SDRAM provide the ultimate graphics experience with revolutionary technologies such as: nFiniteFX II engine for complex geometry and animation, Accuview Antialiasing for unbeatable visual quality and frame rate, as well as nView for multiple display flexibility and user control. ,Part#:ASV8460B (ITEM=ABS14121125)
    Price:$347 FedEx Saver Shipping $6.95 Stock: Yes
    Za kakvo si govorim tuka - 400$ kva e taq cena
    eto tova e originalnata cena na Videoto prosto se vlubih )
    Edited by - Kayso на 07/05/2002 2351
    Edited by - Kayso на 07/05/2002 23:24:51
    Dec 2000
    #18
    Ddimitrov
    E che az tochno tova kazvam po-nagore??? Ti cheti po-vnimatelno i posle pishi. Niama smisul da me povtariash. A Ti4200 otdavna e anonsirana, che i dosta reviewta ima...
    Epox 8KHA+|Athlon XP 1700 MHz|TaiSol CGK960|2x256MB Crucial PC2100+ThermalTake Cooling|Leadtek GF4 300/680|40 GB Seagate ATA III + 13 GB IBM DJNA|Audigy|Chieftech Dragon DA-01W|
    Mar 2002
    #19
    Trebe ili da si mnogo naiven, ako si mislish, 4e ste mozesh da kupish tuka v BG nesto takova na cenata, na koqto se prodava v USA..... ili da ziveesh v USA....
    <-- AMD Inside -->
    EPoX 8K3A, AXP 1809MHz 9x201MHz + Alpha PEP66, 128MB DDR333 KingMAX333, ATi RADEON8500 128MB DVI 300@255, 40GB Seagate BIV + 40GB Maxtor D540X, ASUS 16x DVD, Enlight EN-7237 Case + 400W Enlight PSU, 17" ReliSYS FLAT
    Mar 2001
    #20
    Така....Каисо,нека те светна,щото хич не си в час!
    1.много са малко саитовете,които ще ти пратят до БГ
    2.С кво смяташ да им платиш?Приемат само Мастер карт,ВИЗА или Ам. експрес,е,може и по банков път,само че трансфера е някъде около 80$,а и тяхната такса трябва да поемеш...
    3.Ами застраховката,приятелю,ами митото,около 10%,ами ДДС-то??
    4.FexEx..като го чуя тва име и се изприщвам:7$ е за Щатите,ти имаш ли дори бегла представа колко струва до тук??120$ брато!
    5.За да ти пратят нещо от US ,от трябва да имаш поределен рейтинг някъде,най добре на EBAY-ти имаш ли такъв??НЕ!
    Така че не си прави илюзии-бате ти Митко отдавна е минал по тоя път обаче и ако желаеш мога да ти достава GF4 на цена 20-30$ по висока от тая която си видял
    Dec 2000
    #21
    RoCoBG ti tup li si ili kvo?
    Oste s parvoto si pisanie sam iskal da kaza to4no tova i vseki deto pone malko se zamislja ste se seti za kvo stava vapros.Ta mai ti me povtarjas.
    Osven tova ot anonsirane do puskane v masova prodazba ima razlika ne mislis li?
    Edva li kam dnesna data GF4 4200 e pusnata v prodazba kadeto i da e bilo po sveta.
    Ddimitrov
  9. Senior Member Аватара на Kayso
    Apr 2002
    #22
    Bate mi Mitko, imam 4ustvoto 4e oste vednuj mi se povtarq tezata 4e tuka vmesto da davate mneniq se 4udite ka da si merite pishkite s izvinenie. Nito smqtam da plastam DDS nito mito nito shiping da ne govorim puk za transfer na pari. Vse pak ne znam s kakvo se zanivash ili s kakvo si se zanimal no mi se struva 4e ti ne si v 4as. Tezi nesta sa misleni ne ot tebe a ot hora po 4iito put minavash ti taka 4e ne si prisvoq 4ujd opit. DDS se plasta pri vnos s cel prodajba, a susto taka i mito. Za 4asni lica tezi nesta ne vajat. Neznam zasto reshi 4e horata v Bulgariq ne mogat da imat kreditni karti i oste pove4e puk poznati ili sestra primerno koito da u4at tam i da mogat da im kupqt, da im pratqt ili oste po-dobre da im donesat kato se vrustat za lqtnata vakanciq kakvoto si pojelaqt. Taka 4e molq te kakto i vsi4ki ostanali, NE SE IZHVURLQITE a prosto spodelete znaniqta koito imate i s drugite, taka mislq az e po dobre
    Edited by - Kayso на 09/05/2002 14:12:25
    Jan 2001
    #23
    едно малко уточнение: ддс и мито се плащат винаги при внос, независимо от целта на вноса и независимо дали е осъществен от физическо или юридическо лице. ддс е постоянно (20%), а митото се определя съгласно митническите тарифи на бг. за да не платиш ддс и мито, чисто и просто трябва да не я покажеш на границата.
    далаверата ти е, че ддс-то, което си платил в съответната държава (или vat - value added tax), ти е върнато на тяхната граница, след представяне на фактура и при стойност на покупката, надхвърляща определена регламентирана сума. ако скриеш покупката при влизане в бг и не платиш нашето ддс, си спечелили, или по-точно спестил величината на vat-a в страната на покупката.
    за митото - просто си зависи от типа на стоката - от 0% до "не ти трябва да знаеш"
    най-общо - това е.
    Jan 2001
    #24
    Посочените по-горе цени са верни в общи линии. Това за сестрите също <img src=icon_smile_big.gif border=0 align=middle>
    Най-точно се изказа обаче FearMe!!!
    _________________
    A Steve Morse Fan!!!
  12. Senior Member Аватара на Kayso
    Apr 2002
    #25
    FearMe prav si za DDSto no pak povtarqm pri postenska pratka nqma kak da platish DDS, prosto na mitnicata ne ti q zasi4at razbirash li. Sestra mi e prastal aMp3 player, 4asovnici i dr. podobni i do sega ne sum platil i lev. Tova se opitvam da obqsnq. I kolkoto do tova koga se plasta DDS i mito, znam ) vse pak sum 3 godina v ikonomi4eskiq vuv Varna
  13. Super Moderator Аватара на FearMe
    Jan 2001
    #26
    за колетчетата - спор няма, само че не ти връщат vat-то т.е. може и по-изгодно ... стига да мине човека лично границата ...
    а за ИУ-Варна - been there, seen that
    Mar 2001
    #27
    Сестра,брат,вуйчо...тва са частни случаи
    Във всеки случай ако стоката се застрахова,плащаш всичко като поп-мита,ДДС..просто застрахователя го налага-ако ли не:тва просто си е хазарт!
    Въпросът е да не се дават примери със цени в Щатите-нереално е...и е далече и излиза скъпо!Още повече пък ако се споменава шипване със FedEx-тва е най-скъпия доставчик.
    Jan 2002
    #28
    Neka wi kaza s primer kak Bombera(Shader) s wzema Radeon 8500 ot AMerica. Porychwa se na mama. Mama kupuwa, paketira, obqwqwa stoinost 250$(kolkoto beshe togawa). Platkata pristiga pri mene i az trea da ida da si ia zema ot Sofiiska mitnica. Tam edna debela lelka mi kazwa che trea da platq 67 dolara mito zastoto stokata e nad 200 dolara. Sled nqkolko smiganiq minawam s 50 kinta, stoto nqmah po drebna banknota u men. Twa e za danycite. Ako wi e sram na mitnicata - ne se pritesnqwaite, sluzitelite she si predlozat sami. Ako dyrzite da ste chestni - pri chasna pratka nad 200 dolara se plasta mito kato pop. Ne zna mdali gornata cifra(mnoo e golqma nesto) ne wkluchwa i DDS. Po FedEx i sichki posti drugi ot USA do BG e koshmarno skypo+plastash sichki danyci kato pop. Zabrawete.
  17. Senior Member Аватара на Kayso
    Apr 2002
    #29
    Е незнам кое му е частното на случая ама половин България е вече в USA и няма никакъв проблем да си поръчаш каквото и да било, стига да имаш приятел който да има друг приятел чиято птиятелка примерно учи в USA и се връща за лятото, това е. Пак повтарям че ДДС няма, може да има само мито и то в зависимост от определената стойност както каза Shader, невиждам обаче какъв е проблем да си пишеш картата с по-ниска стойност. Шипването от USA струва около 40$ с DHL проверих и идва за около месец с гаранция за съдържанието. А това че на митницата можеш да минеш тъкно е абсолютно вярно стига да си малко по хитър )
    Dec 2000
    #30
    Abe Kayso kuv e toja DHL za mesets be 4ovek?
    Ta tva e po bavno ot obiknovenna posta?
    Napravo me saskas<img src=icon_smile_question.gif border=0 align=middle>
    Ddimitrov
  1. ATI Mobility Radeon HD 2600 vs. nVidia GeForce 8400M GT
    От Black Genesis във форум Аудио и Видеокарти
    Последно: 22-04-08, 13:21
  2. GeForce FX5200 ili Ati Radeon 9000Pro
    От spidera във форум Аудио и Видеокарти
    Последно: 17-10-03, 14:49
  3. Radeon 9700 sre6to GeForce 4 Ti4600?
    От CreatoR във форум Аудио и Видеокарти
    Отговори: 12
    Последно: 12-09-02, 11:54
  4. GeForce MX440 vs GigaByte ATI Radeon 7500
    От Userz2k във форум Аудио и Видеокарти
    Последно: 29-07-02, 16:07
  5. Radeon 7500 64 SDR or Abit GeForce MX400 64 SDR
    От gabarko във форум Аудио и Видеокарти
    Отговори: 23
    Последно: 13-06-02, 02:19
