Дискети???
    Дискети???
    Препоръчйте някаква марка дискети, защото започвам да ставам много неодоволен от Verbatim дори и да използвам най- скъпите от тях. TDK струват ли?
    Dec 2002
    Дискети???
    Proper Diskette Care and Usage
    (1) Never leave diskettes in the drive, as the data can leak out of the disk and corrode the inner mechanics of the drive. Diskettes should be rolled up and stored in pencil holders.
    (2) Diskettes should be cleaned and waxed once a week. Microscopic metal particles may be removed by waving a powerful magnet over the surface of the disk. Any stubborn metal shavings can be removed with scouring powder and steel wool. When waxing a diskette, make sure the surface is even. This will allow the diskette to spin faster, resulting in better access time.
    (3) Do not fold diskettes unless they do not fit into the drive. "Big" Diskettes may be folded and used in "Little" drives.
    (4) Never insert a diskette into the drive upside down. The data can fall off the surface of the disk and jam the intricate mechanics of the drive.
    (5) Diskettes cannot be backed up by running them through a photo copy machine. If your data is going to need to be backed up, simply insert TWO diskettes into your drive. Whenever you update a document, the data will be written onto both disks. A handy tip for more legible backup copies: Keep a container of iron filings at your desk. When you need to make two copies, sprinkle iron filings liberally between the diskettes before inserting them into the drive.
    (6) Diskettes should not be removed or inserted from the drive while the red light is on or flashing. Doing so could result in smeared or possibly unreadable text. Occasionally, the red light remains flashing in what is known as a "hung" or "hooked" state. If your system is hooking, you will probably need to insert a few coins before being allowed to access the slot.
    (7) If your diskette is full and needs more storage space, remove the disk from the drive and shake vigourously for two minutes. This will pack the data enough (data compression) to allow for more storage. Be sure to cover all openings with scotch tape to prevent loss of data.
    (8) Data access time may be greatly improved by cutting more holes in the diskette jacket. This will provide more simultaneous access points to the disk.
    (9) Periodically spray diskettes with insecticide to prevent system bugs from spreading.....
    (10) You can keep your data fresh by storing disks in the vegetable compartment of your refrigerator. Disks may be frozen, but remember to un thaw by microwaving or briefly immersing in boiling water.
    (11) "Little" diskettes must be removed from their box prior to use. These containers are childproof to prevent tampering by unknowledgeable youngsters.
    (12) You can recover data from a damaged disk by using the DOS command: FORMAT /U or alternatively by scratching new sector marks on the disk with a nail file.
    (13) Diskettes become "hard" with age. It's important to back up your "hard" disks before they become too brittle to use.
    (14) Make sure you label your data. Staples are a good way to permanently affix labels to your disks.
    Feb 2002
    Дискети???
    ...he he he... svejo [:D][:D][:D]
    afterburner, za kakvo gi polzva6 tia disketi tolkova...??? ako nameri6 3M niakade, vzemi si niakolko i probvai dali 6te se darjat dostoino. az o6te imam tuka niakolko deto mi se tarkaliat iz 4ekmedjeto. ednata daje e bez kapa4e ama o6te darji...
    Jan 2001
    Дискети???
    не са сега дискетите като едно време. съвсем започнаха от боклуци да ги правят. имам около 70бр 5 1/4" и всичките си бачкат, хем са форматирани на по 420k (стандартно 360k). а от 3 1/2" имам от не знам вече коя година, но не са по-късно от 90-91 и си стоят и пеят! а сега какво? вземеш 2*10 verbatim за пред някоя институция и точно след 2 записа на по 1-2k и се налага format, защото read error.....
    Feb 2002
    Дискети???
    Браво Kirande, kak само ме развесели [:D]
    A това за старите май е вярно че са по-хубави и аз имам такива наблюдения...
    A CD-RW?
  7. Super Moderator Аватара на FearMe
    Jan 2001
    Дискети???
    имам си един ricoh, който има сигурно около 50 записа и не е мръднал, хем е direct cd форматиран. иначе имам maxell, philips, benq и 3 1/2 verbatim, но те не са видяли толкова зор. не че 50 цикъла са кой знае колко, но са си число...
    Дискети???
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by FearMe
    Точно за това говорих. Като ми се скапе РС-то не мога да намеря работещ StarTup диск [:D][:D]
    Mar 2001
    Дискети???
    Mi az sym dovolrm ot TDK, vzemam si i sony
    Дискети???
    Verbatim имат много модели. Кой точно те разочарова?
    Jan 2002
    Дискети???
    be az otkakto imam zapisva4ka disketa ne sam i pomirisval. samo na RW-ta kibi4a. slu4valo se e da pi6a CD za 6Kb file
    Jan 2002
    Дискети???
    Дискети???
    До сега съм използвал DataLifePlus които са с тефлоново покритие, но от 10 дискети 4 се скапаха. Може ли проблема да е във флопито ми?
    Sep 2002
    Дискети???
    аз ползвам на BASF не са кои ли знае ко ама ми вършат раота
    половината са в бадсекторс кво да ти разпраам .
    Дискети???
    Да може флопито да ти драска дискетите - жалко че моделите не се подобряват от години!
    Отмести капачето и разгледай повърхността им!
    Mar 2001
    Дискети???
    Ми те скоро съвсем ще вземе да из4езнат. Може да вземат да станат колекционерска рядкост [] .
    Представяте ли си: един куп пари за да имаш дискета [:D]
  1. Продавам: Sega mega drive 2 + дискети
    От chorbaka във форум Приключили продажби
    Последно: 12-04-11, 20:47
  2. Търся стари дискети за Правец 8
    От Yassen във форум Купува
    Последно: 28-12-09, 08:58
  3. Продавам: Дискети 1,44MB -100 бр. - 5лв.
    От sysoff във форум Продава
    Последно: 01-02-08, 23:14
