http://www.dooyoo.co.uk/playstation-...ally-2/140944/
OPENROADS Enable all tracks and 'Super Special' in time trial mode.
SHOEBOXES To unlock the 4 bonus cars in time trial mode.
SKCART Reverse tracks. (Start race at finish line and end race at start line)
WHITEBUNNY Mirror tracks, Driver also on right side during cockpit view.
BLANCMANGE Drive a 'Green Jelly' car
BUTTONBASH Accelerate by pushing X, O alternately.
DIDDYCARS 'Micro-Machines mode', Drive with small cars and overhead view.
FORKLIFT Drive cars with rear wheel steering.
HELIUMNICK Drive with high-pitched commentary.
HOVERCRAFT Drive hover cars.
KITCAR Enable 'turbo jumps', Press select to jump, when the bar turns green.
MOONWALK Drive with low gravity enabled.
MOREOOMPH Turbo Mode, (game runs faster).
NIGHTRIDER Enable 'Night' mode.
PEASOUPER Enable 'Fog' mode.
SILKYSMOOTH Increase the games frame rate, (particles are disabled).
TINFOILED Drive metallic cars.
Tова открих. Не разбрах къде и кога се въвеждат кодовете, вероятно насляпо в главното меню. Лично аз не съм ги пробвал, просто превъртях шампионатите при средна трудност и "експерт" ... препоръчвам ти и на теб, ако имаш време - екшънът е гарантиран!
EDIT: Горните може би са само за Playstation. Пробвай и тези: http://www.simracingworld.com/games/9/cheats/
След пачването изписва при опит да я стартирам "wrong disc inserted".Та трябваше да я преинсталирам.
wrong patch inserted
Стана като написах greatnews като име на нов driver profile.
05 не се кара без волан,просто е много нереално.Първоначално публикувано от fanta orange
Colin McRae Rally 2
Various Cheats
Create a new driver with any of the following "Names":
Code Effect
LETMEWIN All Options
GREATNEWS All Tracks
ALLTHEBUTTONS All Cars
MORRISMODE Escort MK1 Car
GOFASTERSTRIPES Faster Cars
GARYWILDASS Ford Puma Car
EVILEVO Lancer Road Car
MINIME Mini Cooper S Car
NUTTYNETS Aggressive Cars
TURNONTHEICE Background Music
BOINGBOINGBOING Bouncer Mode
WAVEYOURLEFTS Reverse Tracks
WHEELYBIG Monster Tires
SHINYBUTTONS Shining Cars
CURRYFORME Turbo Boost
BOUNCYBOUNCYBOUNCY Reduced Gravity
EATTHIS Fireball (press handbrake)
OOHNICE ???
врътнах си го на кариер без волан и то с победа на всяко едно рали или състезание
