Medal Of Honor Allied Assault Spearhead
nqkoi moje li da mi kaje kak da si sloja expansiona sled kato MOHAA-ta mi ne e instalacionna ami napravo se slagha na pc-to i se igrae.I pri instalaciq na expansiona mi kazva 4e sam nqmal instalirana MOHAA.Ima li sashto nqkakvi iziskvaniq po otnoshenie na versiqta.
A i oshte neshto,nqkoi koito ima instalirana MOHAA moje li da mi exportne registrite si da gi sloja pri men da probam dali taka shte stane.
10x predvaritelno
Дори и инсталационна да я имаш,все тая:няма да тръгне[:-bouncy][:-bouncy][:-bouncy][:-bouncy]
Решението е <font color="red">ТОВА</font id="red">
mersi za reg-a shte go probam dali shte tragne.
Az si zapisax Spearhead oba4e sled kato se opitvam da pusna Singala ili multito me izxvarliq ot igrata i shte pastna vsi4ki,koeto mi izpisva ot consolata,za da mi vidite to4no kakyv e problema.Nadqvam se da mi dadete nqkakyv syvet.Reg4eto si go izteglix no bez rezultat.Eto i kakvo mi izpisva:
--- Common Initialization ---
Medal of Honor Spearhead 2.0 win-x86 Oct 24 2002
----- FS_Startup -----
Current search path:
D:\games\Medal Of Honour Allied Assault/mainta
D:\games\Medal Of Honour Allied Assault\mainta\pak2.pk3 (767 files)
D:\games\Medal Of Honour Allied Assault\mainta\pak1.pk3 (6969 files)
D:\games\Medal Of Honour Allied Assault\main\Pak5.pk3 (259 files)
D:\games\Medal Of Honour Allied Assault\main\Pak4.pk3 (593 files)
D:\games\Medal Of Honour Allied Assault\main\Pak3.pk3 (669 files)
D:\games\Medal Of Honour Allied Assault\main\Pak2.pk3 (4722 files)
D:\games\Medal Of Honour Allied Assault\main\Pak1.pk3 (772 files)
D:\games\Medal Of Honour Allied Assault\main\Pak0.pk3 (11175 files)
25926 files in pk3 files
execing default.cfg
execing buildver.cfg
execing menu.cfg
execing newconfig.cfg
execing localize.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 11
You are now setup for medium mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 32, 0 )
...43 PFDs found
...hardware acceleration found
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_EXT_texture_compression_s3tc
...using GL_ARB_texture_compression
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...ignoring GL_EXT_texture_env_combine
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce4 MX 460/AGP/SSE/3DNOW!
GL_VERSION: 1.4.0
GL_EXTENSIONS: GL_ARB_imaging
GL_EXTENSIONS: GL_ARB_multitexture
GL_EXTENSIONS: GL_ARB_point_parameters
GL_EXTENSIONS: GL_ARB_texture_compression
GL_EXTENSIONS: GL_ARB_texture_cube_map
GL_EXTENSIONS: GL_ARB_texture_env_add
GL_EXTENSIONS: GL_ARB_texture_env_combine
GL_EXTENSIONS: GL_ARB_texture_env_dot3
GL_EXTENSIONS: GL_ARB_texture_mirrored_repeat
GL_EXTENSIONS: GL_ARB_transpose_matrix
GL_EXTENSIONS: GL_ARB_vertex_program
GL_EXTENSIONS: GL_ARB_window_pos
GL_EXTENSIONS: GL_S3_s3tc
GL_EXTENSIONS: GL_EXT_abgr
GL_EXTENSIONS: GL_EXT_bgra
GL_EXTENSIONS: GL_EXT_blend_color
GL_EXTENSIONS: GL_EXT_blend_minmax
GL_EXTENSIONS: GL_EXT_blend_subtract
GL_EXTENSIONS: GL_EXT_clip_volume_hint
GL_EXTENSIONS: GL_EXT_compiled_vertex_array
GL_EXTENSIONS: GL_EXT_draw_range_elements
GL_EXTENSIONS: GL_EXT_fog_coord
GL_EXTENSIONS: GL_EXT_multi_draw_arrays
GL_EXTENSIONS: GL_EXT_packed_pixels
GL_EXTENSIONS: GL_EXT_paletted_texture
GL_EXTENSIONS: GL_EXT_point_parameters
GL_EXTENSIONS: GL_EXT_rescale_normal
GL_EXTENSIONS: GL_EXT_secondary_color
GL_EXTENSIONS: GL_EXT_separate_specular_color
GL_EXTENSIONS: GL_EXT_shared_texture_palette
GL_EXTENSIONS: GL_EXT_stencil_wrap
GL_EXTENSIONS: GL_EXT_texture_compression_s3tc
GL_EXTENSIONS: GL_EXT_texture_cube_map
GL_EXTENSIONS: GL_EXT_texture_edge_clamp
GL_EXTENSIONS: GL_EXT_texture_env_add
GL_EXTENSIONS: GL_EXT_texture_env_combine
GL_EXTENSIONS: GL_EXT_texture_env_dot3
GL_EXTENSIONS: GL_EXT_texture_filter_anisotropic
GL_EXTENSIONS: GL_EXT_texture_lod
GL_EXTENSIONS: GL_EXT_texture_lod_bias
GL_EXTENSIONS: GL_EXT_texture_object
GL_EXTENSIONS: GL_EXT_vertex_array
GL_EXTENSIONS: GL_EXT_vertex_weighting
GL_EXTENSIONS: GL_IBM_texture_mirrored_repeat
GL_EXTENSIONS: GL_KTX_buffer_region
GL_EXTENSIONS: GL_NV_blend_square
GL_EXTENSIONS: GL_NV_fence
GL_EXTENSIONS: GL_NV_fog_distance
GL_EXTENSIONS: GL_NV_light_max_exponent
GL_EXTENSIONS: GL_NV_packed_depth_stencil
GL_EXTENSIONS: GL_NV_pixel_data_range
GL_EXTENSIONS: GL_NV_point_sprite
GL_EXTENSIONS: GL_NV_register_combiners
GL_EXTENSIONS: GL_NV_texgen_reflection
GL_EXTENSIONS: GL_NV_texture_env_combine4
GL_EXTENSIONS: GL_NV_texture_rectangle
GL_EXTENSIONS: GL_NV_vertex_array_range
GL_EXTENSIONS: GL_NV_vertex_array_range2
GL_EXTENSIONS: GL_NV_vertex_program
GL_EXTENSIONS: GL_NV_vertex_program1_1
GL_EXTENSIONS: GL_SGIS_generate_mipmap
GL_EXTENSIONS: GL_SGIS_multitexture
GL_EXTENSIONS: GL_SGIS_texture_lod
GL_EXTENSIONS: GL_WIN_swap_hint
GL_EXTENSIONS: WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 2
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU: AMD w/ 3DNow!
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
picmip_models: 0
picmip_sky: 0
texture bits: 32
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
Initializing Shaders
Setting up Shaders
----- finished R_Init -----
------- profiling DrawBackground methods -------
glDrawPixels w/ BGR: 10595 clocks
glDrawPixels w/ RGB: 6014 clocks
glTexSubImage2D w/ BGR: 2258490 clocks
glTexSubImage2D w/ RGB: 2088906 clocks
DrawBackground: using glDrawPixels with RGB data
Winsock Initialized
Opening IP socket: localhost:12203
Hostname: pc
IP: 127.0.0.1
------- Sound Initialization (full) -------
Sound opened using Direct Sound
'Miles Fast 2D Positional Audio' provider opened.
Loading global/sound0.txt
------- S_StopAllSounds (stop music) -------
------- S_StopAllSounds Complete-------
----- Sound Info -----
driver - Miles Fast 2D Positional Audio
speaker setup - 2 speakers
reverb - OFF
samplebits - 16
speed - 44100
------- Sound Initialization Complete ------- 38 ms
Setting up Shaders
Loading inventory...
----- Client Initialization Complete ----- 1877 ms
--- Common Initialization Complete --- 4460 ms
Working directory: D:\games\Medal Of Honour Allied Assault
Loading Localization File global/localization.txt
trFMV::play(), playing EAlogo.RoQ
------ Server Initialization ------
Server: briefing/briefingt1
Setting up Shaders
UI_DrawConnect called
LoadLibrary("mainta/gamex86.dll") failed
...reason: 'One of the library files needed to run this application cannot be found.
----- CL_Shutdown -----
------- Sound Shutdown (full) -------
------- S_MILES_StopAllSounds -------
------- S_MILES_StopMP3 -------
------- Q_AIL_shutdown -------
------- S_MILES_FreeDLL -------
------- S_MILES_FreeDLL Finished! -------
------- Miles DLL Removed -------
------- Sound Deallocation (4) -------
Deallocating 0x 4 (Done)
------- Sound Shutdown Complete -------
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...hiding window
...destroying window
...window successfully destroyed
...resetting display
...shutting down QGL
...unloading OpenGL DLL
----- Server Shutdown -----
Couldn't load game
Виж дали въобще имаш файл 'gamex86.dll' в директория 'mainta', която е поддиректория на директорията на играта. Ако имаш - трябва да е 2*478*130 байта.
Tozi fail go imam i e to4no tolkova golqm kolkoto kazvash.
Здравейте, някой може ли да ми даде сериен номер за Medal of Honor? Благодаря предварително.
На http://astalavista.box.sk има всичко от което се нуждаеш.П.С.Става дума за koleto де.
Abe hora toi pavkata mi kaza 4e imal takiva problemi i ne6to tam napravil, 4e daje mi se hvali 4e q prevartial!!! Pitaite nego!!!
