Medal Of Honor Allied Assault Spearhead
  1. qni
    qni е офлайн
    Member Аватара на qni
    Mar 2002
    nqkoi moje li da mi kaje kak da si sloja expansiona sled kato MOHAA-ta mi ne e instalacionna ami napravo se slagha na pc-to i se igrae.I pri instalaciq na expansiona mi kazva 4e sam nqmal instalirana MOHAA.Ima li sashto nqkakvi iziskvaniq po otnoshenie na versiqta.
    A i oshte neshto,nqkoi koito ima instalirana MOHAA moje li da mi exportne registrite si da gi sloja pri men da probam dali taka shte stane.
    10x predvaritelno
    Mar 2001
    Дори и инсталационна да я имаш,все тая:няма да тръгне[:-bouncy][:-bouncy][:-bouncy][:-bouncy]
    Решението е <font color="red">ТОВА</font id="red">
  4. qni
    qni е офлайн
    Mar 2002
    mersi za reg-a shte go probam dali shte tragne.
  5. Cko
    Cko е офлайн
    Senior Member
    Aug 2001
    Имате ли линк за MOHAA-S
    Jan 2003
    Az si zapisax Spearhead oba4e sled kato se opitvam da pusna Singala ili multito me izxvarliq ot igrata i shte pastna vsi4ki,koeto mi izpisva ot consolata,za da mi vidite to4no kakyv e problema.Nadqvam se da mi dadete nqkakyv syvet.Reg4eto si go izteglix no bez rezultat.Eto i kakvo mi izpisva:
    --- Common Initialization ---
    Medal of Honor Spearhead 2.0 win-x86 Oct 24 2002
    ----- FS_Startup -----
    Current search path:
    D:\games\Medal Of Honour Allied Assault/mainta
    D:\games\Medal Of Honour Allied Assault\mainta\pak2.pk3 (767 files)
    D:\games\Medal Of Honour Allied Assault\mainta\pak1.pk3 (6969 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak5.pk3 (259 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak4.pk3 (593 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak3.pk3 (669 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak2.pk3 (4722 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak1.pk3 (772 files)
    D:\games\Medal Of Honour Allied Assault\main\Pak0.pk3 (11175 files)
    25926 files in pk3 files
    execing default.cfg
    execing buildver.cfg
    execing menu.cfg
    execing newconfig.cfg
    execing localize.cfg
    Config: unnamedsoldier.cfg
    execing configs/unnamedsoldier.cfg
    couldn't exec localized.cfg
    execing autoexec.cfg
    Unknown command "fov"
    couldn't exec custom.cfg
    ...detecting CPU, found AMD w/ 3DNow!
    ------- Input Initialization -------
    Initializing DirectInput...
    Couldn't set DI coop level
    Falling back to Win32 mouse support...
    ------- Input Initialization Complete ------- 11
    You are now setup for medium mode.
    ----- Client Initialization -----
    Called FadeSound with: 0.000000
    ----- Initializing Renderer ----
    ----- R_Init -----
    Initializing OpenGL subsystem
    ...initializing QGL
    ...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
    ...setting mode 4: 800 600 FS
    ...using colorsbits of 32
    ...calling CDS: ok
    ...registered window class
    ...created window@0,0 (800x600)
    Initializing OpenGL driver
    ...getting DC: succeeded
    ...GLW_ChoosePFD( 32, 32, 0 )
    ...43 PFDs found
    ...hardware acceleration found
    ...PIXELFORMAT 7 selected
    ...creating GL context: succeeded
    ...making context current: succeeded
    Initializing OpenGL extensions
    ...using GL_EXT_texture_compression_s3tc
    ...using GL_ARB_texture_compression
    ...using GL_EXT_texture_env_add
    ...using WGL_EXT_swap_control
    ...using GL_ARB_multitexture
    ...ignoring GL_EXT_texture_env_combine
    ...using GL_EXT_compiled_vertex_array
    ...WGL_3DFX_gamma_control not found
    GL_VENDOR: NVIDIA Corporation
    GL_RENDERER: GeForce4 MX 460/AGP/SSE/3DNOW!
    GL_VERSION: 1.4.0
    GL_EXTENSIONS: GL_ARB_imaging
    GL_EXTENSIONS: GL_ARB_multitexture
    GL_EXTENSIONS: GL_ARB_point_parameters
    GL_EXTENSIONS: GL_ARB_texture_compression
    GL_EXTENSIONS: GL_ARB_texture_cube_map
    GL_EXTENSIONS: GL_ARB_texture_env_add
    GL_EXTENSIONS: GL_ARB_texture_env_combine
    GL_EXTENSIONS: GL_ARB_texture_env_dot3
    GL_EXTENSIONS: GL_ARB_texture_mirrored_repeat
    GL_EXTENSIONS: GL_ARB_transpose_matrix
    GL_EXTENSIONS: GL_ARB_vertex_program
    GL_EXTENSIONS: GL_ARB_window_pos
    GL_EXTENSIONS: GL_S3_s3tc
    GL_EXTENSIONS: GL_EXT_abgr
    GL_EXTENSIONS: GL_EXT_bgra
    GL_EXTENSIONS: GL_EXT_blend_color
    GL_EXTENSIONS: GL_EXT_blend_minmax
    GL_EXTENSIONS: GL_EXT_blend_subtract
    GL_EXTENSIONS: GL_EXT_clip_volume_hint
    GL_EXTENSIONS: GL_EXT_compiled_vertex_array
    GL_EXTENSIONS: GL_EXT_draw_range_elements
    GL_EXTENSIONS: GL_EXT_fog_coord
    GL_EXTENSIONS: GL_EXT_multi_draw_arrays
    GL_EXTENSIONS: GL_EXT_packed_pixels
    GL_EXTENSIONS: GL_EXT_paletted_texture
    GL_EXTENSIONS: GL_EXT_point_parameters
    GL_EXTENSIONS: GL_EXT_rescale_normal
    GL_EXTENSIONS: GL_EXT_secondary_color
    GL_EXTENSIONS: GL_EXT_separate_specular_color
    GL_EXTENSIONS: GL_EXT_shared_texture_palette
    GL_EXTENSIONS: GL_EXT_stencil_wrap
    GL_EXTENSIONS: GL_EXT_texture_compression_s3tc
    GL_EXTENSIONS: GL_EXT_texture_cube_map
    GL_EXTENSIONS: GL_EXT_texture_edge_clamp
    GL_EXTENSIONS: GL_EXT_texture_env_add
    GL_EXTENSIONS: GL_EXT_texture_env_combine
    GL_EXTENSIONS: GL_EXT_texture_env_dot3
    GL_EXTENSIONS: GL_EXT_texture_filter_anisotropic
    GL_EXTENSIONS: GL_EXT_texture_lod
    GL_EXTENSIONS: GL_EXT_texture_lod_bias
    GL_EXTENSIONS: GL_EXT_texture_object
    GL_EXTENSIONS: GL_EXT_vertex_array
    GL_EXTENSIONS: GL_EXT_vertex_weighting
    GL_EXTENSIONS: GL_IBM_texture_mirrored_repeat
    GL_EXTENSIONS: GL_KTX_buffer_region
    GL_EXTENSIONS: GL_NV_blend_square
    GL_EXTENSIONS: GL_NV_fence
    GL_EXTENSIONS: GL_NV_fog_distance
    GL_EXTENSIONS: GL_NV_light_max_exponent
    GL_EXTENSIONS: GL_NV_packed_depth_stencil
    GL_EXTENSIONS: GL_NV_pixel_data_range
    GL_EXTENSIONS: GL_NV_point_sprite
    GL_EXTENSIONS: GL_NV_register_combiners
    GL_EXTENSIONS: GL_NV_texgen_reflection
    GL_EXTENSIONS: GL_NV_texture_env_combine4
    GL_EXTENSIONS: GL_NV_texture_rectangle
    GL_EXTENSIONS: GL_NV_vertex_array_range
    GL_EXTENSIONS: GL_NV_vertex_array_range2
    GL_EXTENSIONS: GL_NV_vertex_program
    GL_EXTENSIONS: GL_NV_vertex_program1_1
    GL_EXTENSIONS: GL_SGIS_generate_mipmap
    GL_EXTENSIONS: GL_SGIS_multitexture
    GL_EXTENSIONS: GL_SGIS_texture_lod
    GL_EXTENSIONS: GL_WIN_swap_hint
    GL_EXTENSIONS: WGL_EXT_swap_control
    GL_MAX_TEXTURE_SIZE: 2048
    GL_MAX_ACTIVE_TEXTURES_ARB: 2
    PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
    MODE: 4, 800 x 600 fullscreen hz:N/A
    GAMMA: hardware w/ 0 overbright bits
    CPU: AMD w/ 3DNow!
    rendering primitives: single glDrawElements
    texturemode: GL_LINEAR_MIPMAP_LINEAR
    picmip: 0
    picmip_models: 0
    picmip_sky: 0
    texture bits: 32
    multitexture: enabled
    compiled vertex arrays: enabled
    texenv add: enabled
    compressed textures: enabled
    Initializing Shaders
    Setting up Shaders
    ----- finished R_Init -----
    ------- profiling DrawBackground methods -------
    glDrawPixels w/ BGR: 10595 clocks
    glDrawPixels w/ RGB: 6014 clocks
    glTexSubImage2D w/ BGR: 2258490 clocks
    glTexSubImage2D w/ RGB: 2088906 clocks
    DrawBackground: using glDrawPixels with RGB data
    Winsock Initialized
    Opening IP socket: localhost:12203
    Hostname: pc
    IP: 127.0.0.1
    ------- Sound Initialization (full) -------
    Sound opened using Direct Sound
    'Miles Fast 2D Positional Audio' provider opened.
    Loading global/sound0.txt
    ------- S_StopAllSounds (stop music) -------
    ------- S_StopAllSounds Complete-------
    ----- Sound Info -----
    driver - Miles Fast 2D Positional Audio
    speaker setup - 2 speakers
    reverb - OFF
    samplebits - 16
    speed - 44100
    ------- Sound Initialization Complete ------- 38 ms
    Setting up Shaders
    Loading inventory...
    ----- Client Initialization Complete ----- 1877 ms
    --- Common Initialization Complete --- 4460 ms
    Working directory: D:\games\Medal Of Honour Allied Assault
    Loading Localization File global/localization.txt
    trFMV:lay(), playing EAlogo.RoQ
    ------ Server Initialization ------
    Server: briefing/briefingt1
    Setting up Shaders
    UI_DrawConnect called
    LoadLibrary("mainta/gamex86.dll") failed
    ...reason: 'One of the library files needed to run this application cannot be found.
    ----- CL_Shutdown -----
    ------- Sound Shutdown (full) -------
    ------- S_MILES_StopAllSounds -------
    ------- S_MILES_StopMP3 -------
    ------- Q_AIL_shutdown -------
    ------- S_MILES_FreeDLL -------
    ------- S_MILES_FreeDLL Finished! -------
    ------- Miles DLL Removed -------
    ------- Sound Deallocation (4) -------
    Deallocating 0x 4 (Done)
    ------- Sound Shutdown Complete -------
    RE_Shutdown( 1 )
    Shutting down OpenGL subsystem
    ...wglMakeCurrent( NULL, NULL ): success
    ...deleting GL context: success
    ...releasing DC: success
    ...hiding window
    ...destroying window
    ...window successfully destroyed
    ...resetting display
    ...shutting down QGL
    ...unloading OpenGL DLL
    ----- Server Shutdown -----
    Couldn't load game
    Jan 1970
    Виж дали въобще имаш файл 'gamex86.dll' в директория 'mainta', която е поддиректория на директорията на играта. Ако имаш - трябва да е 2*478*130 байта.
    Jan 2003
    Tozi fail go imam i e to4no tolkova golqm kolkoto kazvash.
    Nov 2002
    Здравейте, някой може ли да ми даде сериен номер за Medal of Honor? Благодаря предварително.
    Oct 2002
    На http://astalavista.box.sk има всичко от което се нуждаеш.П.С.Става дума за koleto де.
    Apr 2002
    Abe hora toi pavkata mi kaza 4e imal takiva problemi i ne6to tam napravil, 4e daje mi se hvali 4e q prevartial!!! Pitaite nego!!!
  1. Проблем с Medal of Honor Pacific Assault
    От cordobata във форум ИГРИ
    Последно: 14-11-07, 12:26
  2. Мedal of Honor: Pacific Assault
    От LUDIA във форум ИГРИ
    Последно: 09-12-04, 22:52
  3. Medal of Honor: Pasific Assault проблемче
    Последно: 30-11-04, 14:24
  4. Medal Of Honor AA
    От Ivo Wolfen във форум ИГРИ
    Последно: 29-10-02, 08:28
  5. Medal Of Honor AA bawnaaa
    От Suren във форум ИГРИ
    Последно: 26-02-02, 05:25
