FUJITSU ASYG09KXCA & ASYG12KXCA
Здравейте. В очакване на европейския вариант на новата Нокрия за България пускам линк към UK сайта:
Split Systems (Air Conditioner) : Wall Mounted - Flagship model nocria™X - FUJITSU GENERAL United Kingdom
Само 2 варианта - 9ка и 12ка, което за мен е леко разочароващо.
Очаквах да има поне 14ка.
Спецификациите за сега:
| Specification | | | ASYG09KXCA | ASYG12KXCA |
| Power source | Phase | Single-phase | Single-phase |
| Voltage | 230 V | 230 V |
| Frequency | 50 Hz | 50 Hz |
| Capacity | Cooling | 2.5 kW(0.6 - 3.5) kW | 3.4 kW(0.6 - 5.3) kW |
| Heating | 3.6 kW (0.6 - 7.1) kW | 5.0 kW (0.6 - 9.0) kW |
| Input Power | Cooling | 0.46 kW | 0.67 kW |
| Heating | 0.63 kW | 1.02 kW |
| EER | Cooling | 5.45 W/W | 5.09 W/W |
| COP | Heating | 5.72 W/W | 4.90 W/W |
| Pdesign | Cooling | 2.5 kW | 3.4 kW |
| Heating (-10°C) | 3.4 kW | 3.5 kW |
| SEER | Cooling | 8.5 W/W | 8.5 W/W |
| SCOP | Heating (Average) | 5.1 W/W | 5.1 W/W |
| Energy Efficiency Class | Cooling | A+++ | A+++ |
| Heating | A+++ | A+++ |
| Max. Operating Current | Cooling | 8.5 A | 9.0 A |
| Heating | 14 A | 16 A |
| Annual Energy Consumption | Cooling | 103 kWh/a | 140 kWh/a |
| Heating | 934 kWh/a | 961 kWh/a |
| Moisture Removal | 1.1 I/h | 1.2 I/h |
| Sound Pressure Level | Indoor (Cooling) | High | 46 dB(A) | 46 dB(A) |
| Middle | 42 dB(A) | 42 dB(A) |
| Low | 38 dB(A) | 38 dB(A) |
| Quiet | 28 dB(A) | 28 dB(A) |
| Indoor (Heating) | High | 48 dB(A) | 48 dB(A) |
| Middle | 43 dB(A) | 43 dB(A) |
| Low | 39 dB(A) | 39 dB(A) |
| Quiet | 30 dB(A) | 30 dB(A) |
| Sound Pressure Level | Outdoor (Cooling) | High | 40 dB(A) | 44 dB(A) |
| Outdoor (Heating) | High | 41 dB(A) | 43 dB(A) |
| Sound Power Level | Indoor (Cooling) | High | 58 dB(A) | 58 dB(A) |
| Indoor (Heating) | High | 62 dB(A) | 62 dB(A) |
| Outdoor (Cooling) | High | 53 dB(A) | 57 dB(A) |
| Outdoor (Heating) | High | 57 dB(A) | 57 dB(A) |
| Air Flow Rate | Indoor | High | 670 m3/h | 670 m3/h |
| Outdoor | High | 1,975 m3/h | 2,230 m3/h |
| Net Dimensions | Height | 293 mm | 293 mm |
| Indoor | Width | 786 mm | 786 mm |
| Depth | 378 mm | 378 mm |
| Net Dimensions | Height | 704 mm | 704 mm |
| Outdoor | Width | 820 mm | 820 mm |
| Depth | 315 mm | 315 mm |
| Net Weight | Indoor | 20 kg (44 lbs) | 20 kg (44 lbs) |
| Outdoor | 41 kg (90 lbs) | 41 kg (90 lbs) |
| Connection Pipe Diameter | Liquid | 6.35 mm | 6.35 mm |
| Gas | 9.52 mm | 9.52 mm |
| Drain Hose Diameter | Indoor | 13.8 mm | 13.8 mm |
| Outdoor | 15.8 to 16.7 mm | 15.8 to 16.7 mm |
| Max Pipe Length (Pre Charge) | 15 (15) m | 15 (15) m |
| Max Height Difference | 10 m | 10 m |
| Operation Range | Cooling | -10 to 43 °CDB | -10 to 43 °CDB |
| Heating | -15 to 24 °CDB | -15 to 24 °CDB |
| Refrigerant | Type | R32 | R32 |
| Global Warming Potential | 675 | 675 |
| Charge | 1,300 g | 1,300 g |
Отговор: FUJITSU ASYG09KXCA & ASYG12KXCA
При тези отоплителни мощности, просто няма смисъл да има модел с 14 и повече в името.
12ката ми е малка за хола.
Ако тя ти е малка, значи хола ти е бая голям и си за две машини, според мен.
много добре ,радва ... Фуджицу ще утрепят другите високи класове особено с една прилична цена
Ако може да се разчита на спецификацията излиза че вътрешното тяло е доста шумно особено на ниските степени.
Дано да има грешка.
Че ще е шумно е ясно - Dual Blaster .То само като им гледам рекламните картинки и ми е шумно. :)
Хол, трапезария, кухня, офис, аз в спалня не бих го сложил.
Само дето на снимката е същото огромно дистанционно като на другите модели :thumbdn:
Тъй като тази информация е налична повече от година, за мен именно цената е причина това чудо на техниката да не се продава по нашите ширини.
Това чудо от Април ще се продава в България.
emil vasilev
Така казват, но ако е вярно и това, че цената ще е около 4000 лв, наистина вече ми е ясно защо не бързат.
Не виждам как ще се продава на тези цени.
Това не е конспирация, а традиция. Повечето фирми започват да продават новите си модели от април всяка година.
ASHG09KXCA - 4300 лв, ASHG12KXCA - 4700 лв. Честито на новите притежатели.....!!!
Това цената на комплекта за тристайно жилище ли е?
Ще ти се..
Тя 200в 40ка е 4к :)
