Продавам звукова карта Creative Audigy 2 ZS. Работи отлично.
За София и страната с куриер.
ЦЕНА: 50 лв.
0899 17 16 68
skype: bg_splitt
ЦЕНА: 50 лв.
0899 17 16 68
skype: bg_splitt
Кутия за HTPC CFI-A8989 Mini ITX. Почти не е употребявана. Има захранване 150W.
http://www.chyangfun.com/products_mini-itx.html
ЦЕНА: 45 лв.
0899 17 16 68
skype: bg_splitt
Продавам нови гъвкави висококачествени преходници (PCI-E risers, extenders) PCI-E x1 към x1 (удължител), както и PCI-E x1 към PCI-E x16 (преходник).
Цена: 20 лв/брой.
0899 17 16 68
skype: bg_splitt
Ново захранване за компютър Powercool 950W. Ефективност 80+. Без гаранция. Не е модулно.
ЦЕНА: 190 лв.
0899 17 16 68 - Николай
skype: bg_splitt
Повече информация:
High Efficiency - 80 Plus Certified
ATi Crossfire & nVidia SLi Ready
Low noise cooling fan system
Multi-Rail Technology
Advanced Thermal & Acoustic Design
EZ Connector System
Multi-GPU support: independent double +12V rails designed specially for dual graphic cards
Multi-Core CPU Support: provides 8-pin 12V CPU support with stable voltage
AMD support: supports the newest Athlon 64 CPU by AMD
Active PFC: enhances utilization of energy
Ventilation: 1 x 12cm fan
Full range: AC full range input
Over Temperature Protection
Short Circuit Protection
Over Voltage Protection
20+4 pin: compatible with all motherboards available on the market
Specifications
Input Range : 230Vac Voltage, 5A Current, 50Hz Frequency
Dimensions : 150 mm x 157 mm x 86 mm (W x D x H)
Retail Box Dimensions : 303 mm x 126 mm x 203 mm (W x D x H)
MTBF : 100k hours
DC Output
Model: PC-950AUBA-B
AC Input: 230V 5A 50Hz
DC Output +3.3V +5V +12V1 +12V2 +12V3 +12V4 -12V +5VSB
Min. Output Current 1.8A 1.0A 0.8A 0.8A 0.5A 1.0A 0.5A 2.5A
Max. Output Current 26A 32A 17A 17A 17A 17A 0.5A 2.5A
Peak Output 245.8W Max
950W
Connections 20+4 Pin Main Connectors: 1
P4 4+4 Pin 12V Connectors: 1
6+2 Pin PCIe Connectors: 2
4-Pin Molex Peripheral Connectors: 5
SATA Connectors: 6
Floppy Drive Connectors: 1
Гледам ти темите и все си мисля, че трябва да прочетеш правилата на форума.
няма цена, няма град, няма контакти
гледам, че си в темата, така че имаш половин час да си я хармонизираш с Правилата
ти не можеш да ги слееш, но можеш да четеш
така че недей да "изключваш" и да лъжеш, че си чел Правилата, защото там ясно е забранено и пускането на повече от 1 (една) активна тема
сливам ти тези и с това приключва периодът ти на новобранец с право на грешки
Леле, какво отношение. Заплахи. Обиди...
Ясно.Няма да пускам повече теми.
