SUPER NOTEBOOK COMPUTER, THE AtomChip® SG22
    Dec 2004
    Feb 2001
    THE REVOLUTION BEGINS
    The notebook does not employ a Hard Disk and is completely based on solid state AtomChip® optoelectronics [except the mechanical Optical Drive: DVD Super Multi].
    The new non-volatile Quantum-Optical RAM increases the speed of the system, since there is no need to refresh information after every cycle of reading of information, unlike regular RAM.
    The new AtomChip® Quantum® II processor with 256MB on-board memory has a high speed with very low consumption of electrical energy.
    This notebook has a wireless function, high CPU speed and large memory capacity with extremely low power consumption. Absence of the hard disk increases system stability under low temperatures, vibration and acceleration.
    Voice Command!
    That lets you use your voice to look up e-mails, contacts, get calendar information, play and control your music or video, and launch programs.
    THIS PRODUCT OPENS A NEW ERA IN THE CONSUMER ELECTRONICS INDUSTRY!
    SPECIFICATION:
    Processor: 6.8GHZ CPU (AtomChip® Quantum® II processor / System Compliance: Two Operating Systems with Voice Command (Microsoft® Windows® XP Professional and Linux®) / PROMT-Translator (8 languages) / /Memory: 1TB Quantum-Optical non-volatile RAM (NvIOpSRAM-SODIMM 200-pin) / Storage: 2TB non-volatile Quantum RAM (NvIOpRAM-ATA IDE) / Optical Drive: DVD Super Multi / LCD Display: 12.1” WXGA (1280 x 800, 16:10) TFT Glare Type LCD display with 1.3 Mega pixel CMOS camera / Video & Graphics: Two Integrated graphic controllers [Intel®855GME internal graphics, support Intel® DVMT (Dynamic Video Memory Technology) and AtomChip® DVM (Dynamic Video Memory)] / Communication: 10/100 Base-T LAN on board, MDC Fax/Modem V.90/V.92 on Board, 802.11a/802.11b/802.11g WLAN, Intel® PRO/Wireless 2100/2200BG/2915ABG network connection, WiFi, Bluetoth, GPRS -with Bluetoth antena, CMOS camera with USB interface, Mega pixel resolution CMOS image / Pointing Device: Synaptics touchpad with 4 way scrolling button / Application Launch Key: E-mail, Internet, Capture, WLAN / LED Status Indicator: Power, Suspend/Resume, Battery Charging Status, Quantum Storage Access, Num Lock mode, Caps Lock mode, Scroll Lock mode, WLAN Lock mode / Keyboard: 3.0mm travel, inverted-T, 88keys with 2 windows key (Internet & Microsoft For Connectivity) / Interface Ports Front Side: One 4-in-1 card reader slot (support SDIO/SD/MS Pro/MS), Audio line out, Stereo Microphone-in / Interface Ports Left Side: LAN port, Modem port, SVGA–out port, One Type II PCMCIA slot (support CardBus), 1394A port (mini jack) / Interface Ports Right Side: USB 2.0 ports x 3 / Interface Port Rear Side: DC-in, Kensington Lock / Audio: Built-in two stereo speakers and Built-in Microphone / AC Adapter (Input: 100-240V AC, 50-60Hz, 1.5A. Output: 20V DC, 2.5A, 50W) / Battery: 6 cell Li-lon battery pack. Battery Charge: 3 hrs charge time to 100% capacity while system off and 4 hrs charge time while system on. Battery Life: Approximately 8 hours for AtomChip® Quantum® II processor and 3 hours for 4 x Intel® Pentium® M processors 1.7CHz / BIOS: AMI, Support PnP, password, Bootable from USB and DVD / Power Management: ACPI 2.0 compliance / Smart Battery System Support / Security: Kensington Lock / Size: 320.0(W) x 242.0(D) x 22.0(H)mm/28.0mm (front/back) / Weight: 1.9kg(when fully equipped with AtomChip® Quantum® II processor) and 2,20kg(when fully equipped with 4 x Intel® Pentium® M processors) / Packing Accessories: Quick Guide, Support CD (Driver, Utility, Manual), AC Adapter, Power Cord, Battery Pack, BOSE Headphone Music System with noise Cancelling.
    Източник и цялата новина : http://atomchip.com/_wsn/page4.html
    Интересни са ми коментарите Ви...
    Aug 2002
    Re: SUPER NOTEBOOK COMPUTER, THE AtomChip® SG22
    Беше време и при нас да се появи
    цялата технология е разработена на принципа" ефектка на Телдин върху силиция "
    Интересното което чух е че тази твехниология не може да се копира , - автора е поставил киселинни резервоари ,с датчик , които засеча всякакви гама лъчи и ако ги засече - киселината пада върху чипа и го унижожава - интересно "патентоване" вместо да води дела с години с intel & AMD човека си е решил проблема
    процесора е абсолютно неизвестен ( името му е съвпадение с името на придобилата лоша слава фирма )
    паметта и харда работят на един принцип - принципа на оптичните у-ва , само че със силициеви плочи , които са n-пъти по-бързи от досегашните технологии.
    повече инфо www.hardwaresight.com
    Mar 2003
    Да, да и един мърмот завиваше шоколада в станиол..... Абсолютен "фейк". Първото, което ми се набива на очи е как така уиндоус експи поддържа 1TB!!! РАМ? ХА ха...
    Jan 2002
    Ще засече баба ми с тия фото елементи.
  7. Senior Member Аватара на Wise
    Oct 2004
    Обикновено настолните компютри са на върха на технологиите. Преносимите винаги крачат зад тях. Тези цени и за настолен с тези параметри са ниски. И кой ще тръгне да прави преносим преди настолен?? Та военните, а и не само те биха закупили огромно количество от такива "щайги"
    Нещо май си е бъзик - Терата още не е на мода, особено за малките.........компютри. Но звучи добре.... c:
    Jan 2001
    вижте и другите страници... на едната се опитват да ни продадат жак за слушалки като... някаква преносима памет беше, ако не се лъжа...
    Nov 2004
    Накратко в линкове:
    http://atomchip.com/_wsn/page4.html - на английски; разгледайте* в последната картинка: паметта (отбелязано в предишните мнения), ореола около надписа AtomChip, десетичната запетайка, разделите между хилядите, това "Перевод" горе вдясно;
    http://cesweb.org/attendees/director...?exhibid=7059& - на английски; погледнете адресите за контакт;
    http://www.ecs.com.tw/ECSWeb/Product...=Specification - на английски; нормално е да си приличат, те и имената са им почти същите; тук се вижда по-ясно - http://www.stormst.com/img/g220w_640.jpg;
    http://forum.ixbt.com/topic.cgi?id=8:19645 - на руски; форумни коментари;
    http://www.ixbt.com/dvd/ces2005-2.shtml - на руски; този пък е виждал предишната версия -- ами да, даже са и наградени - http://www.cesweb.org/attendees/awar...sp?category=48;
    http://www.museumofhoaxes.com/hoax/w...ebook_computer - на английски; толкова млада тема, а вече в музея;
    http://www.theregister.com/2005/09/0...racle_machine/ - на английски; стигнахме и до българската връзка - http://www.compu-technics.com/images/158_IMAGE043.JPG.
    Интересно каква е крайната цел -- някой само се шегува или нещо ще се рекламира?
    Apr 2005
    Re: Погледнете какво компютърче....
    М-да - кога ли ще е на mass-market-a?
    Aug 2005
    1.Най-много си харесах оптичната памет от тип стерео жак )
    2.както и залепената с дъвка за процесора леща от цд
    3.ама и конференцията на пластмасови столчета(тип квартална баничарница) си я бива де
    4.ако се вгледа човек в картинките забелязва и един прекрасен АМИ БИОС от 1999
    5.и ако още повече се вгледа ще забележи, че цоклите са за 2.2волта а паметта работина 1.4(според лепенката, която е залепена накриво)
    6.и т.н.
  1. Отговори: 50
    Последно: 02-11-14, 21:31
  2. TOSHIBA 13 PKVP-E Super Daiseikai 5 или TOSHIBA 13 SKVP2-E Super Daiseikai6
    От MisterT във форум Климатици Toshiba, Carrier
    Отговори: 63
    Последно: 28-01-14, 11:35
  3. my Computer
    От tannoy във форум Поддръжка
    Последно: 13-02-10, 14:24
  4. Изтрих My Computer !!!
    От hristobotev във форум Windows
    Последно: 06-02-09, 17:24
  5. Turn Off Computer
    От Daskala във форум Общ - софтуер
    Последно: 19-03-04, 23:20
