Внимавайте с SP1!
Инфото е по-долу! но не го инсталирайте докато го проверя...
В противен случай ако сте с Corparate, ще се активирате набързо...
§§§§§§ [cOMMENTS] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
§ Yay! Its Windows XP Service Pack 1 §
§ Works on both Professional and Home Edition §
§ THE DEVILS0WN CD KEY AND/OR THIS KEY: §
§ FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8 WILL NOT WORK! READ BELOW §
§ ON HOW TO CHANGE YOUR CD KEY! §
§ See http://www.microsoft.com for more details! §
§ Thanks to #betas on irc.betas-online.com for the §
§ original file... §
§ 1 more thing. PRINT this nfo out. You'll need it! §
§§§§§§ [iNSTALL nOTES] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
§ Read READMESP.HTM for more info... §
§ Run update.exe from the Update dir to INSTALL! §
§ Do NOT run deactivate.reg unless I told you to do so. §
§ DO THIS ONLY IF U ARE USING DEVILS0WN WIN XP PRO!!!!! §
§ DO THIS IF U ARE USING FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8 §
§ DO NOT DO THIS IF U ARE NOT USING WINDOWS XP PRO!! §
§ Er, its a bit hard... But... Oh well... Here goes! §
§ 0. Run a system resore to create a new checkpoint in §
§ case you need it. §
§ 1. Run deactivate.reg to deactivate the current §
§ activation... §
§ 2. Choose run from start menu and type in this command: §
§ %systemroot%\system32\oobe\msoobe.exe /a to get the §
§ activation screen and go to the second option which is §
§ activate by phone. §
§ 3. In the new screen choose the option to change product §
§ key, and type in the new product key (your Corporate one §
§ only). K2KB2-BDBGV-KP686-D8T7X-HDMQ8 §
§ 3a. If it brings you back to the prior screen after §
§ entering the new key click remind me later and then §
§ reboot. §
§ 4. Close that window, reboot your system and enter the §
§ command in step 2 for the second time to verify your §
§ activation , you should see "windows is already §
§ activated". §
§ 4a. Now install SP1 §
§ 5. If you have done this wrong or without a valid key §
§ you will not be able to boot. hit F8 and select last §
§ known good configuration §
§ Thanks to whoever you are for the key and BigFoot for §
§ the tutorial and hot_wired13 for the regfile... §
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
