Windows XP ServicePack1 Build 1063... ЧЕТЕТЕ ВАЖНО
  Внимавайте с SP1!
Инфото е по-долу! но не го инсталирайте докато го проверя...
В противен случай ако сте с Corparate, ще се активирате набързо...
     §§§§§§ [cOMMENTS] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
     §  Yay! Its Windows XP Service Pack 1                       §
     §  Works on both Professional and Home Edition 		 §
     §  THE DEVILS0WN CD KEY AND/OR THIS KEY:			 §
     §  FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8 WILL NOT WORK! READ BELOW  §
     §  ON HOW TO CHANGE YOUR CD KEY! 				 §
     §  See http://www.microsoft.com for more details!           §
     §  Thanks to #betas on irc.betas-online.com for the         §
     §  original file...					 §
     §  1 more thing. PRINT this nfo out. You'll need it!	 §
     §§§§§§ [iNSTALL nOTES] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
     §  Read READMESP.HTM for more info...			 §
     §  Run update.exe from the Update dir to INSTALL!		 §
     §  Do NOT run deactivate.reg unless I told you to do so.    §
     §  DO THIS ONLY IF U ARE USING DEVILS0WN WIN XP PRO!!!!!    §
     §  DO THIS IF U ARE USING FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8     §
     §  DO NOT DO THIS IF U ARE NOT USING WINDOWS XP PRO!!	 §
     §  Er, its a bit hard... But... Oh well... Here goes!       §
     §  0. Run a system resore to create a new checkpoint in     §
     §  case you need it.				   	 §
     §  1. Run deactivate.reg to deactivate the current 	 §
     §  activation...						 §
     §  2. Choose run from start menu and type in this command:  §
     §  %systemroot%\system32\oobe\msoobe.exe /a to get the	 §
     §  activation screen and go to the second option which is   §
     §  activate by phone.					 §
     §  3. In the new screen choose the option to change product §
     §  key, and type in the new product key (your Corporate one §
     §  only). K2KB2-BDBGV-KP686-D8T7X-HDMQ8			 §
     §  3a. If it brings you back to the prior screen after      §
     §  entering the new key click remind me later and then	 §
     §  reboot.							 §
     §  4. Close that window, reboot your system and enter the   §
     §  command in step 2 for the second time to verify your     §
     §  activation , you should see "windows is already      	 §
     §  activated".						 §
     §  4a. Now install SP1					 §
     §  5. If you have done this wrong or without a valid key	 §
     §  you will not be able to boot. hit F8 and select last	 §
     §  known good configuration 				 §
     §	Thanks to whoever you are for the key and BigFoot for 	 §
     §  the tutorial and hot_wired13 for the regfile...		 §
  Инсталацията мина безупречно по горната схема...
ето го REG file-a:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WPAEvents]
"OOBETimer"=hex:ca,00,00,00,00,00,00,00,00,00,00,00
  Аз вчера си го инсталнах по описания начин и си тръгна.
Нали имаше някаква тема преди как да се смени номера-това е явно начина.
  A има ли въобще смисъл да се качва SP1?!?
<-- AMD Inside -->
EPoX 8K3A, AXP 1920MHz 10x192MHz + Watercooling, 128MB DDR333 KingMAX333, ATi RADEON8500 128MB DVI 300@255, 40GB Seagate BIV + 40GB Maxtor D540X, ASUS 16x DVD, Enlight EN-7237 Case + 400W Enlight PSU, 17" ReliSYS FLAT
  Ако това, което се разпространява като SP1 има достатъчна прилика с това, което ще бъде официалния SP1 няма начин да няма смисъл...
Егати изречението спретнах :)
Ми питай microsoft :)
Щото се излъгах да кача Hot Fixes и ми скапа Media Player-a за назидание......
<-- AMD Inside -->
  <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Щото се излъгах да кача Hot Fixes и ми скапа Media Player-a за назидание......<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
i na tebe li <img src=icon_smile_big.gif border=0 align=middle>
  E това е Service Pack. Оправя някои грешки ама и добавя нови. Това го меже само MS.
 http://julmin.hit.bg
  pod koshcheto mi se poiavi edin nadpis
kak da go mahna
pishe che windows-a mi e za testvane..........
  I kakvo pishe po tochno...
Znaq pove4e otkolkoto si misli6
  vzel si versija 2600 beta..zatova ti go pishe... ->>[1068_xpsp1.exe]
Ako beshe s 1050 njamashe da go pishe... (ima go v warezbg)
no veche moje bi e kusno... (shte chakash release)
Pokazva:
 Windows XP Professional
For testing purposes only.Build 2600.xpsp1.020628-1905()
Edited by - DeathKnight на 09/07/2002  16:50:29
  koe mi e beta :
windowsa ili SP1 ?
  Za SP sys sigurnost, a i nai-verojatno XP-to systo
  mislia si che ne e beta winXP-to
kazete mi kak da razbera
