Резултати от 1 до 5 от общо 5
Американски хумор
    Apr 2002
    Американски хумор
    Eto wi malko da se posmeete:
    Network feed to TV.
    Hi,
    I work at Walmart and I have a network cable (Cat5 I think) that has a games preview feed. I need a way to run these on a TV that has a coaxial conection.
    Can you please help me?
    xxxxx
    Comment from xxxxxxxxx on 08/22/04:
    All I have is the network cable to work with; it needs to be change to a coaxial connection someway to be connected to the TV.
    No PC is involved. The feed is from servers in the back of the store.
    I need to change a network cable connection to coaxial.
    Thanks for any help
    Jan 2001
    Американски хумор
    искам да знам какво са му отговорили на тоя ****** и как са му "помогнали" []. не че всеки е длъжен да знае и разбира, но се получава весело, когато неспециалист прави допускания
    Apr 2002
    Американски хумор
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">искам да знам какво са му отговорили на тоя ****** и как са му "помогнали" []. не че всеки е длъжен да знае и разбира, но се получава весело, когато неспециалист прави допускания
    <div align="right">Originally posted by FearMe*-*23/08/2004*:* 21:34:42</div id="right">
    Ami moyat otgovor be6e v smisul na NO WAY bez da mine prez PC s tv out (kakuvto i da e - ima na razpolojenie cyala gama ot internal, external and so one) ama nali vijda6 - 4oveka si e postnal commenta...[:D]
    a drugiyat eto go - ne6to e mnogo muglyav ... ama vse pak:
    Answer 3:
    I cant imagin this would be an analog signal on a cat 5 cable, not one that comes for any considerable distance, the signal would leak out all over the place and garbage would dribble out the end. It must be a digital signal of sorts and if its encapsulated in some frame format, then some interface that would do the codex will be needed between the line and the coax connector. If it is an analog signal, lets say, channel 3, you can get a .50 75ohm adapter that you can screw down the hot pair and plug into the coax receptical on the TV.
    Jan 2001
    Американски хумор
    я гледай ти. дори и думи като "гaлфoн" се коригирали автоматично []
    а иначе answer 3 няма нищо общо с проблема на човека. той иска да гледа games preview на телевизора, без да отчита, че приликата между информацията, постъпваща в tv-то, и тази, постъпваща в pc-то, има толкова общо, колкото мотиката и тостера имат нещо общо.
    решението му се нарича "internet tv". за пръв път го видях серийно производство и достъпно за всеки в берлин, 2000г, на технологичния панаир. там вече ще може да тикне всякакъв кабел и да гледа всичко, що душа му сака
  6. Senior Member Аватара на ru-boy
    Jan 2000
    Американски хумор
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">я гледай ти. дори и думи като "гaлфoн" се коригирали автоматично []
    <div align="right">Originally posted by FearMe*-*24/08/2004*:* 00:06:12</div id="right">
    ... грижим се за цензурата с малко усилия, но редовно ... [:D]
  1. Апокрифният хумор от 80-те - откъде?
    От roumen68 във форум Музика, филми и театър
    Последно: 12-07-21, 20:58
  2. Чуството за хумор на Техномаркет Европа
    От hristobotev във форум Дъра-Бъра
    Последно: 09-01-09, 10:40
  3. "Mr. & Mrs. SMITH" - 'Той и Тя', по Американски :)
    От IvO™ във форум Музика, филми и театър
    Отговори: 21
    Последно: 05-08-05, 15:22
  4. Имате ли чувство за хумор?
    От skynet във форум Дъра-Бъра
    Последно: 25-11-04, 23:49
  5. Малка почивка и глътка хумор
    От fori във форум Linux
    Последно: 17-03-03, 15:01
