Компютъра ми се сканира постоянно от някакви ип-та. Ако изключа защитната стена генерира трафик на лан картата 20%от100мб а ако я вкюча тя блокира тези сканове но процесора се товари на 30%. Сложих рутер зад които се скрих и сега няма проблеми на моя компютър, но вижте лог файла на рутера ......
System Logs
Tue Feb 27 16:02:05 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
Tue Feb 27 16:02:07 2007 Unrecognized attempt blocked from 82.146.28.108:2231 to 89.186.193.88 TCP:18476
Tue Feb 27 16:02:08 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
Tue Feb 27 16:02:14 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
Tue Feb 27 16:02:37 2007 Unrecognized attempt blocked from 89.186.195.36:3036 to 89.186.193.88 TCP:135
Tue Feb 27 16:02:40 2007 Unrecognized attempt blocked from 84.21.218.41:4144 to 89.186.193.88 TCP:18476
Tue Feb 27 16:02:47 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
Tue Feb 27 16:02:49 2007 Unrecognized attempt blocked from 84.21.218.41:4144 to 89.186.193.88 TCP:18476
Tue Feb 27 16:02:50 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
Tue Feb 27 16:02:56 2007 Unrecognized attempt blocked from 82.146.27.70:54853 to 89.186.193.88 TCP:14308
Tue Feb 27 16:02:56 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:17 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:20 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:26 2007 Unrecognized attempt blocked from 82.119.66.232:2333 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:26 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:32 2007 Unrecognized attempt blocked from 82.146.27.70:56954 to 89.186.193.88 TCP:14308
Tue Feb 27 16:03:47 2007 Unrecognized attempt blocked from 82.146.28.108:3007 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:50 2007 Unrecognized attempt blocked from 82.146.28.108:3007 to 89.186.193.88 TCP:18476
Tue Feb 27 16:03:59 2007 Unrecognized attempt blocked from 82.146.27.70:58188 to 89.186.193.88 TCP:14308
Tue Feb 27 16:04:32 2007 Unrecognized attempt blocked from 82.119.66.232:2469 to 89.186.193.88 TCP:18476
Tue Feb 27 16:04:37 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
Tue Feb 27 16:04:40 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
Tue Feb 27 16:04:46 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
Tue Feb 27 16:04:56 2007 Unrecognized attempt blocked from 82.146.27.70:61535 to 89.186.193.88 TCP:14308
Tue Feb 27 16:05:02 2007 Unrecognized attempt blocked from 82.146.27.70:61535 to 89.186.193.88 TCP:14308
Tue Feb 27 16:05:07 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:10 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:14 2007 Unrecognized attempt blocked from 82.146.27.70:62572 to 89.186.193.88 TCP:14308
Tue Feb 27 16:05:16 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:37 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:40 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:46 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
Tue Feb 27 16:05:59 2007 Unrecognized attempt blocked from 82.146.27.70:64957 to 89.186.193.88 TCP:14308
Tue Feb 27 16:06:07 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
Tue Feb 27 16:06:10 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
Tue Feb 27 16:06:16 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
Tue Feb 27 16:06:20 2007 Unrecognized attempt blocked from 82.146.27.70:49694 to 89.186.193.88 TCP:14308
Tue Feb 27 16:06:40 2007 Unrecognized attempt blocked from 82.146.28.108:4353 to 89.186.193.88 TCP:18476
Tue Feb 27 16:06:46 2007 Unrecognized attempt blocked from 82.146.28.108:4353 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:07 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:07 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:10 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:10 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:16 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:16 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:37 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:40 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
Tue Feb 27 16:07:46 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
Tue Feb 27 16:08:00 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
Tue Feb 27 16:08:07 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
Tue Feb 27 16:08:09 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
Tue Feb 27 16:08:10 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
Tue Feb 27 16:08:16 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
Tue Feb 27 16:08:19 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
Tue Feb 27 16:08:47 2007 Unrecognized attempt blocked from 82.146.27.70:57308 to 89.186.193.88 TCP:14308
Tue Feb 27 16:08:47 2007 Unrecognized attempt blocked from 82.146.28.108:1350 to 89.186.193.88 TCP:18476
Tue Feb 27 16:08:50 2007 Unrecognized attempt blocked from 82.146.28.108:1350 to 89.186.193.88 TCP:18476
Tue Feb 27 16:09:05 2007 Unrecognized attempt blocked from 82.146.27.70:58412 to 89.186.193.88 TCP:14308
Tue Feb 27 16:09:14 2007 Unrecognized attempt blocked from 82.146.27.70:58412 to 89.186.193.88 TCP:14308
Tue Feb 27 16:09:17 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
Tue Feb 27 16:09:20 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
Tue Feb 27 16:09:26 2007 Unrecognized attempt blocked from 82.146.27.70:59528 to 89.186.193.88 TCP:14308
Tue Feb 27 16:09:26 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
Tue Feb 27 16:09:35 2007 Unrecognized attempt blocked from 82.146.27.70:59528 to 89.186.193.88 TCP:14308
Tue Feb 27 16:09:36 2007 Unrecognized attempt blocked from 82.119.66.232:3095 to 89.186.193.88 TCP:18476
Tue Feb 27 16:09:50 2007 Unrecognized attempt blocked from 82.146.27.70:60847 to 89.186.193.88 TCP:14308
това е една много малка част от него.
И така е постоянно от около месец!!!
Помислих че е вирус и преинсталирах Уиндоуса, но и това не помогна!
С trace route успях да проследя ип-то и стигнах до http://medicom-bg.net/ , но само един път успях сега като пингвам ип-то нищо не ми излиза.
Дайте някакви идеи за решение на проблема.
