Резултати от 1 до 15 от общо 27
Странен проблем с интернет!
    Jan 2004
    Компютъра ми се сканира постоянно от някакви ип-та. Ако изключа защитната стена генерира трафик на лан картата 20%от100мб а ако я вкюча тя блокира тези сканове но процесора се товари на 30%. Сложих рутер зад които се скрих и сега няма проблеми на моя компютър, но вижте лог файла на рутера ......
    System Logs
    Tue Feb 27 16:02:05 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:02:07 2007 Unrecognized attempt blocked from 82.146.28.108:2231 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:02:08 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:02:14 2007 Unrecognized attempt blocked from 82.146.27.70:52542 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:02:37 2007 Unrecognized attempt blocked from 89.186.195.36:3036 to 89.186.193.88 TCP:135
    Tue Feb 27 16:02:40 2007 Unrecognized attempt blocked from 84.21.218.41:4144 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:02:47 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:02:49 2007 Unrecognized attempt blocked from 84.21.218.41:4144 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:02:50 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:02:56 2007 Unrecognized attempt blocked from 82.146.27.70:54853 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:02:56 2007 Unrecognized attempt blocked from 82.146.28.108:2523 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:17 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:20 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:26 2007 Unrecognized attempt blocked from 82.119.66.232:2333 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:26 2007 Unrecognized attempt blocked from 82.146.28.108:2777 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:32 2007 Unrecognized attempt blocked from 82.146.27.70:56954 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:03:47 2007 Unrecognized attempt blocked from 82.146.28.108:3007 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:50 2007 Unrecognized attempt blocked from 82.146.28.108:3007 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:03:59 2007 Unrecognized attempt blocked from 82.146.27.70:58188 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:04:32 2007 Unrecognized attempt blocked from 82.119.66.232:2469 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:04:37 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:04:40 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:04:46 2007 Unrecognized attempt blocked from 82.146.28.108:3430 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:04:56 2007 Unrecognized attempt blocked from 82.146.27.70:61535 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:05:02 2007 Unrecognized attempt blocked from 82.146.27.70:61535 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:05:07 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:10 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:14 2007 Unrecognized attempt blocked from 82.146.27.70:62572 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:05:16 2007 Unrecognized attempt blocked from 82.146.28.108:3654 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:37 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:40 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:46 2007 Unrecognized attempt blocked from 82.146.28.108:3872 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:05:59 2007 Unrecognized attempt blocked from 82.146.27.70:64957 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:06:07 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:06:10 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:06:16 2007 Unrecognized attempt blocked from 82.146.28.108:4099 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:06:20 2007 Unrecognized attempt blocked from 82.146.27.70:49694 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:06:40 2007 Unrecognized attempt blocked from 82.146.28.108:4353 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:06:46 2007 Unrecognized attempt blocked from 82.146.28.108:4353 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:07 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:07 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:10 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:10 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:16 2007 Unrecognized attempt blocked from 82.146.28.108:4585 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:16 2007 Unrecognized attempt blocked from 88.203.240.12:2397 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:37 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:40 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:07:46 2007 Unrecognized attempt blocked from 82.146.28.108:4796 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:08:00 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
    Tue Feb 27 16:08:07 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:08:09 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
    Tue Feb 27 16:08:10 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:08:16 2007 Unrecognized attempt blocked from 82.146.28.108:1068 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:08:19 2007 Unrecognized attempt blocked from 88.203.240.12:17241 to 89.186.193.88 UDP:18476
    Tue Feb 27 16:08:47 2007 Unrecognized attempt blocked from 82.146.27.70:57308 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:08:47 2007 Unrecognized attempt blocked from 82.146.28.108:1350 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:08:50 2007 Unrecognized attempt blocked from 82.146.28.108:1350 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:09:05 2007 Unrecognized attempt blocked from 82.146.27.70:58412 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:09:14 2007 Unrecognized attempt blocked from 82.146.27.70:58412 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:09:17 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:09:20 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:09:26 2007 Unrecognized attempt blocked from 82.146.27.70:59528 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:09:26 2007 Unrecognized attempt blocked from 82.146.28.108:1584 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:09:35 2007 Unrecognized attempt blocked from 82.146.27.70:59528 to 89.186.193.88 TCP:14308
    Tue Feb 27 16:09:36 2007 Unrecognized attempt blocked from 82.119.66.232:3095 to 89.186.193.88 TCP:18476
    Tue Feb 27 16:09:50 2007 Unrecognized attempt blocked from 82.146.27.70:60847 to 89.186.193.88 TCP:14308
    това е една много малка част от него.
    И така е постоянно от около месец!!!
    Помислих че е вирус и преинсталирах Уиндоуса, но и това не помогна!
    С trace route успях да проследя ип-то и стигнах до http://medicom-bg.net/ , но само един път успях сега като пингвам ип-то нищо не ми излиза.
    Дайте някакви идеи за решение на проблема.
    Dec 2000
    Re: Странен проблем с интернет!
    Не виждам в момента да има проблем, който трябва да се решава. Какво точно те притеснява?
    Jan 2004
    Компютъра ми ПОСТОЯННО се сканира от някакви несъществуващи ип-та, а и немога да бъда постоянно зад рутер.
    Dec 2000
    Аха! Значи идентифицирахме истинския проблем: не можеш постоянно да си зад рутер. Сега вече е доста по-вероятно да се намири решение.
    Преди това ще трябва да обясниш защо не може постоянно да ползваш рутер.
    Jan 2004
    Защото интернет доставчикът към който съм не разрешава употребата на рутери.
    May 2004
    Кажи на доставчика ти да ходи да се гръмне некъде...
    Какво го бърка него ти какво ще ползваш?
    Jan 2004
    Проблема не ми е в доставчика!
    А в това
    System Logs
    Ако някой има представа от какво се получава да пише.
    Dec 2000
    Няколко решения, които ми идват на пръв поглед:
    1) Не спазваш договора и ползваш рутер
    2) Обясняваш проблема на доставчика и той ти разрешава да ползваш рутер (илк предлага друго решение)
    3) Сменяш доставчика с такъв, който разрешава рутер
    4) Купуваш по-мощен компютър, който не си товари 30% от процесора за firewall-а
    5) Сменяш firewall-a с такъв, който иска по-малко ресурси
    Въпреки че точка 5 изглежда най-лесна, имай предвид, че доста често се срещат сериозни проблеми при деинсталацията на firewall. По някога се налага преинсталирането на целия Windows. Допълнителен въпрос: Ако си с Windows XP защо не ползваш вградения firewall?
    Dec 2000
    "Това" се получава, защото наистина те сканират. Така е в Интернет. Нормално е и не можеш да спреш когото и да било да сканира машина с реален ИП адрес в Интернет. Това, което може да се направи, ти вече си го пробвал: скриваш компютъра зад рутер или му включваш firewall. След като си пробвал тези варианто, остава да избереш най-подходящата комбинация за конкретния случай.
  12. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    Пробвай Avast за антивирусна, ако не си с нея. Тя има някакви вградени защити за подоби случаи.
    Feb 2006
    Я да се пробвам и аз... Случааайно да ползваш торент клиент?
    Портовете ти, на които се опитват да се вържат са два-три, което ме навежда на мисълта че НЕ те сканират умишлено, а различни пиъри се опитват да се вържат към торент клиента ти и рутера ти ги реже. Когато беше със защитна стена, тя не ти ли казваше кое приложение слуша на тези портове?
    Jan 2004
    Прав си порта на който ми работи Биткомета е 18476.
    Но защо тези пиъри се опитват от един месец да се свържат.
    И защо като нямам защитна стена през ланкартата ми минава трафик без да съм пуснал Биткомета.
    Dec 2000
    Техните клиенти са те запомнили като peer и се опитват да точат...Изпращат ти пакети в опит да осъществат сесия...
    May 2001
    Цитат Първоначално публикувано от kobra
    Я дай малко по-подробно, какъв трафик засичаш и с какво.
    Dumeter ли ползваш? Ако виждаш трафик постоянен от порядъка на 30-40 килобайта без да си пуснал някакъв трансвериращ софтуер (има вариaнт ако имаш skype да работи в режим на сървър и да минава трафик на други ползващи skype), това са броадкастите от калпавите суичове на доставчика, които работят в режим на хъб заради малкия си арп кеш (предполагам че си по етрнет с tcp/ip а не с pppoe) :-)
    Още, Dumeter показва постоянен трафик при някои модемни връзки, като пример кабелен модем към интернет по телевизионния кабел но при теб явно не е такъв случая.
    Свали си tcpview от сайта на sysinternals.com (може би вече е собстванност на microsoft) и провери точно кой прави трансфера.
    Цитат Първоначално публикувано от Ghost
    Тази подробност не ми е известна. Всеки клиент ли се държи по този начин?
  1. Отговори: 4
    Последно: 05-11-11, 17:02
  2. Странен проблем Win 7
    От beretta92sd във форум Windows
    Отговори: 29
    Последно: 13-08-11, 08:01
  3. Отговори: 1
    Последно: 07-06-09, 20:10
  4. Странен проблем
    От bx във форум Общ - хардуер
    Последно: 14-02-06, 17:59
  5. Странен проблем
    От Whiskey във форум Windows
    Последно: 04-07-05, 18:30
