Overview of remote access
By configuring Routing and Remote Access to act as a remote access server, you can connect remote or mobile workers to organization networks. Remote users can work as if their computers are physically connected to the network.
Users run remote access software and initiate a connection to the remote access server. The remote access server, which is a server running Routing and Remote Access, authenticates users and services sessions until terminated by the user or network administrator. All services typically available to a LAN-connected user (including file and print sharing, Web server access, and messaging) are enabled by means of the remote access connection.
Remote access clients use standard tools to access resources. For example, on a server running Routing and Remote Access, clients can use Windows Explorer to make drive connections and to connect to printers. Connections are persistent: Users do not need to reconnect to network resources during their remote sessions. Because drive letters and universal naming convention (UNC) names are fully supported by remote access, most commercial and custom applications work without modification.
