Key Benefits of Paragon Net Burner:
Easy-to-use even for inexperienced users
User-friendly wizards will help you to mount (or remove) a remote optical drive in only a few clicks. Access the mounted drives no differently than your local devices.
Extremely useful for notebooks without optical drive
Paragon Net Burner is a great solution for notebook users who have no optical drive onboard (subnotebooks, netbooks, ultraportable laptops). Mount a CD/DVD/BD drive located on another machine in your local network and grab, record or master CDs/DVDs/BDs without having these devices locally. Net Burner is must-have for home users who have both subnotebook(s) and PCs – now you can forget about tiresome transferring of files from one PC to another just so you can burn them.
With Net Burner, if you take your subnotebook on a business trip, you can burn CD/DVD/BD discs using another PC.
Cost-effective for office network, internet-café etc.
With Paragon Net Burner there is no need to have an expensive HD-DVD/BD drive on every machine in the office, internet-café or any other network. It is enough to have only one device of this type, and share it all over the network.
Ideal for backing up data to a remote CD/DVD/BD
Paragon Net Burner is an excellent addition to the Paragon’s products (such as Hard Disk Manager, Drive Backup etc.) that lets you back up data from your PCs, workstations or servers to a remote CD/DVD/BD.
Compatible with the most of burning software and hardware
Paragon Net Burner supports a wide variety of burning software and hardware. It is compatible with 32-bit and 64-bit Microsoft Windows 2000/XP/2003/2008/Vista, so you can use Windows' built-in burning software.
To get maximum burning features, see our latest burning solution, Paragon Easy CD/DVD Recorder 9.0.
If you already use third-party software and are satisfied with it, you can continue using it together with Net Burner.
Great performance in all operations
Net Burner consists of two components: the Server (a full-featured software-only iSCSI Target) and the Client (an iSCSI and ATA-over-Ethernet initiator). Paragon Net Burner Server has a matching "domestic" iSCSI Initiator called Paragon Net Burner Client. This combination provides unbeatable performance compared to the Microsoft iSCSI Initiator and third-party iSCSI targets.
