Пратих го на пощата ти. От линка теглиш като чукваш по избор на някой от заградените места (виж снимката) :
Ето упътването за флашване в оригинал:
Код:
....Hello,
please find attached the firmware update.
Our technican tested the main function, but it was not possible to test the cyrilic subtitles.
Installing the firmware update:
you need to extract the zip or winrar file
- it will create a folder
- that folder will be copied on the MediaPlayer main root
- after that, plug the player on TV and go to the folder of latest firmware
- and the firmware will be automatically uploaded.
best regards..........
