Emprex ME1 High Definition Multimedia Enclosure
попаднах в нета на това мултимедийно устройство, изглежда е от семейството на Realtek.
Дали случайно някой от Вас не притежава такова, ако може да сподели впечатления.
А между временно ето малко повече данни за самото устройство:
 http://www.emprex.com/var/product/ME1-packing-s520.jpg
 http://www.emprex.com/userimages/ME1-note.jpg
 Сайт на производителя: http://www.emprex.com/02_products_02.php?id=210
 Марка: Emprex
 Модел: ME1
 Тип: High Definition Multimedia Enclosure
 Функции: Play music, high resolution photo, and HD video
Browse photo with background music playing
One Touch Record and Time-shift input video from AV-in port
Upscale video quality to NTSC/PAL progressive scan, 720p, or 1080i
Stream file from PC in the LAN through Ethernet port
Play file firm USB storage device, and USB card reader through USB 2.0 Host port
As an external USB HDD of PC through USB Device port
Support both NTSC and PAL video in and video out
Support various multimedia formats
Support 3.5” IDE type HDD
 Спецификации:
 Model No. ME1
 Physical Dimension: Height: 126.6 mm x Depth: 192.5 mm x Width: 44.3mm
 Weight: 0.63 Kg (without Hard disk drive)
 Playback Format:
 Audio: MP3, WMA, PCM
 Video: MPEG 1/2, DivX HD, DivX 3.11, 4.12, 5, 6 ; AVI, VOB, MPG, DAT, Xvid
 Picture: JPG, BMP
 Subtitle: SRT
 Remote Control: IR remote control
 Audio Out: 2 channels output
 Video Out: Component: Y, Pb, Pr (NTSC/PAL, NTSC/PAL progressive scan, 720p, 1080i), Composite video out (NTSC/ PAL)
 Audio In: 2 channels stereo input
 Video In: Composite video in (NTSC/ PAL)
USB 2.0 Device port
USB 2.0 Host port
Ethernet (10/100 Mbps) port
 HDD Supported (Not included): Size: 3.5 inch type HDD (FAT32); Capacity: max. 500GB supported
Power Adapter
Input: AC90V~250V
Output: DC +12V 2A, DC +5V 4A
 Language: English, French, German, Spanish, Italian, Nederland, Russian
 Manual: PDF
 Firmware: Version MEC_P0.31.K1 MEC_P0.31.K1.b6_USB_InstallAP.zip Notes: PDF
Цена може да проверите в amazon.
     Re:Emprex ME1 High Definition Multimedia Enclosure
  твърдо НЕ, силно е орязан в поддържаните формати, предполагам че ползва някой стар чипсет на RealTek
  Това като го гледам е стандартен Мултимедиен HDD, аналог на Captiva, сиреч нищо особено, освен ако някой не иска да си пуска DivX и DVD-та. Защо са го набедили за HD плеър не знам, но DivX HD поддръжката не ми говори нищо особено, защото не съм срещал файл с такова кодиране. Липсата на HDMI като видео изход говори най-много, няма многоканално аудио, даже Captiva май имаше ъпскейлинг и HDMI ...
  Да, да така е.
Аз питам за друго.
В amazon го видях за 20 - 22 £ (нов)
Викам си цената е супер, но искам да го ползвам за слушане на интернет радио, а не като мултимедиен плеър и се чудех ще стане ли номера?
  Аз не видях опция за Интернет радио, ти защо си мислиш че има ?
				Първоначално публикувано от Hell
    Не мисля, надявах се :) защото гледах шотове на менютата из мануала и приличат на други realtek-ски медиа плеъри ...
