попаднах в нета на това мултимедийно устройство, изглежда е от семейството на Realtek.
Дали случайно някой от Вас не притежава такова, ако може да сподели впечатления.
А между временно ето малко повече данни за самото устройство:
Сайт на производителя: http://www.emprex.com/02_products_02.php?id=210
Марка: Emprex
Модел: ME1
Тип: High Definition Multimedia Enclosure
Функции: Play music, high resolution photo, and HD video
Browse photo with background music playing
One Touch Record and Time-shift input video from AV-in port
Upscale video quality to NTSC/PAL progressive scan, 720p, or 1080i
Stream file from PC in the LAN through Ethernet port
Play file firm USB storage device, and USB card reader through USB 2.0 Host port
As an external USB HDD of PC through USB Device port
Support both NTSC and PAL video in and video out
Support various multimedia formats
Support 3.5” IDE type HDD
Спецификации:
Model No. ME1
Physical Dimension: Height: 126.6 mm x Depth: 192.5 mm x Width: 44.3mm
Weight: 0.63 Kg (without Hard disk drive)
Playback Format:
Audio: MP3, WMA, PCM
Video: MPEG 1/2, DivX HD, DivX 3.11, 4.12, 5, 6 ; AVI, VOB, MPG, DAT, Xvid
Picture: JPG, BMP
Subtitle: SRT
Remote Control: IR remote control
Audio Out: 2 channels output
Video Out: Component: Y, Pb, Pr (NTSC/PAL, NTSC/PAL progressive scan, 720p, 1080i), Composite video out (NTSC/ PAL)
Audio In: 2 channels stereo input
Video In: Composite video in (NTSC/ PAL)
USB 2.0 Device port
USB 2.0 Host port
Ethernet (10/100 Mbps) port
HDD Supported (Not included): Size: 3.5 inch type HDD (FAT32); Capacity: max. 500GB supported
Power Adapter
Input: AC90V~250V
Output: DC +12V 2A, DC +5V 4A
Language: English, French, German, Spanish, Italian, Nederland, Russian
Manual: PDF
Firmware: Version MEC_P0.31.K1 MEC_P0.31.K1.b6_USB_InstallAP.zip Notes: PDF
Цена може да проверите в amazon.
