Media Player - HiMedia (всички модели)
  HiMedia HD900B - 3D FULL HD МЕДИЯ ПЛЕЪР
 http://www.homecinema-bg.com/userfil...roduct_294.jpg
 Подробна спецификация
Дата на производство    Ноември 2011
Произход    Китай
Максимална резолюция    1080p [Full-HD]
Чипсет    Realtek
Chipset Family    Realtek 1xx6 (2011)
Модел на чипсета    Realtek 1186
Чипсет Mhz    750
Памет    512MB DDR 4Gbit Flash
Операционна система    Realtek Linux / Android
Internal HDD    3.5" SATA
Брой HDD    1
USB (Host)    2
USB (Slave)    1
USB Version    2.0 / 3.0
SD    1
Other Storage    External SATA
File Systems    FAT, EXT3, NTFS
UPnP    Yes
DLNA    Yes
Мрежови протоколи    Samba, NFS
Wired Network    Gigabit Ethernet
Wireless Network    Wi-Fi(n) опция
HDMI    1
Component Video    1
Composite Video    1
HDMI Version    1.4a
Stereo L/R Audio    1
S/PDIF TOSLink    1
S/PDIF Coaxial    1
Видео формати (Codecs)    RM/RMVB, H.264, VC1, WMV, MPEG 1/2/4, DIVX, XVID
Video Extensions (Containers)    BD-ISO, MKV, TS, M2TS, MTS, FLV, AVI, DVD-ISO, VOB, MPG, DAT, ASF, TP, TR
Аудио формати (Codecs)    LPCM, APE, FLAC, MP3, OGG, WMA, WAV
Снимкови формати    JPG, TIFF, PNG, BMP, GIF
Субтитри    PGS, SRT, SUB, IDX+SUB, SSA, SMI
3D SBS    Yes
3D Top Bottom    Yes
3D Frame Packing    Yes
3D Frame Sequential    No
Blu-Ray 3D    Yes
DVD ISO    Yes (original menus)
Blu-Ray ISO Yes.
Blu-Ray Menu Yes (BD Profile 1 + BD-Lite)
Dolby Digital Downmix    Yes
Dolby Digital Passthrough    Yes
Dolby Digital Plus Downmix    Yes
Dolby Digital Plus Passthrough    Yes
Dolby TrueHD Downmix    Yes
Dolby TrueHD Passthrough    Yes
DTS Downmix    Yes
DTS Passthrough    Yes
DTS-HD HR Downmix    Yes
DTS-HD HR Passthrough    Yes
DTS-HD MA Downmix    Yes
DTS-HD MA Passthrough    Yes
Интернет радио    Shoutcast
Web Services    Loads
Bittorrent    Yes
Web Browser    Yes
Browser Detail    HTML 5, Flash
Flash    Yes
Вентилатор    Yes
Фронтален дисплей    Yes
Захранване    12V 3A
W (mm)    226
D (mm)    180
H (mm)    50
Тегло (kg)    1.50
 All Official Firmware Downloads
 Firmwares:
 Original
 firmware 1.0.4.7
 firmware 1.0.3.8
 Custom
 OllyP 1.0.4.10 - 2012.07.17
 OllyP 1.0.4.7 - 2012.05.20
 MIPSELFW v1.1 (1.0.3.8)
 OllyP 1.0.1.12 Beta
 https://forum.setcombg.com/index.php...0;attach=10622
 Първи впечатления
3дравейте,
Реших да отворя темата за плейъра не защото ще ви представя ревю или тестове, а само за да отговоря на многото въпроси, които дойдоха във връзка с обявата ми за продажба на стария.
Нямам време и все още нямам 3D телевизор и blu-ray устройство за да мога да направя каквито и да е тестове.
Плейъра е базиран на новия чипсет на Риалтек RT1186DD, който е на 750Mhz, поддържа HDMI 1.4, USB 3.0, Андроид и т.н.
Хардуера му като възможности и дизайн е силно впечатляващ (дизайн аналогичен на HD600B). Много елегантно и практично решение за поставяне на твърдия диск с повдигане на един капак и придвижване на пакет с конектори. Също така много практично е и наличието на външен sata конектор. Не особено практично за мен е наличието на wifi адпатер (Тъй като жичния гигабитов порт за мен е напълно достатъчен). Много приятен преден панел с тъч скрин бутони и красив дисплей. Метален корпус и вентилатор се грижат твърдия диск да не прегрява. Поддържа се и функцията spin down, така че диска "заспива" след време когато не се използва.
Както може да се очаква, плеъра поддържа всички формати които тествах и онлайн съдържания като youtubе, и др. ( с изключение на записаните транспортни mpeg2 файлове от IPBox-а ми).
Може още много да се говори за предимствата и потенциала на може би най-добрия хардуер на пазара към момента.
До тук с хубавите неща. Софтуера му е за сега пълна боза. Макар, че се появява нова версия през 2-3 дена, положението е повече от ужасно. Много от нещата не са оправени - много бъгове има. Не ми се изброяват дори. Например почти след всяко рестартиране си губи интернет гейтуея, не работи торент клиента, не работят мишките които пробвах (така браузъра и андроид системата са обезмислени), при превъртане напред бързо не дава реални скорости, и др..
Пробвах да кача фърмуера от Iconbit 1003D (друг 1186 плейър), но за съжаление не става (необходим му е друг bootloader, но дори тогава не работи дистанционното. IconBit предлага преведени на руски вместо китайски, като на HiMedia, онлайн филми иначе си носи същите бъгове.
Плейъра е много обещаващ, дано да изчистят скоро многобройните бъгове.
Понеже много въпроси има и за това, купих го от futeko.com за 159 лири с доставката до България и дойде за 3-4 дни. Дойде с Европейски щепсел, HDMI кабел и антена която се навива на wifi антенния вход.
Относно DVB-T, по принцип чипсета го поддрържа, има куплунг вътре, но няма място на задния панел, така че от HiMedia не възнамеряват да го предлагат като опция. Вероятно и софтуерно няма да го разрешат дори да си го сложа някак си, когато се появи. Жалко.
     Re:HiMedia HD900B - 3D full HD Multimedia Player Първи впечатления
  А някакви наистина много груби бъгове има ли? В смисъл тези, които си написал се преживяват.
И няколко въпроса имам:
1. Какви скорости на трансфер успяваш да постигнеш през гигабит порта
2. Ако може да пробваш и 3D-то, в смисъл тук ме интересува плейва ли от iso файл и дали имаш избор за изходящия формат на сигнала примерно: Side By Side, Frame Packing, Checkboard ...
3. Можеш ли да монтираш устройсва през мрежата (винбоз шеринг) и дали ги помни. И ако може да кажеш какви скорости постигаш на трасфер през такова монтирано устройство.
  Не ми е ясно как мерите скоростта по мрежата? Иначе то там нещо показва, при прочитането, но не съм сигурен дали може да му се вярва. В мрежата вижда samba share, но не успявам да намеря nfs share от ipbox приемника. Бъгав е начина по който му задавам адреса на NFS и се отказах да се мъча, а на search не го открива. Не съм свалял ISO 3D все още.
				Първоначално публикувано от carp
    Благодаря, но това не ми е необходимо. Аз имам работещ NFS сървър на сателитния приемник IPBox HD910 и не ми е необходим такъв на компютъра. Проблема е че плеъра нещо има бъг и не мога да му задам адреса на сървъра. А вероятно скоростта на потока я мери самия NFS сървър за WINDOWS, но не мен не ми се занимава с това само заради самото мерене, нямам време.
				Първоначално публикувано от orlie
    Пусни да се копира примерно един 40GB BD и засечи колко време отнема.
  Продава ли се в България този плеар , и каде ?
  Знае ли някой, дали това чудо чете 3d bd iso.
				Първоначално публикувано от hkr68
    Така като чета в този саит: http://www.homecinema-bg.com/product...ia-hd900b.html
явно чете,но наи добре някои собственик на такова плеарче да каже.
				Първоначално публикувано от antovasilev
    http://www.homecinema-bg.com/ На Hifi Expo-то ги имаше изложени,казаха че за бг.пазара са им сменяли захранването и слагали по голям кеш :detective: Питах ги за 3D iso,но изобщо не знаеха за какво става въпрос,не бяха и чували какво е това,важно е търговийката да върви,те хората са търговци кво ги интересува какво възпроизвежда плейъра,той е за продаване не за лична употреба. :-memnon
    Не съм свалял 3D ISO за да пробвам, не мога да ви кажа, дали и как плейва. За Бога, не се прецаквайте с тоя боклук, както аз направих. Той дори не може да чете снимки от фотоапарат Панасоник! Софтуера му е голямо дърво и не си заслужава да изреждам бъговете дори. Същото се отнася и за другите плеъри с Риалтек 1186 чипсет!
Не знам какво му сменя БГ вносителя, външния адаптер ли? Аз си го поръчах от UK с европейски щепсел...
Какъв кеш му сменя не ми е ясно, паметта ли? Не знам дали има смисъл.
     Похвално колега, че даваш обективно мнението за плеърчето ти, много в БГ биха си замълчали по принципа "защо да съм прецакан само аз" така че благодарности :bravo Явно Android базираните системи още не са "дорасли" и изчистени от бъгове за да служат за стабилен HD плеър и при тази "перманентна криза в БГ" може би трябва да изчакаме да си оправят бъговете за да не си купуваме "паметник-сапунерка". Жалко чипчето RTL1186 изглеждаше доста обещаващо с неговите възможности и 750Mz. Но може би Androidkite ще се развият бързо - да си спомним как беше Android в първите смартфони а сега си е вече доста уважавана стабилна OS - е за сега само при телефоните но утре..... при това F1 темпо angel
 P.S Ето Hell отдолу прави уместна забележка например аз не знаех че това плеърче има Dual Boot т.е възможност за избор на 2 операционни системи - като за Андроида ясно ще се "барва" тепърва но как се държи с нативната Real-тешкa Linyx ОС плеърче базирано на 1186 ще е интересно да споделиш тук вече Realtek би трябвало да имат сериозен опит ???
 А иначе ако си решил да го хвърляш  :huh: имаше един колега преди време който така се беше отчаял че искаше да си хвърля плеъра от прозореца  :wink: Кажи да чакаме отдолу :-memnon
  @orlie -> с кой от двата буута правиш проби - с Линукс или Андроида ? Основните тестове ги направи с нативната операционна система - базирания на Линукс софтуер на РиълТек. Сложи си и последния фърмуер (предполагам, че го правиш - те излизат доста начесто) и опитай всички проби отново и чак тогава напиши отзиви, иначе можеш да заблудиш аудиторията с прибързани заключения. Да не забравяме, че докато поуправят бъговете си, при другите модели плеъри минава най-малко година (според мен това май важи за всички марки) :)
 P.S. Не плеърът (или марка и модел), а чипсета RTD1186DD-3D е разработен така и позволява използване на двете операционни системи - стандартната Линукс и Андроид. Всички плеъри използващи този процесор са с "Dual boot" - това идва със самия фърм от RealTek. Целта е да се съчетаят предимствата и на двата лагера, но тепърва ще оценяваме това преимущество.
  Аз като гледам тук http://www.futeko.com/forum/index.ph...=thread&id=204 всичко се оправя много бързо. Тия от HiMedia изглеждат много сериозни всяка седмица се прави упдейт, оправят се бъгове. Даже се замислям дали да не си взема и аз един за пробата.
    Аз съм с HD900A и нямам проблем с 3D iso
