Променяме 4 параметъра в настройките на Лисицата и..... политаме в Интернет със скоростта на светлината!!!!!
Инструкция:
(по-долу е кратък превод на български )
For those of you who regularly use Firefox Browser:
TIPS FOR MAKING IT THE FASTEST BROWSER ON EARTH:
Speed up Firefox, after this tweak you can serf much faster.
How To
1.Type "about:config" into the address bar and hit return. Scroll down
and look for the following entries:
network.http.pipelining network.http.proxy.pipelining
network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time.
When you enable pipelining it will make several at once, which really
speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests " to some number like 30.
This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it
"nglayout.initialpaint.delay" and set its value to "0". This value is
the amount of time the browser waits before it acts on information it
receives.
If you're using a broadband connection you'll load pages MUCH faster now!
Note: This only works if you have Firefox installed on your computer.
I have observed a great difference after this
Направете следното:
1.Набираме в арес-бара: "about:config"
И търсим следните параметри:
2. Променяме стойностите им така:
Променяме "network.http.pipelining" в "true"
Променяме "network.http.proxy.pipelining" в "true"
Променяме "network.http.pipelining.maxrequests " в 30.
3.Дясно бутонче на мишката някъде в полето на страницата на браузера New-> Integer.
Преименуваме на:
"nglayout.initialpaint.delay" въвеждане стойност "0".
И би трябвало да полетим скоростно при браузване в Интернет!!!!!!! :knuppel2:
