QIP 7970
Код:Added:
- optional: NTLM authentication support for proxies based on MS Windows platforms;
- optional: launch qip on startup;
- optional: possibility to disable showing of birthday balloons;
- optional: possibility to disable showing of how long user was idle in Away, NA statuses;
- close tab after sending message feature (Send button popup menu);
- future qip clients identification for mobile platforms;
Fixed/Updated:
- [upd] drawing images on buttons methods for MS Windows Vista compatibility;
- [upd] if messaging window is active with user who sent message then sound of incoming message will not be played;
- [upd] addopt.bmp, added new icons for future qip clients for mobile platforms;
- [upd] if contact hint is showing then received custom status text will be updated on hint directly;
- [upd] selection, quoting behavior in messaging window;
- [upd] tray clicks handling function;
- [upd] if using /ifa command line parameter then qip sets Invisible For All on server before closing;
- [upd] protocol and messaging module;
- [fix] messaging window taskbar button sometimes stays highlighted;
