Първоначално публикувано от hihimor
Your Uninstaller! 2006 е най-доброто на което съм попадал и го ползвам от 3-4 години - дейнсталира много основно, чисти и регистъра при деинсталацията на съответната програма....
Here's a brief feature list of Your Uninstaller! 2006. "[PRO]" means this feature is only available in Pro version of Your Uninstaller!.
· Remove programs that could not be removed by Add/Remove Program. [PRO]
· Auto detection of unused files and registry keys during uninstalling process.
· Shows all applications installed on your computer with customized views.
· Built-in Disk Cleaner helps you find and remove unnecessary files on your disk to save space and make computer faster! [PRO]
· Ability to uninstall screen savers.[PRO]
· Built-in IE Context Menu Cleaner, cleans the context menu of Internet Explorer. [PRO]
· Built-in Startup Manager, take full control of Window startups. [PRO]
· Built-in Start Menu Manager helps you keep your Start Menu clean.
· Get the applications detail info even if it hide itself in deep directory, especially useful for finding out "Spy" applications. [PRO]
· Ability to backup/restore installed-applications information.
· Uninstall with SINGLE drag-drop! Just drop a file on Your Uninstaller! icon on the desktop to see what happens! [PRO]
· List installed applications with appropriate icons(same as you see in the Start Menu), you can easily find the application you want to uninstall.
· Powerful search feature allows you quickly find the program you are about to uninstall.
· Automatical detectection of invalid installations and removing them with one click.
· Force removal of uninstall related entries in the registry(care to use!). [PRO]
· Lighting speed at startup, 5-10 times faster than Add/Remove Program of Windows XP!
· View all details of an certain application installed on your computer.
· Export programs list to file or printer.
and more...
