Re: Skype
MX Skype Recorder 3.3.2 Full
MX Skype Recorder is a new tool that works in conjunction with Skype for recording Skype audio conversations.
It has the following advantages:
- can work in automatic mode (you don't need to press "record" or "stop" or manual mode
- automatic compressing in mp3 format (8-320 kbits) using Lame MP3 Encoder
- can save as wav PCM format
- can record conversations either in single or dual audio track (one channel for input, other for output)
- can work in spy mode (user who uses Skype won't guess that all conversations will be recorded)
- can work with PC-to-PC, PC-to-phone as well as skypecast conversations
- support all versions of Skype, Google talk, Yahoo Messenger and anothet VoIP applications
- free to try
System Requirements:
OS: MS Windows 2000/XP/2003
Memory: 64 Mb
Disk space: 1 Mb for program files and space for records
How to record a skype audio conversation ?
This process is fully automatic, just you need to make folowing steps:
- run MX Skype Recorder
- run Skype (Google talk, Yahoo Messenger or anothet VoIP application)
- start conversation in Skype (Google talk, Yahoo Messenger) as you do it usually
- when you finish the conversation, MX Skype Recorder makes mp3 or wav file and put it into output folder
( usually into C:\Program Files\MXSkypeRec\records )
Download
******************.com/files/46337539...ws_-_Final.rar
