Резултати от 1 до 5 от общо 5
problem sas cd-rw help!!!!!!!!!pls
    Aug 2006
    windowsa mi ne razpoznava zapisva4kata deinstalirah ia i 9 instalirah otnovo nameri9 kato hardwere no mi kazva 4e ima problem s driver izpisva mi o6te (code 39). Help me! Blagodar9!
  3. Member Аватара на panevdd
    Jul 2003
    Re: problem sas cd-rw help!!!!!!!!!pls
    Кажи модела на дъното и записвачката; кажи и с какъв Windows работиш. Ако си с WindowsXP, виж дали това упътване ще ти помогне. И пиши на кирилица...
  4. Super Moderator Аватара на FearMe
    Jan 2001
    ето какво казват M$:
    SYMPTOMS
    After you remove either compact disc (CD) recording software or other software from your computer, your computer may exhibit the following behavior:
    • Device Manager displays the following error message:
    A driver for this device was not required, and has been disabled (Code 32 or Code 31).
    You may also receive an "error code 39" message that indicates that the driver is corrupted.
    решение:
    To manually delete the UpperFilters and LowerFilters registry values, follow these steps:
    1. Start Registry Editor (Regedt32.exe).
    2. Locate the UpperFilters value under the following key in the registry:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    3. On the Edit menu, click Delete, and then click OK.
    4. Locate the LowerFilters value under the same key in the registry:
    5. On the Edit menu, click Delete, and then click OK.
    6. Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software.
    7. Restart your computer.
    кажи после дали се е получило
  5. Junior Member
    Aug 2006
    drupni drivera ot neta.Dai si modela na RW-to
  6. Super Moderator Аватара на FearMe
    Jan 2001
    z*e*w*a, за дискови устройства не се дърпат отделни драйвери, защото поддръжката им е вградена в самия windows. наблюдаваният проблем е поради "осакатяването" на самия windows при деинсталирането на софтуер за запис, а не поради реална липса на драйвер
  1. BIG FAT PROBLEM :(
    От roL4xX във форум ИГРИ
    Отговори: 10
    Последно: 20-04-06, 14:49
  2. WD - problem
    От connect във форум Общ - хардуер
    Последно: 03-02-06, 08:58
  3. XP problem
    От paco във форум Windows
    Последно: 06-03-04, 13:18
  4. WIn XP Problem
    От LinuxLoader във форум Windows
    Последно: 10-02-03, 00:06
  5. problem s P4
    От mitak във форум Общ - хардуер
    Отговори: 19
    Последно: 29-04-02, 11:21
