zna4i eto kakav e problema darpam nov BIOS update za GF2 MX 400
(BIOSa e pravilniqt)zarejdam DOS i davama
nvflash -f xxxxxxxxx(filename)
i mi izpisva
NO Supported EEPROM found ili ne6to takova
idei ???
have no fear lightmaster is here
i mi izpisva
idei ???
  Ами ако дадеш малко допълнително инфо няма да сгрешиш. Например каква ти е видеокартата, версия на новия БИОС, на стария БИОС, версия на nvflash.
Пък и ако ти е noname видео-то няма да се учудя чипа да не е EEPROM ами само EPROM
  Suren eto ti info
kartata dokokoto razbrah e na firmata Triplle3D, pone taka mi kazaha:
$ffffffffff Display adapter information
$ffffffffff ---------------------------------------------------
$0000000000 Description : NVIDIA GeForce2 MX/MX 400
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0110
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP
$0000000005 AGP status : enabled
$0000000006 AGP rate : 1x 2x 4x supported, 4x selected
$0000000007 AGP SBA : not supported
$0000000008 AGP FW : supported, disabled
$0000000009 Base address 0 : ce000000 (memory range)
$000000000a Base address 1 : c0000000 (memory range)
$000000000b Base address 2 : none
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV11 revision B2
$0100000001 Bus type : AGP
$0100000002 Memory bus : 128-bit
$0100000003 Memory type : SDR (RAM configuration 00)
$0100000004 Memory amount : 32768KB
$0100000005 Core clock : 199.656MHz
$0100000006 Memory clock : 165.958MHz
$0100000007 Reference clock : 14.318MHz
$0100000008 Maximum Fvco : 500.000MHz
$0100000009 Core PLL Fvco : 399.313MHz
$010000000a Memory PLL Fvco : 331.917MHz
tova e ot riva tuner
nastoq6t BIOS - Version 3.11.00.08.00
nov bios - Version 3.11.01.37.00
ako ti trqbva o6te info da rovq ???
10x predvaritelno
  Аз лично досега никога не съм успявал да флашна с NVFlash, просто картите, които се внасят тук или не могат да се флашнат въобще, или не се разпознават от NVFlash. Но има други програмки де, dflash, wfflash, търси из интернет, ще намериш.
<font size=1>P4 1.6@2.59 (16x162), EpoX 4G4A+, Kingmax DDR300@405, Gigabyte GF2 GTS Pro, IBM 30GB, Sony 200GST 17", Logitech MouseMan Dual Optical</font id=size1>
  vsa6nost da bada iskren za6to iskam da update BIOS,
otvorih ROMa s BIOS editor i vklu4ih SBA,4etoh 4e v MX seriite ne se poddarja dali 6te stane ??
  Картата явно е куча марка и ще е голям късмет ако въобще е стане.
http://julmin.hit.bg
  a otkade da namerq tezi други програмки де, dflash, wfflash,
  Az puk si flashnah Abit-cheto T400 s nvflash i nqmah nik`vi problemi. Samo deto nikude ne pisheshe kakvo opravq toq update na BIOS-a)
Znaq pove4e otkolkoto si misli6
  И аз съм си флашвал БИОС-а на видеото даже два пъти.И също картата е ABIT T400.Последния ми БИОС е v3.11.01.48 и не знам какво оправя обаче предния който беше 3.11.01.37 забелязах че махаше Fastwrites(поне аз това забелязах сигурно има и други разлики). Версията на моя NVFLASH e 03.18.
Пробвай да видиш дали чипа ти се поддържа от програмата, все пак ги изброява в края.
Тази фирма обаче я чувам за първи път - Tripple3D ?!
  Btw BIOSa na Axela EEPROM li e?
Cyrix's sysyem:
Duron750@900/GB 7VRX/128DDR333/GF MX400/HDD40GB/
  Нямаш късмет с видеокартата - това най-вероятно не е Triplle3D, а "Triple D International LTD", както е официалното име на фирмата произвеждаща видеокартите Axle. Доколкото знам, те не ползват флаш биос, за да са по евтини. Ако чипа, който ползват е EEPROM, и не е запоен, можеш да го извадиш и занесеш заедно с новия BIOS в някоя фирма с програматор, където срещу някакво заплащане ще ти го препрограмират. Ако не е, ще трябва да се откажеш.
Между впрочем разликата в производителността между "със SBA" и "без SBA" е толкова малка, че няма абсолютно никакъв смисъл.
I'll be back!
  a ne ne ne ne neeeeeeeee
samo ne pak Axxle, mrazq gi !!!!!!!!
i starata mi videokarta be6e na AXxle TNT2 Ultra
Ultra ama po axxleski standarti (Core 150/Memory 150)
e pone tozi geforce si e OK s 4estotite
kato se setq ne mojah da update i TNT2kata sa6tata gre6ka dava6e
Steeve: SBA - Side Band Adressing
  OPa zabravih da kaja 4e namerih na4in da pusna SBA bez da FLASH BIOSa
Novata versiq na Riva Tuner 2.0 RC11, predlaga instaliraneto na driver kojto se zarejda predi qdroto na operacionnata sistema(edin vid vtori BIOS, abe ne to4no taka ama ...).Taka predi da e zaredil Win, moje da se vklu4i SBA, FW i tova koeto mi haresa naj-mnogo:
prezapisva PCI DEvice ID i pravi ot va6iq Geforce Quadro bez da se zapoqwat rezistori ili da se pa4vat detonatorite, vednaga sled vklu4vaneto na tazi opciq trqbva6e pak da ka4vam driveri za6toto Win razpona videoto kato Quadro.
V 3D Mark 2001 SE nqma razlika v rezultata 2875 za geforce, 2872 za Quadro MXR.
Vulpune GL MARK s ge force - 25 fps,minimum - 10fps, max90
s Quadro MXR - 30 fps, min. 12fps , max 170fps
xristo - kak da razbera kakav e 4ipa ima samo edna lepenka Gefopce i tva e , moje bi nqkakav software ???
  uvi na Axle e
http://www.axle-hk.com/mx400.htm
oba4e ne pi6e s kakav 4ip e
