Резултати от 1 до 15 от общо 18
VIDEO BIOS update failed
    Jul 2001
    zna4i eto kakav e problema darpam nov BIOS update za GF2 MX 400
    (BIOSa e pravilniqt)zarejdam DOS i davama
    nvflash -f xxxxxxxxx(filename)
    i mi izpisva
    NO Supported EEPROM found ili ne6to takova
    idei ???
    have no fear lightmaster is here
    Oct 2001
    Ами ако дадеш малко допълнително инфо няма да сгрешиш. Например каква ти е видеокартата, версия на новия БИОС, на стария БИОС, версия на nvflash.
    Пък и ако ти е noname видео-то няма да се учудя чипа да не е EEPROM ами само EPROM
    Jul 2001
    Suren eto ti info
    kartata dokokoto razbrah e na firmata Triplle3D, pone taka mi kazaha:
    $ffffffffff Display adapter information
    $ffffffffff ---------------------------------------------------
    $0000000000 Description : NVIDIA GeForce2 MX/MX 400
    $0000000001 Vendor ID : 10de (NVIDIA)
    $0000000002 Device ID : 0110
    $0000000003 Location : bus 1, device 0, function 0
    $0000000004 Bus type : AGP
    $0000000005 AGP status : enabled
    $0000000006 AGP rate : 1x 2x 4x supported, 4x selected
    $0000000007 AGP SBA : not supported
    $0000000008 AGP FW : supported, disabled
    $0000000009 Base address 0 : ce000000 (memory range)
    $000000000a Base address 1 : c0000000 (memory range)
    $000000000b Base address 2 : none
    $000000000c Base address 3 : none
    $000000000d Base address 4 : none
    $000000000e Base address 5 : none
    $ffffffffff NVIDIA specific display adapter information
    $0100000000 Graphics core : NV11 revision B2
    $0100000001 Bus type : AGP
    $0100000002 Memory bus : 128-bit
    $0100000003 Memory type : SDR (RAM configuration 00)
    $0100000004 Memory amount : 32768KB
    $0100000005 Core clock : 199.656MHz
    $0100000006 Memory clock : 165.958MHz
    $0100000007 Reference clock : 14.318MHz
    $0100000008 Maximum Fvco : 500.000MHz
    $0100000009 Core PLL Fvco : 399.313MHz
    $010000000a Memory PLL Fvco : 331.917MHz
    tova e ot riva tuner
    nastoq6t BIOS - Version 3.11.00.08.00
    nov bios - Version 3.11.01.37.00
    ako ti trqbva o6te info da rovq ???
    10x predvaritelno
    Jan 1970
    Аз лично досега никога не съм успявал да флашна с NVFlash, просто картите, които се внасят тук или не могат да се флашнат въобще, или не се разпознават от NVFlash. Но има други програмки де, dflash, wfflash, търси из интернет, ще намериш.
    <font size=1>P4 1.6@2.59 (16x162), EpoX 4G4A+, Kingmax DDR300@405, Gigabyte GF2 GTS Pro, IBM 30GB, Sony 200GST 17", Logitech MouseMan Dual Optical</font id=size1>
    Jul 2001
    vsa6nost da bada iskren za6to iskam da update BIOS,
    otvorih ROMa s BIOS editor i vklu4ih SBA,4etoh 4e v MX seriite ne se poddarja dali 6te stane ??
  7. Moderator
    Nov 2001
    Картата явно е куча марка и ще е голям късмет ако въобще е стане.
    http://julmin.hit.bg
    Jul 2001
    a otkade da namerq tezi други програмки де, dflash, wfflash,
  10. DJ
    DJ е офлайн
    Member
    Jun 2001
    Az puk si flashnah Abit-cheto T400 s nvflash i nqmah nik`vi problemi. Samo deto nikude ne pisheshe kakvo opravq toq update na BIOS-a)
    Znaq pove4e otkolkoto si misli6
    Oct 2001
    И аз съм си флашвал БИОС-а на видеото даже два пъти.И също картата е ABIT T400.Последния ми БИОС е v3.11.01.48 и не знам какво оправя обаче предния който беше 3.11.01.37 забелязах че махаше Fastwrites(поне аз това забелязах сигурно има и други разлики). Версията на моя NVFLASH e 03.18.
    Пробвай да видиш дали чипа ти се поддържа от програмата, все пак ги изброява в края.
    Тази фирма обаче я чувам за първи път - Tripple3D ?!
    Feb 2002
    Btw BIOSa na Axela EEPROM li e?
    Cyrix's sysyem:
    Duron750@900/GB 7VRX/128DDR333/GF MX400/HDD40GB/
    Apr 2001
    Нямаш късмет с видеокартата - това най-вероятно не е Triplle3D, а "Triple D International LTD", както е официалното име на фирмата произвеждаща видеокартите Axle. Доколкото знам, те не ползват флаш биос, за да са по евтини. Ако чипа, който ползват е EEPROM, и не е запоен, можеш да го извадиш и занесеш заедно с новия BIOS в някоя фирма с програматор, където срещу някакво заплащане ще ти го препрограмират. Ако не е, ще трябва да се откажеш.
    Между впрочем разликата в производителността между "със SBA" и "без SBA" е толкова малка, че няма абсолютно никакъв смисъл.
    I'll be back!
    Jan 2002
    kakvo e SBA ??
    Rainbow books !
    Jul 2001
    a ne ne ne ne neeeeeeeee
    samo ne pak Axxle, mrazq gi !!!!!!!!
    i starata mi videokarta be6e na AXxle TNT2 Ultra
    Ultra ama po axxleski standarti (Core 150/Memory 150)
    e pone tozi geforce si e OK s 4estotite
    kato se setq ne mojah da update i TNT2kata sa6tata gre6ka dava6e
    Steeve: SBA - Side Band Adressing
    Jul 2001
    OPa zabravih da kaja 4e namerih na4in da pusna SBA bez da FLASH BIOSa
    Novata versiq na Riva Tuner 2.0 RC11, predlaga instaliraneto na driver kojto se zarejda predi qdroto na operacionnata sistema(edin vid vtori BIOS, abe ne to4no taka ama ...).Taka predi da e zaredil Win, moje da se vklu4i SBA, FW i tova koeto mi haresa naj-mnogo:
    prezapisva PCI DEvice ID i pravi ot va6iq Geforce Quadro bez da se zapoqwat rezistori ili da se pa4vat detonatorite, vednaga sled vklu4vaneto na tazi opciq trqbva6e pak da ka4vam driveri za6toto Win razpona videoto kato Quadro.
    V 3D Mark 2001 SE nqma razlika v rezultata 2875 za geforce, 2872 za Quadro MXR.
    Vulpune GL MARK s ge force - 25 fps,minimum - 10fps, max90
    s Quadro MXR - 30 fps, min. 12fps , max 170fps
    xristo - kak da razbera kakav e 4ipa ima samo edna lepenka Gefopce i tva e , moje bi nqkakav software ???
    Jul 2001
    uvi na Axle e
    http://www.axle-hk.com/mx400.htm
    oba4e ne pi6e s kakav 4ip e
  1. UPDATE BIOS
    От Z*E*W*A във форум Общ - софтуер
    Последно: 30-10-06, 10:11
  2. Проблем след Update на BIOS на Gigabyte
    От Jogo_1 във форум Процесори и Дънни платки
    Отговори: 10
    Последно: 21-06-05, 17:29
  3. BIOS Update - цени
    От ManiMani във форум Общ - хардуер
    Последно: 06-06-05, 11:34
  4. Update на стар BIOS???
    От jivak във форум Общ - хардуер
    Последно: 02-11-04, 14:33
  5. Win XP [update BIOS проблем]
    От KOMAP във форум Windows
    Последно: 16-09-03, 18:00
