Re: Промблем с УСБ мп3 ќа
Пробвай това:
GetDataBack for FAT/NTFS 3.03
GetDataBack will recover your data if the hard drive's partition table, boot record, FAT/NTFS/MTF or root directory are lost or damaged, data was lost due to a virus attack, the drive was formatted, fdisk has been run, a power failure has caused a system crash, files were lost due to a software failure, files were accidentally deleted.
или това:
RT DiskExplorer for FAT/NTFS 3.03
DiskExplorer 3.03 for FAT/NTFS - with this powerful disk editor you can inspect your drive in greater detail. It lets you go directly to the partition table, boot record, FAT/NTFS or root directory as well as jump to a certain sector etc...
This powerful disk editor enables you to: navigate through your drive by using browser-style back and forth arrows, by going directly to the partition table, boot record, FAT/NTFS or root directory, by jumping to a certain sector etc. switch between several views, such as hex, text, directory, MFT, FAT/NTFS, partition table and boot record view, search your drive for text, boot records, partition tables and sub directories, investigate the volume' s boot record by looking at the volume information, edit your drive by using the direct read/write mode (not recommended) or the virtual write mode, view and recover even deleted files, create a virtual volume when your boot record is lost or corrupted, conduct your own data recovery by taking advantage of all these features.
мерси стана , макар и не напълно но по важните ги върна :) после му направих формат и засега работи
