Значи това ми е CPU
Number of CPUs 1
Name AMD Athlon XP
Code name Palomino
Specification AMD Athlon(TM) XP 1500+
Family/Model/Stepping 662
Extended Family/Model 7/6
Package Socket A
Core Stepping A5
Technology 0.18µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Clock Speed 1336.3 MHz
Clock multiplier x10.0
Front Side Bus Frequency 133.6 MHz
Bus Speed 267.3 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1336.3 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
А това е даното
Northbridge nVidia nForce rev. B2
Southbridge nVidia nForce MCP rev. C3
Graphic Interface AGP
AGP Revision 2.0
AGP Transfert Rate 2x
AGP SBA supported, enabled
AGP Aperture 64 MBytes
Memory Type DDR
Memory Size 256 MBytes
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Даното e ASUS A7NV266-VM може ли да се klockne поне малко тоя процесор поне да стане 1.5Ghz
<font color="red">как да вдигна това FSB като в BIOS не ми е достапно (с DIM ключета ли?)</font id="red">
