Продавам ресивър Harman Kardon AVR 100
Audio Section
Stereo Mode
Continuous Average Power (FTC)
50 Watts per channel, 20Hz–20kHz,
@ < 0.08% THD, both channels driven into 8 ohms
Five-Channel Surround Modes
Power Per Individual Channel
Front L&R channels:
40 Watts per channel,
@ < 0.08% THD, 20Hz–20kHz into 8 ohms
Center channel:
40 Watts, @ < 0.08% THD, 20Hz–20kHz into 8 ohms
Surround channels:
Input Sensitivity/Impedance
Linear (High Level) 250mV/47k ohms
Signal-to-Noise Ratio (IHF-A) 90dB
Surround System Adjacent Channel Separation
Analog Decoding 40dB
(Pro Logic, etc.)
Dolby Digital (AC-3) 55dB
Frequency Response
@ 1W (+0dB, –3dB) 10Hz–100kHz
High Instantaneous
Current Capability (HCC) ±30 Amps
Transient Intermodulation
Distortion (TIM) 0.08%
(20Hz – 20kHz)
Rise Time 16 μsec
Slew Rate 40V/μsec
FM Tuner Section
Frequency Range 87.5–108MHz
Usable Sensitivity IHF 1.5μV/14.8dBf
Signal-to-Noise Ratio Mono/Stereo 73/70dB
Distortion Mono/Stereo 0.3/0.5%
Stereo Separation 40dB @ 1kHz
Selectivity ±400kHz, 60dB
Image Rejection 40dB
IF Rejection 100dB
Tuner Output Level 1kHz, ±75kHz Dev 500mV
AM Tuner Section
Frequency Range 520–1710kHz
Signal-to-Noise Ratio 35dB
Usable Sensitivity Loop 800μV/M
Distortion 1kHz, 50% Mod 1.5%
Selectivity ±10kHz, 30dB
Video Section
Video Format NTSC
Input Level/Impedance 1Vp-p/75 ohms
Output Level/Impedance 1Vp-p/75 ohms
Video Frequency 10Hz–8MHz (–3dB)
Response
General
Power Requirement AC 120V/60Hz
Power Consumption 72W idle, 290W maximum
(2 channels driven)
Dimensions (Max)
Width 17.3 inches (440mm)
Height 6.2 inches (156mm)
Depth 14.7 inches (375mm)
Weight 27.9 lb (12.6 kg)
цена 300 лева. само за София!
за контакт: 0888 25 25 19 или Skype: crouly
