Монито 19 Samsung SyncMaster 940BWр
General:
* Display Type LCD display / TFT active matrix
* TFT Technology TN
* Width 17.3 in
* Depth 7.9 in
* Height 14.2 in
* Weight 9.3 lbs
* Enclosure Color Black
Display:
* Diagonal Size 19.0 in - Widescreen
* Viewable Size 19.0 in
* Dot Pitch / Pixel Pitch 0.285 mm
* Max Resolution 1440 x 900 / 75.0 Hz
* Color Support 16.2 million colors
* Max Sync Rate (V x H) 75.0 Hz x 81.0 KHz
* Video Bandwidth 135.0 MHz
* Response Time 4.0 ms
* Front Panel Controls Power on/off
* Controls / Adjustments Contrast,
Brightness,
Gamma correction,
Sharpness,
H/V position
* Video Output None
* Signal Input DVI-D, VGA
* Features MagicBright 2,
Response Time Accelerator (RTA),
MagicColor,
MagicTune
Image:
* Image Brightness 300.0 cd/m2
* Image Contrast Ratio 500:1
* Image Max H-View Angle 160
* Image Max V-View Angle 160
Video Input:
* Analog Video Signal RGB
* Digital Video Standard Digital Visual Interface (DVI)
Audio Output:
* Type None
Input Device
* Type None
Expansion / Connectivity
* Interfaces 1.0 x VGA - 24 pin digital DVI,
1.0 x DVI-D - 15 pin HD D-Sub (HD-15)
Miscellaneous
* Cables Included 1.0 x VGA cable - 6.0 ft
* Flat Panel Mount Interface 75 x 75 mm
* Features Security lock slot (cable lock sold separately)
* Microsoft Certifications Certified for Windows Vista
* Compliant Standards CE,
DDC-2B,
Plug and Play,
TCO '03
Power
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 38.0 Watt
* Power Consumption Stand by / Sleep 1.0 Watt
Software / System Requirements
* Software type Driver,
Natural Color,
MagicTune
Environmental Parameters
* Operating humidity range 20 - 90%
Sustainability
* EPA Energy Star Compliant Yes
User manual Тук
В перфектно състояние.
Без изгорели пиксели.
Комплект кабели за видео и захр.
Цена: 130лв.
Куруера за сметка на купувача
Еконт с опция за преглед и тест до 15мин.
За контакти:
Бургас
Email: Alexy@abv.bg
skype: Alexybg
тел: 0884688610
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
