ВИСОКО КАЧЕСТВЕН И МОЩЕН АДАПТОР ЗА БЕЗЖИЧЕН ИНТЕРНЕТ. МОЩЕН ОБХВАТ до 1000М В ЗАВИСИМОСТ ОТ ОКОЛНАТА СРЕДА. ЛЕСЕН НАЧИН ДА ЛОВИТЕ БЕЗПЛАТЕН ИНТЕРНЕТ ОТ ОТДАЛЕЧЕНИ МРЕЖИ
Най добрия адаптер за отключване на WI- FI мрежи
чипсетът му работи с BackTrak 9
ALFA Wireless USB 802. 11b/g 1W Long Range Adapter
-Supports wireless data encryption with 64/128-bit WEP, WPA, WPA2, TKIP, AES
-2. 4GHz frequency band, MIMO (Multiple Input Multiple Output)
-High speed transfer TX data rate up to 54 Mbps
Устройството е чисто ново с оригинален стикер както се вижда на снимката
СПЕЦИФИКАЦИИ
* Connects at a full 54Mbps via USB 2.0, up to 8 times faster than a USB 1.1 adapter
* High gain upgradeable
* Compact size for greater flexibility
* Also compatible with USB 1.1 desktop and notebook computers
* Plug-and-Play Compatible with windows 98SE, 2000, Millennium, XP and Linux
* High security 64/128/256bit WEP Encryption, TKIP, WPA, 802.11
Data Rate 802.11b: UP to 11Mbps, 802.11g: 54Mbps
Antenna Type 1 x 2.4Ghz SMA connector
Chipset Realtek 8187L
Output Power 24dBm (OFDM), 30dBm(CCK)
Frequency Stability within +25 ppm
Data Modulation Type BPSK,QPSK, CCK and OFDM
Security WEP 64/128, 802.1X support, Wi-Fi Protected Access (WPA), WPA-PSK ,WPA II .
Dimensions 8.5 x 2.2 x 6.3cm
Weight 38.5g
цена 55лв
тел. 0898558211
за други градове с Еконтекспрес
[img width=800 height=589]http://krasisoft.hit.bg/wifi/pic_00190706_1.jpg[/img]
