1. Гигабитов, 24-порта, NORTEL Ethernet Routing Switch 4524GT, с планки за монтаж в 19" шкаф. Всички RJ45-портове и SFP-слотове са тествани и нямат проблеми.
Hardware Rev: 02 Resets: 18 Initializing Flash... Reading MAC Address... MAC Address: 00-21-62-13-34-00 Initializing Switch CBs... Attaching SOC unit 0... PCI device ASIC1 attached as unit 0...
Diagnostic Version 5.1.0.7 Fri Oct 05 10:37:44 2007
Press Control-C to Enter Diag
Test ROM Config - PASSED Test FANs - PASSED Test Internal Loopback - PASSED Test ASIC1 Registers - PASSED Test PHY Registers - PASSED Test USB Registers - PASSED
Configured In Use Last BootP --------------- --------------- --------------- Stack IP Address: 0.0.0.0 0.0.0.0 Switch IP Address: 0.0.0.0 192.168.12.64 192.168.12.64 Subnet Mask: 0.0.0.0 255.255.255.0 255.255.255.0 Default Gateway: 0.0.0.0 192.168.12.2 192.168.12.2 *****Port Interface***** Status Auto Flow Port Trunk Admin Oper Link LinkTrap Negotiation Speed Duplex Control ---- ----- ------- ---- ---- -------- ----------- -------- ------ ------- 1 Enable Down Down Enabled Enabled 2 Enable Up Up Enabled Enabled 1000Mbps Full Symm 3 Enable Down Down Enabled Enabled 4 Enable Down Down Enabled Enabled 5 Enable Up Up Enabled Enabled 1000Mbps Full Symm 6 Enable Down Down Enabled Enabled 7 Enable Down Down Enabled Enabled 8 Enable Down Down Enabled Enabled 9 Enable Down Down Enabled Enabled 10 Enable Down Down Enabled Enabled 11 Enable Down Down Enabled Enabled 12 Enable Down Down Enabled Enabled 13 Enable Down Down Enabled Enabled 14 Enable Down Down Enabled Enabled 15 Enable Down Down Enabled Enabled 16 Enable Down Down Enabled Enabled 17 Enable Down Down Enabled Enabled 18 Enable Down Down Enabled Enabled 19 Enable Down Down Enabled Enabled 20 Enable Down Down Enabled Enabled 21 Enable Down Down Enabled Enabled 22 Enable Down Down Enabled Enabled 23 Enable Down Down Enabled Enabled 24 Enable Down Down Enabled Enabled 4524GT>
3. Два броя управляеми, 24-порта, стекируем, PoE суич Nortel 470-24T-PWR. Всички портове и слотове и на двете устройства са тествани и нямат проблеми. PoE-функционалността е тествана с IP-телефон LG Nortel LIP-6812D.
4. Два броя DELL PowerConnect 5448 - гигабитов, 48-портов, управляем суич, с планки за монтаж в 19" шкаф.Всички портове на двата суича, включително и SFP-слотовете са тествани и нямат проблеми.
Два броя DELL PowerConnect 5324 - гигабитов, управляем, Layer 2 суич, с планки за монтаж в 19" шкаф.Всички портове на двата суича, включително и SFP-слотовете са тествани и нямат проблеми.
6. Два броя HP ProCurve 2824 (J4903A) - гигабитов, управляем, basic Layer 3 суич. Единият е с планки за монтаж в 19" шкаф. Ъпдейтвани до последна версия на фърмуера, с поддръжка на DHCP snooping. Всички портове на двата суича, включително и SFP-слотовете са тествани и нямат проблеми.
Цена: 170 лв./бр.
Намират се в Пловдив. Доставка до други населени места - ЕКОНТ, с вкл. опция за преглед и тест, за сметка на купувача. тел.: O885 199 229
18-07-14, 15:20
plameni
Отговор: Продавам мрежово оборудване
7. управляем, гигабитов суич, 24-порта, Netgear GS724Tv2, с планки за монтаж в 19" шкаф. Всички портове, включително и SFP-слотовете са тествани и нямат проблеми.
8. гигабитов, управляем, Layer 2 суич, 48-порта, D-Link DGS-1248T, с планки за монтаж в 19" шкаф.Всички RJ45-портове и SFP-слотове са тествани и нямат проблеми.
-------------------------------------- 6. Два брояHP ProCurve 2824 (J4903A)- суичът с планките е продаден.
9. Добавям Allied Telesis AT-x600-24Ts-60 - гигабитов, стекируем, управляем, Layer 3 суич. Суичът е нов, в неразпечатана, оригинална опаковка и с неразпечатан комплект аксесоари. Отворена е само кутията, за да бъдат направени снимки.
10. Добавям 2 бр. 3Com 4500 PWR 26-Port (3CR17571-91) - управляем, стекируем, Layer 3, PoE суич, с планки за монтаж в 19" шкаф. Поддържат се както IEEE 802.3af, така и legacy PoE (Cisco pre-standard). Всички портове, включително и SFP-слотовете са тествани и нямат проблеми. PoE-функционалността на всички портове е тествана с IP-телефони LG Nortel LIP-6812D, Cisco CP-7940G и Cisco CP-7960G.
Добавям: 11. PoE injector PowerDsine 6548, с пълен комплект аксесоари. Уникален дизайн - 48 порта в 1U. Поддържат се както IEEE 802.3af, така и legacy PoE (Cisco pre-standard). Всички портове са тествани с IP-телефони LG Nortel LIP-6812D, Cisco CP-7940Gи Cisco CP-7960G.
Waiting 2 sec. Press '@' to enter MONITOR
Configured IP = 192.168.0.50
Configured Mask = 255.255.255.0
MAC Address= 00:05:5a:02:26:d5
[FFS ] Start NOR file system (use also 39836 byte from RAM) [OK])
[FFS ] Total cmpressed files size=0 byte, decompressed size=0
Will occupy 0 inside RAM File System
[FFS ] malloc() 53665 for uncompressed files,10000 for compressed files
[FFS ] Start RAM file sys... allocate 3145728 (left 3096576) [OK]
[FFS ] FLASH file system: size=1179648. Free= 301056,Used=878592. Bad=0.
[FFS ] RAM file system : size=3096576. Free= 3096576,Used=0. Bad=0.
[DB ] Def DB size is:8335
[DB ] Found valid DB at size 8341
[WDG ] Start software watchdog
[MNGR] === NMS Manager module software version: 3.05.04.13 ===
[MNGR] NMS HW Card Type=RON. HW Type=4
[MNGR] Get basic parameters from RAM-DB
[MNGR] Get MIDSPAN related parameters from RAM-DB
[MNGR] Set IP=192.168.0.50 Mask=255.255.255.0 DGW=192.168.0.1 DNS=0.0.0.0
[TLNT] Start Telnet Server (TCP port 23)
[MNGR] Comm test with HC08 pass. Try to sync HC08 with DB
[MNGR] Midspan:PN=6863, 48/48 (Log/Phys) Ports, Name=PD-6548/AC/M
SysOiD=1.3.6.1.4.1.7428.1.1.1.8 , MaxPwr(internal)=400[W]
[MNGR] Read HC08 Config: Start reading from HC08
[MNGR] Read HC08 Config: Done.
[MNGR] Check HC08 cfg with DB: Start to compare HC08 config, with DB
[MNGR] Check HC08 cfg with DB: HC08 config, and DB config are the same
[SNMP] Update MIB-II System branch plus GET/SET/TRAP community
[SNMPV3] Calc keys for 'view'.... Done
[SNMPV3] Calc keys for 'admin'.... Done
[WEB ] Start HTTP(port 80) & HTTPS(port 443) WEB Server
[NTP ] No TIME reply from 128.249.1.10 NTP server
[MNGR] Free RAM space=3170304 byte. Free Buffers=254
Main Menu - [Midspan PoE Device]
1. View menu
2. Configuration & maintenance menu
3. Ping remote host
E. Exit to debug information screen
Цена: 220 лв.
12. Суич 24-port PoE ZyXEL ES-2024PWR, с планки за монтаж в 19" шкаф.
- 24 10/100BASE-TX ports with PoE;
- 2 gigabit combo ports SFP and 10/100/1000BASE-T.
Един от вентилаторите е за ремонт/подмяна (вижда се на скрийншота).
тел.: 0885 199 229
6. HP ProCurve 2824 (J4903A) - продаден
към т. 12 добавям още 3 бр. суич 24-port PoE ZyXEL ES-2024PWR, с планки за монтаж в 19" шкаф.Всички портове, включително и SFP-слотовете са тествани и нямат проблеми. PoE-функционалността е тествана с IP-телефон LG Nortel LIP-6812D.
Цена: 110 лв./бр. Намират се в Пловдив.
тел.: 0885 199 229
