1. Гигабитов, 24-порта, NORTEL Ethernet Routing Switch 4524GT, с планки за монтаж в 19" шкаф.
Всички RJ45-портове и SFP-слотове са тествани и нямат проблеми.
Конзола:
Код:Booting... Testing main memory - PASSED Starting... Ethernet Routing Switch 4524GT Boot Version 5.1.0.1 Fri Apr 20 13:52:21 2007 Hardware Rev: 02 Resets: 18 Initializing Flash... Reading MAC Address... MAC Address: 00-21-62-13-34-00 Initializing Switch CBs... Attaching SOC unit 0... PCI device ASIC1 attached as unit 0... Diagnostic Version 5.1.0.7 Fri Oct 05 10:37:44 2007 Press Control-C to Enter Diag Test ROM Config - PASSED Test FANs - PASSED Test Internal Loopback - PASSED Test ASIC1 Registers - PASSED Test PHY Registers - PASSED Test USB Registers - PASSED Starting Agent Code... Decompressing the image done. Initializing ...... Broadcom Command Monitor: Copyright (c) 1998-2005 Broadcom Corporation Completing initialization... ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ########### Enter Ctrl-Y to begin. *************************************************************** *** Ethernet Routing Switch 4524GT *** *** Nortel *** *** Copyright (c) 1996-2007, All Rights Reserved *** *** *** *** HW:02 FW:5.1.0.7 SW:v5.1.0.000 *** *************************************************************** 4524GT>show tech *****MEMORY INFORMATION***** status bytes blocks avg block max block -------- -------------- ---------- ---------- ---------- current free 75476528 5 15095305 75470472 alloc 31796000 11625 2735 - internal 616 3 205 - cumulative alloc 37133176 15614 2378 - peak alloc 31816808 - - - *****IP Configuration***** Bootp Mode: BootP When Needed Configured In Use Last BootP --------------- --------------- --------------- Stack IP Address: 0.0.0.0 0.0.0.0 Switch IP Address: 0.0.0.0 192.168.12.64 192.168.12.64 Subnet Mask: 0.0.0.0 255.255.255.0 255.255.255.0 Default Gateway: 0.0.0.0 192.168.12.2 192.168.12.2 *****Port Interface***** Status Auto Flow Port Trunk Admin Oper Link LinkTrap Negotiation Speed Duplex Control ---- ----- ------- ---- ---- -------- ----------- -------- ------ ------- 1 Enable Down Down Enabled Enabled 2 Enable Up Up Enabled Enabled 1000Mbps Full Symm 3 Enable Down Down Enabled Enabled 4 Enable Down Down Enabled Enabled 5 Enable Up Up Enabled Enabled 1000Mbps Full Symm 6 Enable Down Down Enabled Enabled 7 Enable Down Down Enabled Enabled 8 Enable Down Down Enabled Enabled 9 Enable Down Down Enabled Enabled 10 Enable Down Down Enabled Enabled 11 Enable Down Down Enabled Enabled 12 Enable Down Down Enabled Enabled 13 Enable Down Down Enabled Enabled 14 Enable Down Down Enabled Enabled 15 Enable Down Down Enabled Enabled 16 Enable Down Down Enabled Enabled 17 Enable Down Down Enabled Enabled 18 Enable Down Down Enabled Enabled 19 Enable Down Down Enabled Enabled 20 Enable Down Down Enabled Enabled 21 Enable Down Down Enabled Enabled 22 Enable Down Down Enabled Enabled 23 Enable Down Down Enabled Enabled 24 Enable Down Down Enabled Enabled 4524GT>
Цена: 120 лв.
2. Управляем, 48-порта, PoE суич Nortel Business Ethernet Switch 120-48T-PWR.
- 48 x 10/100 Mbps ports
- 2 Dual Personality SFP or 10/100/1000 Mbps ports
- PoE on ports 1 - 24
PoE-функционалността на портове 1 - 24 е тествана с IP-телефон LG Nortel LIP-6812D.
Цена: 150 лв.
3. Два броя управляеми, 24-порта, стекируем, PoE суич Nortel 470-24T-PWR.
Всички портове и слотове и на двете устройства са тествани и нямат проблеми.
PoE-функционалността е тествана с IP-телефон LG Nortel LIP-6812D.
Конзола 1:
Код:470-24T-PWR Diagnostics 3.6.0.7 Testing main memory - PASSED Resets: 33. Initializing Flash.. Reading MAC Address.. MAC Address: 00:18:B0:F2:F1:20 Initializing Switch CBs,..... Initializing Switch HW.. Board Type: 2 Board Variation: 3 Board Revision: 1 Manufacture Revision: 31 Manufacture Date: 09132006 Serial Number: SACC6002FP MAC Address: 00:18:B0:F2:F1:20 Redundant DC: UNKNOWN Board AC: OK GBIC-25 Type: SX GBIC-26 Type: SX Stack Base Switch: ON Type: Address: Name:__________ Version:_______ InterOpVer: DIAG-A 00000000 Diagnostics 3.6.0.7 AGENT-A 00100000 NT ES Agent 3.7.5.012 00000002 DIAG-B 00400000 Diagnostics 3.6.0.6 AGENT-B 00500000 NT ES Agent 3.6.2.4 00000002 Test 102 ROM Config - PASSED Test 104 FANs - PASSED Test 207 NSXs Direct Registers - PASSED Test 209 NSXs Indirect Reg/Mem - PASSED Test 210 NSXs XRAM Adr/Data Lines - PASSED Test 211 PHYs Register - PASSED Test 212 NSXs Internal Loopback - PASSED Test 213 CAM Interrupt - PASSED Test 214 SNMP Interrupt - PASSED Test 215 PHYs Interrupt - PASSED Starting Agent Code.. Decompressing the image... done. Target Name: vxTarget User: target Attaching network interface idtip0... done. Attaching network interface lo0... done. Completing initialization... ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ########### Enter Ctrl-Y to begin. *************************************************************** *** Ethernet Switch 470-24T-PWR *** *** Nortel *** *** Copyright (c) 1996-2009, All Rights Reserved *** *** ESS 3.7 *** *** HW:31 FW:3.6.0.7 SW:v3.7.5.12 ISVN:2 *** ***************************************************************
Конзола 2:
Код:470-24T-PWR Diagnostics 3.6.0.7 Testing main memory - PASSED Resets: 38. Initializing Flash.. Reading MAC Address.. MAC Address: 00:1C:EB:F7:86:00 Initializing Switch CBs,..... Initializing Switch HW.. Board Type: 2 Board Variation: 3 Board Revision: 1 Manufacture Revision: 32 Manufacture Date: 09052007 Serial Number: LBNNTMJX6004V0 MAC Address: 00:1C:EB:F7:86:00 Redundant DC: UNKNOWN Board AC: OK GBIC-25 Type: SX GBIC-26 Type: SX Stack Base Switch: ON Type: Address: Name:__________ Version:_______ InterOpVer: DIAG-A 00000000 Diagnostics 3.6.0.7 AGENT-A 00100000 NT ES Agent 3.7.5.012 00000002 DIAG-B 00400000 Diagnostics 3.6.0.6 AGENT-B 00500000 NT ES Agent 3.6.2.4 00000002 Test 102 ROM Config - PASSED Test 104 FANs - PASSED Test 207 NSXs Direct Registers - PASSED Test 209 NSXs Indirect Reg/Mem - PASSED Test 210 NSXs XRAM Adr/Data Lines - PASSED Test 211 PHYs Register - PASSED Test 212 NSXs Internal Loopback - PASSED Test 213 CAM Interrupt - PASSED Test 214 SNMP Interrupt - PASSED Test 215 PHYs Interrupt - PASSED Starting Agent Code.. Decompressing the image... done. Target Name: vxTarget User: target Attaching network interface idtip0... done. Attaching network interface lo0... done. Completing initialization... ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ########### Enter Ctrl-Y to begin. *************************************************************** *** Ethernet Switch 470-24T-PWR *** *** Nortel *** *** Copyright (c) 1996-2009, All Rights Reserved *** *** ESS 3.7 *** *** HW:32 FW:3.6.0.7 SW:v3.7.5.12 ISVN:2 *** ***************************************************************
Цена: 110 лв./бр.
Намират се в Пловдив.
Доставка до други населени места - ЕКОНТ, с вкл. опция за преглед и тест, за сметка на купувача.
тел.+хххххххххххх
