| Camera |  Model |  IPCX-BC28321080:2.0MP |
 | Image Sensor |  1/2.8'' CMOS |
 | DWDR, BLC |
 | Minimum Illumination |  0.001Lux; 0Lux(IR on) |
 | Electronic Shutter |  Auto/Manual |
 | Lens |  3.6mm standard  |
 | Day& Night |  IR cut filter with auto switch |
 | Digital noise reduction |  3D DNR, Anti FOG, BLC, DWDR |
 | Synchronization |  Internal Synchronization |
 Compression
Standard |  Video Compression |  H.264 |
 | Bit Rate |  0.1 Mbps ~ 6 Mbps |
 | Dual Stream |  Yes |
 | Image |  Max. Image Resolution |  1920x1080 (1080P) |
 | 720p, D1, CIF |
 | Frame Rate |  25/30fps |
 | Image Settings |  Saturation, brightness, contrast,sharpness adjustment |
 | Backlight compensation |  Auto |
 | White Balance |  Auto |
 | Network |  Remote operation |  System settings,stream management, account management, network
management |
 | Motion detection |  Support |
 | Protocols |  TCP/IP, HTTP, DHCP, DNS, DDNS, RTP, RTSP, PPPoE, SMTP,  |
 | ICMP, FTP, 802.1X, HTTPS, NTP, UPnP, |
 | Network Transmission |  P2P penetrate automatic forwarding |
 | System Compatibility  |  ONVIF 2.0 |
 | Detection and alarm |  Client alarm,E-mail alerm |
 | Privacy Masking |  Supports four block area block |
 | Mobile Monitoring |  Support Android,iPhone OS |
 | Interface |  Communication Interface  |  1 RJ45 10M / 100M ethernet interface |
 | General |  Operating Conditions |  -30 °C ~ 55 °C (-22 °F ~ 131 °F) |
 | Humidity 10%~90% |
 | Power Supply |  DC 12V 1A or 2A (Not included) |
 | Power Consumption |  Max. 8 W |
 | Waterproof |  No |
 | IR Range |  36 pcs LEDs, Up to 20 meters(65.6ft), Depends on the size of lens |
 | Connector |  RJ45 & 5.5mm DC Plug |
 | Camera Weight / Size |  180g / 92*75mm(diameter*high) |
 | Packing Weight / Size |  300g / 100×100×92 mm |
