Пълен комплект: кабели (brake-out) + дискове (8 бр.) + книжки
Цена: 65лв.
София, 0877 22 33 45
Буксата на SPDIF OUT трябва да се смени ако ще се използва.
Sample Rates: 44.1, 48, 88.2, 96, 176.4, 192kHz from internal crystal or externally supplied clock (no sample rate conversion)
Bit Depths: 24-bit I/O, 32-bit processing
PCI Specification:
- PCI 2.2 Compliant
- Form Factor: Universal Keyed, Short PCI Card
- 3.3V I/O, 5V Tolerant
- PCI Bus-Mastering DMA subsystem reduces CPU usage
E-MU E-DSP: 32-bit DSP with 67-bit accumulator (double precision w/ 3 headroom bits)
Processing: Hardware-accelerated, 32 channel mixing, and multi-effects processing
Hardware monitoring: Zero-latency direct hardware monitoring w/effects
Drivers: ASIO2, WDM/MME/DirectSound, and 64-bit Drivers
Anti-Pop speaker protection: Minimizes noise during power on/off
Ultra-low jitter clock subsystem: < 1ns in PLL mode (44.1kHz, Opt. S/PDIF Sync)
Analog Line Inputs (2):
Type: DC-coupled, low-noise input circuitry
A/D converter: PCM1804
OpAmp: NJM2068
Level: -10dBV nominal, 6dBV max (unbalanced)
Frequency Response (20Hz-20kHz): +0.20/-.10dB
Dynamic Range (1kHz, A-weighted): 111dB
Signal-to-Noise Ratio (A-weighted): 111dB
THD+N (1kHz at -1dBFS): 100dB (.0001%)
Stereo Crosstalk (1kHz at -1dBFS): < -120dB
Analog Line Outputs (2):
Type: Low-pass, 3-pole low-pass differential filter
D/A converter: AK4396
Frequency Response (20Hz - 20kHz): 0.05/-.010dB
Dynamic Range (1kHz, A-weighted): 116dB
Signal-to-Noise Ratio (A-weighted): 116dB
THD+N (1kHz at -1dBFS): -100dB (.0001%)
Stereo Crosstalk (1kHz at -1dBFS): < -109dB
Digital I/O:
S/PDIF:
- 2 in/2 out optical or coaxial (transformer coupled)
- AES/EBU or S/PDIF format (software selectable)
MIDI:
- 1 in, 1 out
Synchronization:
Internal crystal sync: 44.1, 48, 88.2, 96, 176.4, 192kHz
External sample rate sync: - S/PDIF (opt. or coax 44.1 - 96kHz)
SMPTE/LTC/MTC (via optional Sync Daughtercard):
- 24, 25, 30 drop-frame, 30 non-drop
- SMPTE to MTC, MTC to SMPTE Conversion
- SMPTE Striping
- Flywheel/Jam/Regenerate
