Продавам чисто нов, неотварян Cambridge Audio DacMagic.
Закупен на 30.12.2011 от официалния представител в София.
В гаранция до 20.12.2013 година.
D/A Converters: Dual Wolfson WM8740 24bit DACs
Digital filter: Texas Instruments TMS 320VC5501 DSP upsampling to 24bit 192kHz
Analogue filter: 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
Frequency Response: 20Hz to 20kHz (±0.1dB) - steep filter disabled
THD @ 1Khz 0dBFs: <0,001% (24 bit)
THD @ 1kHz -10dBFs: <0.001%
THD @ 20kHz 0dBFs: <0.002%
Signal to Noise Ratio: -112dBr
Total correlated jitter: <130pS
Crosstalk @ 1kHz: < -100dB
Crosstalk @ 20kHz: < -90dB
Output Impedance: <50ohms
Output level (unbalanced): 2.1V rms
Output level (balanced): 4.2V rms (2.1V per phase)
Digital input word widths supported: 16-24bit (16 bit for USB)
Digital input sampling frequencies supported: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz (44.1kHz, 48kHz for USB)
Audio output up-sampling: Fixed 24bit 192kHz
Dimensions (H x W x D): 52 x 215 x 191mm
Weight: 1.2kg
Повече за продукта:
http://www.cambridgeaudio.com/summar...&Title=Summary
Намира се в София. Изпращам с Еконт навсякъде за сметка на купувача.
Цена - 550 лв.
За контакти - 0884 123424
