Дънна платка :Intel D915GAG
направена в Канада ! Останалите компоненти са все още налични .
Характеристики :
Form Factor • ATX (12.00” x 9.60”) Intel Desktop Board D915GAV/D915GEV
• MicroATX (9.60” x 9.60”) Intel Desktop Board D915GUX/D915GAG
Processor Support for an Intel® Pentium® 4 processor in the LGA775 package
Main Memory Desktop Boards D915GAV and D915GAG:
• Four 184-pin, 2.5 V SDRAM Dual Inline Memory Module (DIMM) sockets
• 400/333 MHz single or dual channel DDR SDRAM interface
• Designed to support up to 4 GB of system memory
Desktop Boards D915GEV and D915GUX:
• Four 240-pin, 1.8 V SDRAM Dual Inline Memory Module (DIMM) sockets
• 533/400 MHz single or dual channel DDR2 SDRAM interface
NOTE: System resources (such as PCI and PCI Express*) require physical memory
address locations that reduce available memory addresses above 3 GB. This may
result in less than 4 GB of memory being available to the operating system and
applications. For the latest list of tested memory, refer to the Intel World Wide Web
site at: http://support.intel.com/support/motherboards/desktop/
Chipset Intel® 915G Express Chipset consisting of:
• Intel® 82915G Graphics and Memory Controller Hub (GMCH) with Direct Media
Interface
• Intel® 82801FB I/O Controller Hub (ICH6)
• Firmware Hub (FWH)
Graphics Intel 915G Express Chipset with Intel® Graphics Media Accelerator 900
Audio • Intel 915G Express Chipset
• Intel® High Definition Audio
• Realtek codec
Expansion
Capabilities
Desktop boards D915GAV and D915GEV:
• Four PCI bus add-in card connectors (SMBus routed to PCI bus 2)
• One PCI Express x16 connector and two PCI Express x1 connectors
Desktop boards D915GAG and D915GUX:
• Two PCI bus add-in card connectors (SMBus routed to PCI bus 2)
• One PCI Express x16 connector and one PCI Express x1 connector
http://i187.photobucket.com/albums/x.../IMAGE_396.jpg
Процесор на Дъното:
Intel Celeron D LGA 775 : Intel Celeron D 336 Prescott 2.8GHz 256KB L2 Cache LGA 775 84W Single-Core Processor
+качествен радиатор на Cooler Master *виждат се на снимката
Видеокарта на платката :
Radeon X300SE PCIe 128 MB
Характеристики :
128MB of HyperMemory *512MB version is equipped with 128MB of Onboard VRAM 64-Bit memory interface Engine clock: 325MHz Memory clock: 600MHz (300MHz DDR) PCI Express x16 lane native support Outputs: DVI-I, S-Video TV-out Full support for DirectX OpenGL functionality SMARTSHADER HD technology SMOOTHVISION HD
Памет към платката :takeMS
4бр х 256 MB DDR400 cl.2,5 dual channel
http://www.overclockers.ru/images/la...ddr400_spd.gif
Хард диск към дъното :
HDD Maxtor DiamondMax Plus 9 (модел 6Y080x0) 80GB, SATA, 2MB Cache
БЕЗ нито един "bad" sector .
Захранване за дъното :
Delta Electronics > 300 W
http://i187.photobucket.com/albums/x.../IMAGE_398.jpg
+ Подарък DVD Benq 16x
+ Подарък CRT Монитор по избор от двата модела :
NEC Multisyn XE21
KFC CA653
Към всички компоненти имам съответните кабели !
Цена за Всичките компоненти изброени до момента > 160 лева < Нова цена > 120 лева *без видеокарта
Аsus PTGD1-LA
Снимки :
http://s187.photobucket.com/albums/x...t=PB080146.jpg
http://s187.photobucket.com/albums/x...t=PB080145.jpg
Характеристики :
Features/Specifications:
ASUS PTGD1-LA Socket 775 ATX MB w/P4 3.4GHz
General Features:
Supports Hyper-Threading Technology
Supports up to 3.4 GHz CPU
Intel Pentium 4 CPU 3.4 GHz pre-installed
Socket 775
ATX Form Factor
800 MHz Front Side Bus
Supports up to 4GB DDR266/333/400
One FDD connector
RealTek ALC650 8-channel audio with Intel High Definition Audio CODEC
Supports 4 Serial ATA devices
Realtek RTL8101L LAN
10/100 Mbps Fast Ethernet controller
Expansion Slots:
One (1) PCI Express x16 graphics PEG slot
Three (3) PCI slots
No AGP slot
I/O Ports:
One (1) parallel port
One (1) video (VGA) port
Two (2) PS/2 ports
One (1) RJ-45 Fast Ethernet LAN port
One (1) IEEE 1394 port
Four (4) USB Ports
Six (6) audio ports support 8-channel audio configuration
Installed Processor:
Intel P4 LGA-775 CPU
3.40 GHz/1M/800
Supported Processors:
Intel LGA-775 CPU
800 MHz FSB
3.4 GHz max
Regulatory Approvals:
FCC
CE
BSMI
Package Includes:
ASUS (HP OEM) Socket 775 Motherboard
Intel Pentium 4 3.4 GHz CPU
Notes:
Model: PTGD1-LA (Grouper)
HP P/N: 5187-7616
No manual or drivers included
+ 1 GB DDR 400 PC 3200 CL 2.5 *4x256 MB
+ Intel Celeron D LGA 775 : Intel Celeron D 336 Prescott 2.8GHz 256KB L2 Cache LGA 775 84W Single-Core Processor
Цена : 80 лева *Цената е за дъното + изброените по горе компоненти !
-дъното е без планка за това е и такава цената
За контакти :
Компонентите както и аз се намират в София !
Иван Петков : 0884636486
Тук на ЛС - или е-mail : krokotamus(@)mail.bg
Скайп : ithe60kp(без скобите)
Пращам с наложен платеж до всички точки на България ! Използвам Еконт.
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
  Отговор с цитат
  Отговор с цитат
