Продавам проекторSahara Protector XGA projector с нова лампа на няколко часа
  Продавам проектор Sahara Protector XGA projector с нова лампа на няколко часа. Работи перфектно. Резолюция 1024х768
 Panel TI DMD 0.55-inch, 12 deg. DDR Vertical Scan Rate 50-85Hz
 XGA (1024x768) Projection Position Front/Rear, Table/Ceiling
 HDTV Compatibility 480P, 480i, 720P, 1080i Lamp 200W
 Data Compatibility VGA, SVGA, XGA, SXGA Audio Noise <36dB
 Brightness 1500 ANSI Lumens Input Terminals DVI, PC RGB, Video, S-Video, Component
 Image Size (diagonal) 37” - 240” Audio, RS232, USB
 Projection Distance 1.5M—8M Output Terminals Audio, PC RGB, USB
 Zoom Ratio 1.22:1
 Contrast Ratio 1500:1 Speakers 2W x 1
 Number of Colours 16.7 Million (24-bits/pixel) Dimensions (WxDxH) 328mm x 238mm x 88mm
 Aspect Ratio 4:3 / 16:9 screen selectable Weight 3.55 Kg
 Digital Keystone Correction (V) +/- 15 degrees Power Supply 100-240VAC, 47-63 HZ
 Video Compatibility NTSC, NTSC4.43, PAL, B/G/H/I/M/N 60, SECAM Power Consumption 300W (Max.)
 Horizontal Frequency 15, 31-70kHz Safety & Regulatory FCC Class B, UL, CUL, TUV-GS, CE, CB, CCC Намира се в гр.Пловдив Съби тел.0887286387 пращане по еконт,за гр.Пловдив доставка на място с тестване. цена 490 лв.http://www.wedgwood-group.com/sahara..._projector.htm . http://www.wedgwoodav.com/Download.a...ctRef=Q61JJI38
     Re:Продавам проекторSahara Protector XGA projector с нова лампа на няколко часа
