Продавам проектор Sahara Protector XGA projector с нова лампа на няколко часа. Работи перфектно. Резолюция 1024х768
Panel TI DMD 0.55-inch, 12 deg. DDR Vertical Scan Rate 50-85Hz
XGA (1024x768) Projection Position Front/Rear, Table/Ceiling
HDTV Compatibility 480P, 480i, 720P, 1080i Lamp 200W
Data Compatibility VGA, SVGA, XGA, SXGA Audio Noise <36dB
Brightness 1500 ANSI Lumens Input Terminals DVI, PC RGB, Video, S-Video, Component
Image Size (diagonal) 37” - 240” Audio, RS232, USB
Projection Distance 1.5M—8M Output Terminals Audio, PC RGB, USB
Zoom Ratio 1.22:1
Contrast Ratio 1500:1 Speakers 2W x 1
Number of Colours 16.7 Million (24-bits/pixel) Dimensions (WxDxH) 328mm x 238mm x 88mm
Aspect Ratio 4:3 / 16:9 screen selectable Weight 3.55 Kg
Digital Keystone Correction (V) +/- 15 degrees Power Supply 100-240VAC, 47-63 HZ
Video Compatibility NTSC, NTSC4.43, PAL, B/G/H/I/M/N 60, SECAM Power Consumption 300W (Max.)
Horizontal Frequency 15, 31-70kHz Safety & Regulatory FCC Class B, UL, CUL, TUV-GS, CE, CB, CCC Намира се в гр.Пловдив Съби тел.0887286387 пращане по еконт,за гр.Пловдив доставка на място с тестване. цена 490 лв.http://www.wedgwood-group.com/sahara..._projector.htm . http://www.wedgwoodav.com/Download.a...ctRef=Q61JJI38
