Резултати от 1 до 6 от общо 6
Продавам качествени компютърни компоненти !
    Mar 2011
    Дънна платка :Intel D915GAG
    направена в Канада ! Останалите компоненти са все още налични .
    Характеристики :
    Form Factor • ATX (12.00” x 9.60”) Intel Desktop Board D915GAV/D915GEV
    • MicroATX (9.60” x 9.60”) Intel Desktop Board D915GUX/D915GAG
    Processor Support for an Intel® Pentium® 4 processor in the LGA775 package
    Main Memory Desktop Boards D915GAV and D915GAG:
    • Four 184-pin, 2.5 V SDRAM Dual Inline Memory Module (DIMM) sockets
    • 400/333 MHz single or dual channel DDR SDRAM interface
    • Designed to support up to 4 GB of system memory
    Desktop Boards D915GEV and D915GUX:
    • Four 240-pin, 1.8 V SDRAM Dual Inline Memory Module (DIMM) sockets
    • 533/400 MHz single or dual channel DDR2 SDRAM interface
    NOTE: System resources (such as PCI and PCI Express*) require physical memory
    address locations that reduce available memory addresses above 3 GB. This may
    result in less than 4 GB of memory being available to the operating system and
    applications. For the latest list of tested memory, refer to the Intel World Wide Web
    site at: http://support.intel.com/support/motherboards/desktop/
    Chipset Intel® 915G Express Chipset consisting of:
    • Intel® 82915G Graphics and Memory Controller Hub (GMCH) with Direct Media
    Interface
    • Intel® 82801FB I/O Controller Hub (ICH6)
    • Firmware Hub (FWH)
    Graphics Intel 915G Express Chipset with Intel® Graphics Media Accelerator 900
    Audio • Intel 915G Express Chipset
    • Intel® High Definition Audio
    • Realtek codec
    Expansion
    Capabilities
    Desktop boards D915GAV and D915GEV:
    • Four PCI bus add-in card connectors (SMBus routed to PCI bus 2)
    • One PCI Express x16 connector and two PCI Express x1 connectors
    Desktop boards D915GAG and D915GUX:
    • Two PCI bus add-in card connectors (SMBus routed to PCI bus 2)
    • One PCI Express x16 connector and one PCI Express x1 connector
    http://i187.photobucket.com/albums/x.../IMAGE_396.jpg
    Процесор на Дъното:
    Intel Celeron D LGA 775 : Intel Celeron D 336 Prescott 2.8GHz 256KB L2 Cache LGA 775 84W Single-Core Processor
    +качествен радиатор на Cooler Master *виждат се на снимката
    Видеокарта на платката :
    Radeon X300SE PCIe 128 MB
    Характеристики :
    128MB of HyperMemory *512MB version is equipped with 128MB of Onboard VRAM 64-Bit memory interface Engine clock: 325MHz Memory clock: 600MHz (300MHz DDR) PCI Express x16 lane native support Outputs: DVI-I, S-Video TV-out Full support for DirectX OpenGL functionality SMARTSHADER HD technology SMOOTHVISION HD
    Памет към платката :takeMS
    4бр х 256 MB DDR400 cl.2,5 dual channel
    http://www.overclockers.ru/images/la...ddr400_spd.gif
    Хард диск към дъното :
    HDD Maxtor DiamondMax Plus 9 (модел 6Y080x0) 80GB, SATA, 2MB Cache
    БЕЗ нито един "bad" sector .
    Захранване за дъното :
    Delta Electronics > 300 W
    http://i187.photobucket.com/albums/x.../IMAGE_398.jpg
    + Подарък DVD Benq 16x
    + Подарък CRT Монитор по избор от двата модела :
    NEC Multisyn XE21
    KFC CA653
    Към всички компоненти имам съответните кабели !
    Цена за Всичките компоненти изброени до момента > 160 лева < Нова цена > 120 лева *без видеокарта
    Аsus PTGD1-LA
    Снимки :
    http://s187.photobucket.com/albums/x...t=PB080146.jpg
    http://s187.photobucket.com/albums/x...t=PB080145.jpg
    Характеристики :
    Features/Specifications:
    ASUS PTGD1-LA Socket 775 ATX MB w/P4 3.4GHz
    General Features:
    Supports Hyper-Threading Technology
    Supports up to 3.4 GHz CPU
    Intel Pentium 4 CPU 3.4 GHz pre-installed
    Socket 775
    ATX Form Factor
    800 MHz Front Side Bus
    Supports up to 4GB DDR266/333/400
    One FDD connector
    RealTek ALC650 8-channel audio with Intel High Definition Audio CODEC
    Supports 4 Serial ATA devices
    Realtek RTL8101L LAN
    10/100 Mbps Fast Ethernet controller
    Expansion Slots:
    One (1) PCI Express x16 graphics PEG slot
    Three (3) PCI slots
    No AGP slot
    I/O Ports:
    One (1) parallel port
    One (1) video (VGA) port
    Two (2) PS/2 ports
    One (1) RJ-45 Fast Ethernet LAN port
    One (1) IEEE 1394 port
    Four (4) USB Ports
    Six (6) audio ports support 8-channel audio configuration
    Installed Processor:
    Intel P4 LGA-775 CPU
    3.40 GHz/1M/800
    Supported Processors:
    Intel LGA-775 CPU
    800 MHz FSB
    3.4 GHz max
    Regulatory Approvals:
    FCC
    CE
    BSMI
    Package Includes:
    ASUS (HP OEM) Socket 775 Motherboard
    Intel Pentium 4 3.4 GHz CPU
    Notes:
    Model: PTGD1-LA (Grouper)
    HP P/N: 5187-7616
    No manual or drivers included
    + 1 GB DDR 400 PC 3200 CL 2.5 *4x256 MB
    + Intel Celeron D LGA 775 : Intel Celeron D 336 Prescott 2.8GHz 256KB L2 Cache LGA 775 84W Single-Core Processor
    Цена : 80 лева *Цената е за дъното + изброените по горе компоненти !
    -дъното е без планка за това е и такава цената
    За контакти :
    Компонентите както и аз се намират в София !
    Иван Петков : 0884636486
    Тук на ЛС - или е-mail : krokotamus(@)mail.bg
    Скайп : ithe60kp(без скобите)
    Пращам с наложен платеж до всички точки на България ! Използвам Еконт.
    Mar 2011
    Re:Продавам качествени компютърни компоненти !
    Хайде пишете , алъш вериша да става
    Mar 2011
    Примоция до края на седмицата : 03.03.2012
    Аsus PTGD1-LA + Celeron D + DDR 1 G = 70 лева
    Който превари
    Mar 2011
    1 ден до края на примоцията
    Mar 2011
    2-та харда за 60 лева до края на седмицата : 12.03.2012 г
    Mar 2011
    75 лева цена на Асуското дъно до края на седмицата !
  1. Продавам компютърни компоненти
    От xaxoto_lp във форум Продава
    Последно: 05-06-14, 12:30
  2. Продавам компютърни компоненти
    От Ulfhedinn във форум Продава
    Последно: 24-03-14, 20:58
  3. Отговори: 9
    Последно: 01-08-13, 21:16
  4. Продавам компютърни компоненти
    От nikihifi във форум Продава
    Последно: 27-07-12, 23:45
  5. Продавам компютърни компоненти
    От Raptor във форум Продава
    Последно: 30-07-07, 11:14
